Abz Posted November 25, 2014 Share Posted November 25, 2014 Pretty handy work there dude! Link to comment Share on other sites More sharing options...
Rich.2211 Posted November 25, 2014 Share Posted November 25, 2014 Stunning car James! I was having a nosey at the motor show Link to comment Share on other sites More sharing options...
Luxluc Posted November 26, 2014 Share Posted November 26, 2014 Simply WOW. Link to comment Share on other sites More sharing options...
Fitz Posted November 26, 2014 Share Posted November 26, 2014 Will have a nosey at this on Saturday Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 26, 2014 Author Share Posted November 26, 2014 (edited) xx Edited October 13, 2018 by TheTurtleshead (see edit history) Link to comment Share on other sites More sharing options...
j_jza80 Posted November 27, 2014 Share Posted November 27, 2014 Stunning work Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 27, 2014 Author Share Posted November 27, 2014 (edited) xx Edited October 13, 2018 by TheTurtleshead (see edit history) Link to comment Share on other sites More sharing options...
Shane Posted November 28, 2014 Share Posted November 28, 2014 Looking good. Your V8 gets delivered today btw. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 28, 2014 Author Share Posted November 28, 2014 Looking good. Your V8 gets delivered today btw. Shhh! You can deliver all the V8's you want, doesn't mean you're getting paid for any of them. Link to comment Share on other sites More sharing options...
Pudsey Posted November 28, 2014 Share Posted November 28, 2014 Looks excellent lots of very hard work gone into that. Really looking forward to hearing what you think of the performance once its all up and running. Link to comment Share on other sites More sharing options...
supra_ufo Posted November 28, 2014 Share Posted November 28, 2014 this looks mint, love to have your skills Link to comment Share on other sites More sharing options...
TheTurtleshead Posted December 6, 2014 Author Share Posted December 6, 2014 Small Update; I didn't want to use braided rubber AN line for the rear oil-return as I was worried it would melt with the heat. Therefore I am using AN10 hard line & tube nuts, which will feed into a small section of braided hose lower down(away from the heat), to allow a bit of flex. Pics of the line I bent up, and a comparison of a normal AN10 fitting to a Tube-nut flare fitting. Link to comment Share on other sites More sharing options...
David P Posted December 7, 2014 Share Posted December 7, 2014 Sound logic, maybe also a good idea to insulate it to help prevent returning hot oil to the sump? Link to comment Share on other sites More sharing options...
TheTurtleshead Posted December 20, 2014 Author Share Posted December 20, 2014 (edited) xx Edited October 13, 2018 by TheTurtleshead (see edit history) Link to comment Share on other sites More sharing options...
Krister Posted December 29, 2014 Share Posted December 29, 2014 How much power are you aiming for? That single 044 wont do much more than 600bhp. I would consider a Walbro 450. My friend dynoed 700bhp on E85 with a single Walbro which would be the same as 1000bhp on regular fuel. Link to comment Share on other sites More sharing options...
fastby4 Posted January 1, 2015 Share Posted January 1, 2015 I use the same turbo kit. two time my water lines are melt. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 1, 2015 Author Share Posted January 1, 2015 How much power are you aiming for? That single 044 wont do much more than 600bhp. I would consider a Walbro 450. My friend dynoed 700bhp on E85 with a single Walbro which would be the same as 1000bhp on regular fuel. Are you sure? I'm not running ethanol at all btw. People in the UK have managed 750-800 hp before on a single 044 with a true -8 feed line, splitting to 2x -6 at the rail, with a -6 return. Turbo's are rated to 780 at this a/r, so aiming for 700. Worst case i'll max this out and add another 044 if it needs more. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 1, 2015 Author Share Posted January 1, 2015 I use the same turbo kit. two time my water lines are melt. Were you using top quality lines from a manufacturer like goodridge, earls, speedflow etc? Did you heat insulate them? Were they rubber or teflon? Link to comment Share on other sites More sharing options...
chazuk Posted January 2, 2015 Share Posted January 2, 2015 Nice work did you upgrade the wiring top side from the connector to your relay ? Link to comment Share on other sites More sharing options...
98HT Posted January 2, 2015 Share Posted January 2, 2015 Are you sure? I'm not running ethanol at all btw. People in the UK have managed 750-800 hp before on a single 044 with a true -8 feed line, splitting to 2x -6 at the rail, with a -6 return. Turbo's are rated to 780 at this a/r, so aiming for 700. Worst case i'll max this out and add another 044 if it needs more. I think Krister is talking real hp (to the wheels). A local maxxed out his bosch at a little more, ~630 rwhp on pump 97ron. Awesome build btw, love those twins Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 2, 2015 Author Share Posted January 2, 2015 (edited) Nice work did you upgrade the wiring top side from the connector to your relay ? Not yet, I've got to look at the best way of doing that... Unpicking all the loom and upgrading the wires or potentially just adding in a new feed and earth, and sneaking them into the relay and hanger plugs where necessary. Edited January 2, 2015 by TheTurtleshead (see edit history) Link to comment Share on other sites More sharing options...
TheTurtleshead Posted February 7, 2015 Author Share Posted February 7, 2015 OOPS!!! Link to comment Share on other sites More sharing options...
JamieP Posted February 7, 2015 Share Posted February 7, 2015 Good choice Link to comment Share on other sites More sharing options...
Chris Bailey Posted February 7, 2015 Share Posted February 7, 2015 6266 or 6466? Link to comment Share on other sites More sharing options...
Fitz Posted February 7, 2015 Share Posted February 7, 2015 Glad to see the Turbo key ring got to you mate, looks huge when you take a pic close up Link to comment Share on other sites More sharing options...
