SRD-1000S Oblivion Beast Project.
jazz1
Good clutch choice - I use the same one and love it! Much nicer to me than the HKS LA was!
I felt the clutch pedal at SRD on LUX Supra and felt like stock, compared to the other heavy clutch on another Supra. This is perfect for the power :cool:.
Haha, more a show car than a race drag car :).
I can see your point but I still feel it requires a blast up the strip. Doesn't need to be launched, just feather it off and then tear through the gears.
That will be my approach anyway lol.
  • 3 months later...
September 2017, Lee sent me some more updates and progress on the interior, plus the rear brake lines were finished. Also to add the polished brake master, I was contemplating chroming the parts but due to the risk of contamination (dipping process) I decided to be safe and stick with polish.
Edited by jazz1 (see edit history)
September 2017, I had also decided to change the Cam Pulleys to PHR from HKS, due to this mainly being a show car I wanted everything to match the engine theme. Previously I had purchased a set of OCD works timing cover, unfortunately they did not fit, Lee sent me some pictures of the damper touching and mentioned the only way they could work was to make a shim spacer. We also tried a stock damper with the same issue! So I decided to contact OCD works.
