T2 MSW Widebody Project
T2 MSW
 Share
  • Replies 387
So tonights little project ive started to sort out my spare set of rear lights. Want LED ones without spending a fortune on them. So doing it myself.
First of all put the lights in the over on 100 degrees for 5 minutes to seperate them. Then removed all the lenses. Cut the lugs off that hold them in and made then near smooth. And finally made some plastic inserts that go into the light resess. Will then sand it all down and spray them black.
Got some LED light rings to go on them which will also get painted black.
  • 1 month later...
So about time for a little Update :D
Car has obviously gone down to Pauls in south wales as I am just not getting time to move the project forward. Typical timing as im now coming to the end of my contract and will have the time but its done now and Paul will do a better job.
A roof till got blown off the house last winter and went through the windscreen so that was the first Job.
Out with the old
In with the new.
Then next job was a full was a full suspension and whifbitz handling kit install. So thats new bushes all round, BC coilovers and Whifbitz antiroll bars front and back.
Now car sits very high at the minute be before everyone jumps its only so it can easily be put on and off the ramp at the min.
Edited by T2 MSW (see edit history)
Couple of updates from today.
Anti roll bars fitted
Heater pipes fitted - look so much neater
Flexifuel sensor fitted. Not sure what to do with this now as found out today the fuel pumps are not Ethanol compatible :think:
And the whifbitz pulleys fitted - Looks like ive got some work to do when I get the car back as that stock black engine front looks crap and needs painting white.
http://i731.photobucket.com/albums/ww311/m5wtt/rollbar_zpse1373222.jpg
http://i731.photobucket.com/albums/ww311/m5wtt/heater_zpsc411567b.jpg
http://i731.photobucket.com/albums/ww311/m5wtt/flexifuel_zpsd4f5a766.jpg
http://i731.photobucket.com/albums/ww311/m5wtt/pulleys_zpsa61a36df.jpg
We can have the covers hydro dipped in any finish if that helps?
 Share
