Krimi's Supra PTE 6766 "THE PUNISHER" (DYNO TIME!)
Krimi
 Share
  • Replies 435
Posted Images
Good news,
Yesterday I cant sleep, I woke up at 4AM and going to garage to check the last thing.
Im thinking that its strange to blew two valve seats of 2 cilinders together, so I check If I introduce air in the 5th cylinder, and heard the air in the 4th cylinder. And YES!! I hear it, so its a blown headgasket, no valve seats, I going to repair the head and build it, new headgasket, ARP Studs, porting it, everything...
Good news for sure!!! :) :)
Good news,
I hope thats the case mate but toyota went to some lengths to not make the same mistakes with the mkiv as they did with the mkiii being known for headgasket failure.
If you have a blown your head gasket it will be the first I have heard in my 9 years of ownership. The head has to come off anyway so all will be revealed in the comming weeks, best of luck with it shame you never really got to use the set up to its potential
Its headgasket obviously! I apply air in the 5th cylinder and heard the air in the 4th, so probably blown studs or anything like this, after the head come off I'll see the real damages, with the camera inside the cylinders, there's no damages.
Thinking about purchasing a new intake manifold :)
  • 3 weeks later...
Waiting for a new order!!
Finally its a blown headgasket, I upload a picture when I going to the workshop, it blews a ring of the gasket between the 5th and 4th cylinder, the problem its a deformed headstud.
The new order consists:
Head:
- Brian Crower STD Size Valves
- Ferrea Valve Lockers
- Ferrea Valve Seals
- ARP 625+ Head Stud Kit
- OEM Headgasket
Block:
- ARP 625+ Main Stud Kit
- Titan Modified Oil Pump
- Toyota OEM Complete Engine Gasket Kit
-Gates Racing Timing Belt
- ACL Race Main Bearings
- ACL Race Rod Bearings
- ACL Thrust Washer
- AEM Exhaust Gas Temperature (EGT)
- Gates Serpentine Belt for ATI
- ATI Crank Pulley Harmonic Balancer
- Manley Extreme Duty 86.5mm Pistons 9.0:1 Compression
- Manley Upgraded Wrist Pins
- Manley H-Tuff H-Beam HD 625+ rod bolts
- Titan Motorsports Billet Main Caps
I'll remove the engine in two weeks! And the parts come in arround 15 days :)
Very happy with this purchase!
Edited by Krimi (see edit history)
Awesome stuff! Cannot wait to see (and hear) the end results :thumbs:
Thanks, can't wait too hahaha
Great spec Krimi. That's gonna be a monster.
I hope that! But for all the guys who has to paid in euros, look at the currencies, in 3 weeks that Im waiting to take off the head I lost arround 1100€!!
So start buying your parts, because the situarion its going to be worse!
Amazing build. doing the fuel lines was it quiet easy? Did you do it yourself or with your mechanic?
Amazing car great build good luck with the engine build going to be wild! :)
I purchase all the fuel lines from PHR, only need to cut an extra-long fuel line in the trunk, but easy job, in my past car I make my own fuel system home-made, with parts from Summit, and... Never again hahahaha
All the jobs in the car are doing by myself and my mechanic friend working together. :)
Thanks for you good luck wishes, obviously I need it!
No, the current exchange rate is really bad for us now.. :(
I haven`t visit your thread for a while, a lot have been happened since. Keep up the good work with the car mate! :thumbs:
Great to read you Mika!! Hope that you are enjoying my ex-engine!!
I'll send you a message soon friend ;)
  • 3 weeks later...
Updated mod list!
Engine/Ignition Components:
- Manley Heavy Duty Pistons 86,5mm 9.0:1
- Manley Upgraded Wrist pins
- Manley H-Tuff Rods (625+ Aged Rod bolts)
- ARP 625+ Main Studs
- ATI Damper Crank Pulley
- Titan Motorsports Oil Pump
- Titan Motorsports Main Caps
- ACL Main Bearings
- ACL Rod Bearings
- ACL Thrust Washer
- Gates-ATI Damper Aux-drive belt
- Gates racing timing belt
- PHR Modified timing gear
- PHR Tensioner Bracket
- TRD Engine Mounts
- TRD Gearbox Mount
- Toyota OEM Engine Gasket Kit
- Toyota OEM Water Pump
- Toyota OEM Power Steering Pump
- Chevy LQ9 Coilpacks
- Chevy Coil Clips & Wiring
- NGK BKR8EIX
Turbocharger/Exhaust Components:
- Precision 6766 0.96 A/R T4 Single Sroll
- Tial MV-R 44mm Wastegate
- PHR Manifold
- PHR Oil Drain Kit
- PHR Oil Feed Kit
- PHR 3" Downpipe
- PHR 4" Air Intake Kit
- PHR Screamer Pipe
- PHR Hot Side Intercooler Pipes
- RMM 3" Midpipe
- Whifbitz 3" Single Box Exhaust
Intake/Cooling:
- Whifbitz 3row FMIC
- Whifbitz Aluminium radiator
- Whifbitz Upper Radiator pipe
- OEM Fan Clutch
- OEM Fan Shroud
- RSP Turbo Blanket
- K&N idle valve filter
- APR Cooling plate
- 2.5" alluminium intercooler pipe to connect to the turbo
Fuel system:
- PHR STAGE 3 Fuel System
- PHR 17.5mm (-8AN) ID high-flow fuel rail kit
- PHR Dual Bosch Hanger
- PHR FPR Bracket
- Twin Bosch 044 fuel pumps
- Aeromotive fuel pressure regulator
- Liquid-filled fuel pressure gauge
- -6AN Stainless Steel braided feed lines
- -6AN Stainless Steel braided return line
- Hi-Flow Fuel Filters
- Injector Dynamics ID1000 Fuel Injectors
- Injector Dynamics quick release injector clips
Engine Management/Electronics:
- AEM EMS SERIES 2 Stand Alone
- AEM 5Bar MAP Sensor
- AEM IAT Sensor
- AEM Boost Control Solenoid
- AEM UEGO Wideband
- AEM Boost Gauge
- AEM EGT Sensor
Head:
- Ported and Polished
- GSC S1 Cams 269/269
- Brian Crower Adjustable Cam Gears
- Brian Crower Valvesprings Retainers
- Brian Crower STD size valves
- ARP 625+ Headstuds
- Toyota OEM Headgasket
Drivetrain:
- Toyota Clutch master cylinder
- Toyota Clutch slave cylinder
- TRD Big Case Diff
- ARP Flywheel bolts
- PHR Braided Clutch line
- PHR 3.5" Driveshaft
- Royal Purple Synchromax
- AP Engineering Solid Shifter bushings
- RPS Carbon/Carbon Twin Clutch
- OEM Getrag V160 Transmission
Chassis/Handling/Brakes:
- KW Variant 3 Coilovers
- Titan Sway Bars
- Hel Black Braided lines
- Motul RBF660 Fluid
- Performance Friction brake pads
Interior:
- OEM Seats Re-Trimmed in black leather
- OEM Black carpet
- OEM Floor carpets
- OEM Dash panels
- OEM Black leather back seats
- Seibon CF Door Panels
Exterior/Body:
- RAYS VOLK TE37 "18x10,5" "18x9,5" w/ Michelin PS3 235/40/18 & FEDERAL595RS-R 285/30/18
- RMM Front lip
- RMM Rear wing with carbon blade
- RMM Wing carbon side caps
- OEM USA bonnet (Optional: Top Secret bonnet)
- Rear fenders rolled
- 1998 OEM Headlights
- 1998 OEM Front indicators
- 1998 OEM Rear tail lights
Perfect setup matey.
I would go for 3" piping for the FMIC.
You won't be using E85 in the future?
Yes, 3" piping for FMIC its a good idea, I should consider that. , and for sure, new intake manifold, exhaust manifold, 4" Exhaust hahahaha but too much money in less than a year invested in the car and I have the feel that I've never fully enjoy my toy at 100%, you know?
And E85 its not available yet in my island, probably at the end of this year BP introduced some E85 for pump.
But for now only pump fuel :(
  • 4 weeks later...
Here its the full order :) With parts for some friends too!
All looks amazing!! The quality of the parts are awesome.
For the electronics, I contact with a guy from Spanish mainland, he do the electronics of some good race cars across europe, GT Series, LeMans Cars, Rallys, Hillclimbs...
And he comes here every 2 months to do electronics to rally cars, so that's going to be my tuner, his name is Gerard Murgadella, and his business name its GMC Sport, for those that wants to check his web or facebook profile!
 Share
