Worthy Supras to be included in MKiv Supra forum's best cars, with specs thread
AndrewOW
 Share
Additional cars to be included in best cars thread (multiple choice)
187 members have voted
  1. 1. Additional cars to be included in best cars thread (multiple choice)
  • Replies 165
Haha, funny thread. Its abit pointless imo everyones car has its plus and negative points and its all down to opinions. Never going to end well. Everyones car is worthy in one way or another e.g amount of time,effort,love put into it by the owner whether it be an na,tt,single.
Just my opinion...
Carry on:D
Agreed.
Although I am full of envy at the likes of mr price, jamesy, rob Mitchell etc for their cars, many have their great plus sides, even if not to everyone's tastes.
Saying that, I'd like to put mine forward (not expecting it to be in there ;)) but what is there to lose?
Progress thread in my sig.
Also, many of the "best" Supras have at some point gone into SRD, Whifbitz etc to be built, so should they not go down as tuner built cars, rather than being built by the owner? What about the little guys who don't have money to burn, who do a lot of the work in their own garage? KaanW for example, even though not finished, should be considered, purely for his efforts.
I can see this thread being all about "clicks". If you are not well known, or have not thrown copious amounts of money at the supra, I can not see it being considered seriously.
Just my views, no offence intended towards anyone.
who cares if its tuner built or not! mine was mainly built by me but i needed SRD for help for fabrication and plumbing in.... and im a fully qualified mechanic and did alot of time working for VW.... Dont mean i can build a supercar performance car its a different world with alot to screw up, we all need help along the lines. I respect the little builds as thats how i started.... every car and owner has different tastes and budgets.
Edited by Rob_Mitchell (see edit history)
Is my dad car considered, considering the amount its been through since February!
Full engine rebuild using ARP head studs, ARP main studs and ARP rod bolts (Completed April 2012)
- Polished HKS TO4Z turbo
- Boostlogic T4 manifold
- HKS External Wastegate and Screamer pipe
- Greddy Profec B Spec 2 Boost Controller
- Sard 650cc injectors
- Syvecs S6 ECU - Mapped by 2BarTuning
- Full 3" Exhaust System
- Whifbitz 3" Stainless Steel Singlebox Cat Back Exhaust
- HKS BOV
- K&N Air Filter
- Whifbitz FMIC Kit
- Whifbitz Aluminium Radiator
- Whifbitz Catch Tank
- Walbro Fuel Pump
- Stock Auto Box with Whifbitz Oil Cooler
- NGK Iridium Spark Plugs
- Blitz Boost Gauge
- LSD
- UK Spec Brakes
- BC Racing Suspension
- Bomex Front Spoiler
- OEM Sideskirts
- Trial Rear Bumper
- Stock Spoiler
- 18-inch Volk Racing Alloys
- Falken Tyres
- Uk Spec Glass headlights
- 6000k HID Kit
- Full Black Leather Interior
- Blue Brake Calipers With Supra Decals
- Polished Battery Cover
- Polished Battery Clamp
- Polished Fuse Box Cover
- Polished Intercooler Plate
- Polished Radiator Plate
- Polished Relay Cover
- Polished Washer Bottle Cover
- Polished Power Steering Pump
- Polished Brake Reservoir Cover
- Polished Billet Alluminium Radiator Brackets
- Polished Alluminium Radiator Top Hose
Surley my old babes has to be there somewhere, jay me have some updates...
JDM 2jzgte engine
Arp rod bolts
Arp head studs
Clevitte bearings
Boost logic reworked oil pump
new oem crank pulley
Gates racing blue timing belt
Gates racing blue aux belt
new oem water pump
Titan billet tensioner bracket
new oem idler and tensioner
oem head gasket
Whifbitz pulley set anodised purple
Whifbitz cam pullies in pruple/grey
Whifbitz 264 cams
bc springs and retainers
ferrera vss and lockers
oem rocker gaskets and cam seals
oem intake gaskets
Trd oil cap
Fueling
Sard 850cc drop injectors(all new seals)
sard fpr
whifbitz dampner removal line
new oem filter
Bosch 044 pump
Turbo
Precision 6765 .81ar turbo( compressor hpc black)
Greddy tubular manifold
Greddy Wastegate
Greddy 3" dp with v band fitted
Custom oil drain
Whifbitz oil feed
Whifbitz 4" filter pipe anodised grey
K&n 4" filter
Dei turbo blanket
Dei wrap for manifold and down pipe
Electrics
Hks F con v pro
Hks afk knock amp/afr
Blitz dual sbc
Defi boost,oil temp, oil pressure and egt gauges
Heckler resistor pack
Oem coil pack clips
Ngk iridium plugs
Any of the tt loom not needed removed
Exhaust
Vielside split type exhaust
Envy 3" mid pipe
Breathing and cooling
Whifbitz single catch can anodised grey
Srd alloy radiator
Driftworks oil cooler kit
Apr carbon cooling plate
Gearbox etc
Getrax 6 speed box
Competition stage 4 clutch
Competition ultralite flywheel
New oem release bearing and c clips
Trd gear box mount
SRD solid shift mounts
Big rear diff
Brakes and suspension
Uk breaks all round
cw pads on all corners
Titan line lock kit
Hsd coilvers
Cusco strut brace
Wheels and tyres
Front-Uk 17's 9.5" wheels, Falken 452 (255 35 17)
Rear-Uk 17's widened to 11.5", Goodyear GSC (315 35 17)
Custom 45mm wheel spacers
Just freshly refurbed in silver
Bodywork
Totally standard
Interior
Black carpets
Black head lining
Black leather front and rear seats
Top glovebox 3 gauge pod
Active spoiler switch converted for line lock
Lights
Facelift front light
Facelift side lights/indicators
Facelift rears
Clear side repeaters
Found this picture of JP's red one . Maybe Jamie can tell us who he sold it to for the spec
Rob posted a picture of Wayne's
Went abroad although I can't remember where. Denmark possibly?
Spec list from Jamie's garage...
BLOCK
Carillo Rods
CP Pistons
Billet Main End Caps
Ap Rod and Main Bolts
Clevite bearings
Greddy Kevlar Cam belt
Greddy Pulleys
CYLNDER HEAD
HKS 264/264 Cams
HKS head gasket
Ferrea Uprated Valve Springs
Titainium Caps
ARP head studs
Greddy cam Gears
TRANSMISSION
6 Speed Getrag box
Exeddy Twin plate
FUEL SYSTEM
HKS 1000cc injectors
HKS twin Feed Fuel Rail
Twin Walbro Pumps
-6 Braided Fuel Lines
Aeromotive Fuel Filter
Fuel Presure Regulator
TURBO KIT AND BOLT ONS
GT4088
Greddy Exhaust Manifold
HKS 50mm External Wastegate
Greddy Intake Plenum
Q45 Throttle Body
HKS ssqv
Sard BOV
Custom 3" Exhaust System
BREATHER SYSTEM
Polished cam covers with -12 fittings welded on
1 Litre Catch Tank With -12 fitting
ELECTRONICS
AEM EMS Stand Alone ECU
AEM Boost Controler
AEM Wideband
AEM 3.5 Bar Map Sensor
Greddy Turbo Timer
HKS DLI
Apexi Boost Gauge
Apexi EGT Gauge
Greddy Oil Pressure Gauge
Greddy Oil Temp Gauge
Battery Relocated To Boot
COOLING
Fluidine Alloy Radiator
Grex Oil Cooler Braided Lines Areoquip Fittings
K&N Cone Air Filter
Trust 3 Row Intercooler
TRD Thermostat
WHEELS AND SUSSPENSION
Trafficstar STM 8.5x19 and 12x19
Tein Coilovers
BRAKES
Front
D2 8 Pot Front Brake Calipers
Stock j-spec Disc And calipers
Off the top of my head the ones I think should 100% be in we a98pmalcoms, Budzs, lui and Wilecoyote (in the dragonball guise)
Why thankyou for the mention :hi:
(this is before the big brakes)
http://img716.imageshack.us/img716/7412/17958110151903387915532.jpg
http://img210.imageshack.us/img210/9639/20120226145220.jpg
http://img17.imageshack.us/img17/5346/20120909181952.jpg
http://img836.imageshack.us/img836/1279/69703700.png
Engine Specifications:
HKS BOV
Big Front Mount Intercooler
NGK Grade 8 Plugs
264 9.3mm Whifbitz Road Cams
AEM Water Cooled Injection
Fuel Pulsator Bypass
Whifbitz Alloy Radiator With Whifbitz Rad Cap
Whifbitz Adjustable Pulleys
Gates Racing Uprated Blue Cambelt
Blue Vacuum Pipes
Blue Radiator Pipes
Chrome Engine Components And Dress Up
JapSpeed Strut Brace
Whifbitz Uprated Coil Packs
Whifbitz Oil Catch Tank
Turbocharger & Induction:
K&N Cone Air Filter
Precision Turbo 6766 Billet
Fuel, Tuning & ECU:
Walbro Fuel 450 Pump
650cc SARD Injectors
Syvecs S6 ECU
Toucan Touch Screen Display
Syvecs Advanced Traction Control With 8 Point Adjustable Knob
Exhaust:
Whifbitz Twin Wastegate Manifold
Twin Trial 42mm Wastegates with screamers
4" Whifbitz Down Pipe
1/2 HKS Super Silent Exhaust
De-Cat
NTK L2H2 (LZA-09-E1) Wideband Lambda Sensor
Drivetrain:
RPS Carbon Triple Plate Clutch And Flywheel
Short Shifter
Weight Reduction & Transfer:
I Try To Work Out And Exercise A Few Times A Week
Suspension, Wheels, Tires & Brakes:
BC Coilovers
19" BK993 Alloys
COOPER ZEON 2XS Tyres
14.5" Big Brembo Front Brakes
13" Brembo Rear Brakes
Goodrige Braided Brake Lines
Interior & ICE:
Dah 2 Display With My Custom Carbon Surround
JVC AVX-820 Headunit
Vibe Slick S12 Sub In Custom Box Fabracted By Myself
Vibe A7 Amp
MOMO Steering Wheel
Richbrook Gearknob And Gator
Richbrook Handbrake And Gator
Colour Coded Dash
Speed Hut Dials
Retrimed Leather Seats With Supra Embroidered In And Blue Piping
Chrome dial, heater, electric mirror and gearknob Rings
After Market Pedals
Focal Speakers Rear. Big Focal Speaker Upgrade Front.
Blue l.e.d Window Switches, Slip Cont and heater control switches
Colour Coded Door Handle Surrounds
Active Spoiler Switch Converted To Heated Windscreen Switch For OEM Look
Exterior:
Full Respray In Nissan Bayside Blue
Top Secret Front Bumper
Trial Rear Bumper Flushed Into Bodywork
TRD Rear Wing With Carbon Blade
Face Lift Converted Headlights With Chrome Rings
Abflug Bonnet
OEM Skirts Flushed Into Bodywork
Facelift Rear Lights
Heated Windscreen
Edited by a98pmalcolm (see edit history)
Now TT BPU, will update soon
I will put mine forward, but it's still an N/A for the moment, so if it needs power obviously mine doesn't make the cut yet, although decent power for an N/A
Will be TT BPU very soon
http://just.razzi.me/photos/856634/83ebd06.jpg
1995 SZ-R N/A 5 speed manual
18" Work's VS-TX 3 piece Split Rims
Carbing Front Strut Brace with Brake Stop
Carbing Rear Strut Brace
Uk glass headlights
Knight-Racer Hid kit fitted 6000k (dipped beam)
HID High Beam 6000k
HID Fog 6000k
Uk front brakes with Black Diamond grooved discs
Black Diamond grooved rear discs
Katimoto 3 inch Cat Back Exhaust
TRD Wide Front Bumper
Bespoke custom made (by ShellShocked) Wide Front Wings
OEM Side Skirts fully blended and extended/widened
Veilside Overfenders with extreme blend
Oem spats blended and smoothed
Jun Carbon fibre bonnet, now painted
Ibrar's Ridox Lip Spoiler, customised by ShellShocked and fully blended
No orange blobs in the front facelift indicators
Clear rear indicator conversion
Led front sidelights X4
Led Number Plate lights
Momo Trek r black leather steering wheel
Dash Chrome Ring Set (12 in total)
1st De-Cat pipe
Sumo Power 2nd De-Cat pipe
K&N washable panel filter
Stock OEM Black Leather Front Seats
Torsen LSD Diff
Black Carpet and Black Headliner
Boot Wiper and Washer Delete
AutoShine Carbon Rear Diffuser
SpeedHut Reverse El-Glo Cluster Dials
Very Soon to be TT BPU with below parts
Greddy Black edition Profec II Boost Controller
Greddy Black Edition Turbo Timer
Depo Stepper Boost Gauge
AEM UEGO AFR Gauge
Blitz FMIC and full Blitz hardpipes
HKS SSQV BOV
Thor FCD
Walbro Fuel Pump
Edited by DodgyRog (see edit history)
 Share
