Jakes RZ Supra Build Project Thread. Officially Sponsored.
ripped_fear
 Share
  • Replies 870
So been rather busy yesterday, massive thank you to James aka theturtleshead for the help, there is no way I would have tackled this job on my own. The new Valve stem seals are in now but I'm waiting on some cam shaft oil seals and top water neck gasket to get it all finished up, as the old oil seals hadn't been fitted correctly and we didn't fancy refitting them. They should be here Tuesday so the plan is to get it finished Tuesday eve.
Here is a couple of snaps from the days work.
So as she is still in bits I took the opportunity to tidy a few bits up, got the bov sanded back and re polished a job that has been annoying me for a long time so glad that is done, re polished the top hard pipe, and gave the new water neck a quick going over. Once all those were done I repainted my PAS matt black as it was chipped in places and fitted my new painted pulley.
Finally I carried on with a carbon project I have been working on, something I wanted to try for a while, but the plan is to redo them in fibreglass and re-cover them in padding and suede. Made some progress on the shape. Quite happy with the results so far.
ah the good old rope trick.
I did this on my first supra, daunting but i got there in the end with limited spannering knowledge.
Nice job.
A fiddly job isn't it, you're a braver man than me I only did is as i had someone by my side who knew what they were doing.
He's a good egg that Jeffers bloke :thumbs: Glad you got it sorted Jake.
He is indeed, another example of the forums finest :D Cheers just hoping this cures all the issues if so I should have some exciting updates soon :D
So things have advanced! :)
As I'm sure most of you have seen I posted on FB thanking everyone individually but basically thanks to james (the turtles head) luke (attero) SRD and Wifbitz shes back together and looking great.
Car need a huge clean but here are some pictures of her back together. I have since taken it out on a run and it looks like it has cured all the smoke issues! :eyebrows:
Just sorting out an order now for the next round of parts/upgrades.
So just spent a small fortune on a lovely list for the car. Im prepping the car for single :)
-Genuine Toyota Crankshaft Pulley
-Genuine Toyota Crankshaft Pulley Bolt
-2x UK Spec (4 pot) Genuine Toyota front brake disks
-UK spec (4 pot) Genuine Toyota front brake pads
-2 x UK spec (4pot) front brake pad pin clips (Retaining Clips)
-4 x Front Pad Pins
-2x J-spec (1 pot) Genuine Toyota rear brake disks
-J-spec ( 1pot) Genuine Toyota rear brake pads
-Genuine Toyota oil pump
-Aux belt
-Genuine Toyota crank oil seal
-Aux belt tensioner pulley bearing
Edited by ripped_fear (see edit history)
Looking really good mate
What polishes do you use when using a machine polisher, and where's best place to get them from?
Thanks mate
The car this time round was done with the following
Shadow sport snow foam
Meguires nxt shampoo
Clayed with 3m clay and meguires rapid detailer
Formula clean de ironiser
3m 3 stage compound. Green Yellow and blue grades on a das6 pro
Shadow sport polish by hand
Poor boys black hole by hand
Soft 99 king of gloss wax seleant by hand
Absolutely stunning photos
Cheers mate
Looks beautiful mate, after seeing your video on facebook I ordered some of that polish :)
Cheers mate. Its a seleant wax though ;) on after polish and ideally top it off after for longevity.
Did this take 3 or 4 days? :D
Started at 9am ish and came in at 7-8pmish so safe to say it took a while haha
She's looking very clean Jake. :thumbs:
Thanks mate. We need to meet up again nothing local happening these days.
Looking really good and clean enough to lick. Surely you must be finished now?
If you want to sell the original air box and associated intakes plus tubing let me know.
Thanks mate shes never finished. Looking at ecus now, and doing loads of replacement bits to.keep her tip top.
Unfortunately i dont have the oem box mate. Otherwise it would be fitted lol
 Share
