Bailey's Silver Bullet Auto
Lee P
  • Replies 540
Posted Images
Running problem has now been solved by SRD - it was a faulty boost control solenoid which Lee said was stuck in the open position so was effectively allowing really high boost levels but thankfully the syvecs made it boost cut at 2 bar which created the kangarooing effect we were experiencing. Solenoid has now been replaced and is controlling the boost much better than before.
The beast is now back to full fitness looking for a Black stock TT6 piloted by somebody called Danny;)
Edited by jcbt (see edit history)
Have you been beaten by ANOTHER stock TT? Bout time you let Chris take over in the hot seat John? :D
As you know I am generous to a fault - even TT's beat singles when they have no usable boost.
Chris's time will come once my money has run out.
  • 1 month later...
  • 2 months later...
I wish I'd known that before going with the pierburg. Yours is the first peirburg failure ive heard of though, and as you've found the syvecs will step in if it fails. But i'll be changing to a mac if the car ever needs to be remapped. :)
I bet you're glad you didn't use an emanage :D
Was going to say any 3 way controllers you can pick at what state it fails at sort of, clearly a normally open will fail allowing uncontrolled boost but if its plumbed normally closed will just run at wastegate boost , that being said if the solenoid was to jam it could be stuck in any position open or closed.
So always best to have a boost cut set in the ecu, glad nothing was damaged guys and hope to see you backmon the road soon
The car was back on the road ages ago mate, run so much smoother with the new MAC solenoid, Lee tweeked the map so that must have something to do with it. The car is back at Lee's now for a few winter modifications ;).
Car is back with us for some very nice upgrades :)
We have fitted the new wheels which look awesome and transform the look of the car.
We removed the front wheel spacers and longer studs as these were no longer needed.
Re-adjusted the height of the suspension and did a full Geo setup
We also fitted the HKS Racing Ti Exhaust
Next on the list is some engine and ECU upgrades.
John took advantage of Kaan breaking his car and purchased some parts.
Full Hypertune intake manifold kit with 90mm TB and fuel rail.
Asnu 1500cc injectors
SRD Ethanol Twin 485 fuel system with Fuel flex
Latest Syvecs S6 with IO expander and plug and play harness
SRD paddle shift kit
We are also fitting a stock torque converter back in
High stall being removed.
Engine bay before we start
Intake side stripped
Mocking up the hypertune
Fuel pump hanger removed, stripped down ready to be modded for second pump.
