Tesla S first responder notes. 3000 gallons of water, 24 hours for battery fire...
Chris Wilson
 Share
3000 US gallons of water and up to 24 hours to extinguish a full
vehicle fire when the battery pack ignites! The UK sees 10.000
vehicle fires per annum, on average..
From the first responder / fire fighter notes from Tesla USA:
FIREFIGHTING USE WATER TO FIGHT A HIGH VOLTAGE BATTERY FIRE. If the
battery catches fire, is exposed to high heat, or is generating heat
or gases, use large amounts of water to cool the battery. It can take
approximately 3,000 gallons of water, applied directly to the battery,
to fully extinguish and cool down a battery fire; always establish or
request an additional water supply. If water is not immediately
available, use dry chemicals, CO2, foam, or another typical
fire-extinguishing agent to fight the fire until water is available.
Extinguish small fires that do not involve the high voltage battery
using typical vehicle firefighting procedures. During overhaul, do not
make contact with any high voltage components. Always use insulated
tools for overhaul. Heat and flames can compromise airbag inflators,
stored gas inflation cylinders, gas struts, and other components which
can result in an unexpected explosion. Perform an adequate knock down
before entering a hot zone. Battery fires can take up to 24 hours to
extinguish. Consider allowing the battery to burn while protecting
exposures. After all fire and smoke has visibly subsided, a thermal
imaging camera can be used to actively measure the temperature of the
high voltage battery and monitor the trend of heating or cooling.
There must not be fire, smoke, or heating present in the high voltage
battery for at least one hour before the vehicle can be released to
second responders (such as law enforcement, vehicle transporters,
etc.). The battery must be completely cooled before releasing the
vehicle to second responders or otherwise leaving the incident. Always
advise second responders that there is a risk of battery re-ignition.
Due to potential re-ignition, a Model S that has been involved in a
submersion, fire, or a collision that has compromised the high voltage
battery should be stored in an open area at least 50 ft (15 m) from
any exposure. Warning: When fire is involved, consider the entire
vehicle energized. Always wear full PPE, including a SCBA. HIGH
VOLTAGE BATTERY - FIRE DAMAGE A burning or heated battery releases
toxic vapors. These vapors may include volatile organic compounds,
hydrogen gas, carbon dioxide, carbon monoxide, soot, particulates
containing oxides of nickel, aluminum, lithium, copper, cobalt, and
hydrogen fluoride. Responders should always protect themselves with
full PPE, including a SCBA, and take appropriate measures to protect
civilians downwind from the incident. Use fog streams or
positive-pressure ventilation fans (PPV) to direct smoke and vapors.
The high voltage battery consists of lithium-ion cells. These cells
are considered dry cells. If damaged, only a small amount of fluid can
leak. Lithium-ion battery fluid is clear in color. The high voltage
battery, charge controller(s), DC-DC converter, and drive unit(s) are
liquid cooled with a typical glycol-based automotive coolant. If
damaged, this blue coolant can leak out of the high voltage battery. A
damaged high voltage battery can create rapid heating of the battery
cells. If you notice smoke coming from the high voltage battery,
assume that it is heating and take appropriate action as described in
Firefighting on page 22
Just looked what a fully specced Tesla X weighs. TWO AND A HALF TONNES. Bleedin' ridiculous. Not that a Nissan Leaf is any less ludicrous at 6.5kW charge current. Just like leaving a high power shower on full whack all night. The national grid is groaning as it is, if these POS become commonplace the grid will need uprating 100% Guess who'll pay for that...? When you can store the equivalent electrical energy of a gallon of petrol or diesel in a container of the same size, weight and cost, things may become more sensible to those who are not ardent and blinkered Greens ;)
Tesla S rated most unreliable car in the UK was what greeted me in this morning's paper. Can't buy parts from Tesla, they won't release service information, and they won't warranty new cars used for commercial purposes. Apparently they will also not release update info on cars they sell as selected used examples, so you have no paperwork to show if the myriad of "fixes" have been carried out whilst under warranty. And the company's owner seems to be going crackers... These things will be worth zilch when out of warranty. This You Tube video makes interesting viewing what a POS these things are!
^ All of his videos about his Tesla are interesting, it certainly opens up your eyes to potential ownership. My GP has just sold his Evo and ordered one of these.
At least he has deep pockets!
I suppose it's OK as GP's no longer make house calls, so it being in the dealership or on a trailer won't matter so much ;)
Thankfully I’ve not had to deal with any of these on fire yet, but I had heard they take forever to put out.
As much of a pain they seem to deal with in a fire scenario, I think I’d rather deal with one than an lpg conversion. I’ve seen some videos of how violently they can explode.
They might be as well developing a dam to go round the car and just submerge the battery pack like they used to do with acetylene cylinders.
I must admit I find Tesla as a company quite interesting. I find the thought of the car driving you home from the pub quite appealing.
Heard they would eventually like you to be able to summon the car from home. Handy for picking you up from the airport after holiday etc :)
Here are some reasons why people are buying these things at the moment:-
100% First Year Allowance for business owners available until April 2021
UK Plug-in Car Grant of £4,500
Reduced Employer Class 1A National Insurance Contributions (company cars only)
Exemption from London Congestion Charge
Salary sacrifice scheme available to business drivers
Significant Fuel Savings vs. a comparable Combustion Engine Car and no car fuel benefit for company cars
Significantly Reduced BiK Taxation for Company Car Drivers
Tesla Superchargers - enabling long-distance travel
Scottish customers can enjoy interest-free loans of up to £35,000 (personal) or up to £100,000 (business)
Basically, the UK taxpayer is subsidising them. I have no idea why the Scots should be allowed interest free loans.
If you've seen violent explosion of LPG converted car it means someone screwed up installation. If it is done right, release valve will burn all the gas without anything close to explosion.
I suppose that’s always going to be a potential problem with them isn’t it. Depends if the conversion was done properly or not.
I saw elon musks interview last night on Joe Rohan’s podcast on YouTube. He was interesting.
He said we are already cyborgs if you count how connected we are to our phones.
Beggars belief we're going this route, just take the dirty air from the cities and dump it in the country ( from the power stations for people that don't get it). Oh and imagine motorway carnage, tesla car fire M1 closed for a day....
Was that a joke?
Devils advocate (almost hate myself for saying it) but isn't the point that hypothetically if a new power station was built that ran on Hydrocarbons produced electricity for 'x' number of cars, then the electric cars could do more miles for the same amount of hydrocarbons burnt? So more efficient use of energy (IC engine is known to be poor) while at the same time the emissions from the one power station source can be more strictly controlled than the individual 'x' cars with 'maps', decats, or simply worn out.
So cleaner and more efficient in principle and then if you can increase the greener/low emission power sources you'll 'win' even more?
 Share
