Garage Whifbitz Supra race car build
Paul Whiffin
  • Replies 1.3k
Posted Images
Looks like I'm going to be building a temporary engine to use for the next couple of months. I really want to use a different piston this time around as I've never been happy with the cylinder leakage we have found with the CP pistons. Heavy breathing at idle and leak down tests aren't that great, its never hindered the power engine makes though.
I'll be using Mahle Pro Series pistons http://whifbitzperformancetuning.co.uk/toyota-supra-engine-upgrades-mahle-p-2209.html with a stock crank for the moment as the pistons for the stroker kit are a special order item and wont be ready for about 6 weeks approx.
It'll be a bit of a backward step in bhp and torque but it will have to do for the moment, just have to wind the boost up some more. 2.2 bar and race fuel here we come for the Snetterton straights!
  • 3 weeks later...
Just finished screwing the rebuild engine together, all looking good, going to install it in the car tomorrow. I wonder what the difference is going to be now I'm using a stock crank again, be interesting as nothing else has changed.
I did a leak down test when I put the head on and I had the best results I've had on a built engine so far, 15% leak by on all cylinders. I put this down to the pistons/rings as I'm now using the Mahle Pro Series. Previously I was using CP pistons and we've never been able to get anywhere near this.
For anyone building a forged engine the Mahles are definately the way forward, proper quality pistons, one of the best you can get anywhere. And they are reasonably priced to, no more expensive than CP or JE, cant go wrong.
Anyway, hopefully I'll get it started up tomorrow, going to spend all day on it hopefully.
Do mahle offer there pro series in 86.5mm and with custom CR's paul??
:thumbs:
Good luck with finishing at all off, I hope you have more luck from now on.
