Alex_GT Posted June 20, 2016 Share Posted June 20, 2016 I've been debating whether or not to do a basic BPU, with stock power the Supra seems a bit slow, but does the BPU make the car noticeably quicker? On paper it gives better numbers, but does that translate into the real world? Link to comment Share on other sites More sharing options...
mattdavies Posted June 20, 2016 Share Posted June 20, 2016 Yes! If you want a basic BPU, then a second de-cat and a cat back exhaust will give you a feel for it. You may hit fuel cut on this setup with motorway pulls but its easy enough to do Link to comment Share on other sites More sharing options...
ellis Posted June 20, 2016 Share Posted June 20, 2016 Yes. Quite a bit. Link to comment Share on other sites More sharing options...
Shane Posted June 20, 2016 Share Posted June 20, 2016 Running at 1.1-1.2 bar transforms the car imo. But be prepared to replace the coil pack connectors and possibly even the coilpacks if they are originals. That bit of extra load shows the otherwise unnoticeable breakdown of these components. Also be prepared for other weak spots to come to the surface, think it was Jasonr24 on here who recently went bpu and it pushed a turbo over the edge. But yes its great. Link to comment Share on other sites More sharing options...
Chris Bailey Posted June 20, 2016 Share Posted June 20, 2016 Or if you have deeper pockets go single turbo.... Link to comment Share on other sites More sharing options...
safcdixon Posted June 20, 2016 Share Posted June 20, 2016 Bit of a daft question isnt it? "Does 100+bhp make your car faster"? Yep Link to comment Share on other sites More sharing options...
Alex_GT Posted June 20, 2016 Author Share Posted June 20, 2016 The problem is I don't want to damage anything if the risk isn't worth it, is there any way of checking if the car would be vulnerable to failure, paticularly turbochargers? Bit of a daft question isnt it? "Does 100+bhp make your car faster"? Yep 100hp? I thought BPU was only good for around 50 extra horsepower? At 1.1/1.2 bar? Link to comment Share on other sites More sharing options...
monkey3 Posted June 20, 2016 Share Posted June 20, 2016 With BPU and a FMIC my '96 TT6 made 420 at 1.2 bar on the rolling road at a TVR vs Supra shootout at the place near Gatwick (the name escapes me). I reckon with a decent SMIC, like a CW one, it would make about the same. It was an absolute animal (not as much as the big singles but a handful none the less) and it really would play with the big boys and would quite happily spin the rear wheels in 4th it you gave it a boot-ful. I had it like that for about 7 years until my wife stacked it. But nothing really went wrong with it as I stayed on top of the services and replaced things like the coil pack connectors. It's a totally different car once BPU. But as others have said, if you're not prepared to deal with stress causing issues then don't push it too much. Has it done a load of miles? Link to comment Share on other sites More sharing options...
mattdavies Posted June 20, 2016 Share Posted June 20, 2016 Where do you live Alex, I am sure a member will take you for a ride in a BPU car Link to comment Share on other sites More sharing options...
gordy.r Posted June 21, 2016 Share Posted June 21, 2016 I run full BPU (FMIC, 1.2 bar, both decats, colder grade spark plugs, etc etc) and anyone who knows me knows I drive the car very 'spirited' and I can say I have had no issues whatsoever with reliability. Since being BPU the car has been around Scotland, up and down to England a few times, Over to Europe and will soon be doing its first track day. You will definitely notice a difference and I feel the second turbo comes on a lot more savage with the extra power. I also upgraded all the turbo pipes and rad etc when I went BPU as a lot of the parts are now 22+ years old and maintenance isn't a dirty word Do it, you won't regret it if you are feeling your stock power output is slow. Link to comment Share on other sites More sharing options...
Burna Posted June 21, 2016 Share Posted June 21, 2016 Wait until you try 1.42 bar Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 21, 2016 Share Posted June 21, 2016 These are old cars and of course making a pensioner run a mini marathon comes with risks. Have a full engine and oil service and a leak down test performed first, and fit a mechanical oil pressure gauge and a mechanical boost gauge so you can monitor the vitals. "Speed costs money, how fast can *YOU* afford to go?" was the plaque above the door at an engine tuner friend of mine's for many a year. A mangled piston and con rod hung beneath it.... Link to comment Share on other sites More sharing options...
a98pmalcolm Posted June 21, 2016 Share Posted June 21, 2016 Changes the car mate Link to comment Share on other sites More sharing options...
JasonR24 Posted June 21, 2016 Share Posted June 21, 2016 (edited) Running at 1.1-1.2 bar transforms the car imo. But be prepared to replace the coil pack connectors and possibly even the coilpacks if they are originals. That bit of extra load shows the otherwise unnoticeable breakdown of these components. Also be prepared for other weak spots to come to the surface, think it was Jasonr24 on here who recently went bpu and it pushed a turbo over the edge. But yes its great. Yea that was me. To be honest before going BPU I'd make sure the car is in tip top form to take the extra power even parts you may not even realise, for example there's a few hoses down the back of the engine, one is a vacuum feed for the second turbo to allow it to come online, mine had perished and split so I didn't have a second turbo the whole time I'd had the car. So definitely worth checking. Not to mention plugs, fuel filter etc. Then even after making sure the car was tip top, there's no telling at all when the stock turbos will go. I had the car 24 hours once it was all sorted. Running at 1.2 bar and the first turbo just let go. heard bits of it rattle out the exhaust! It's definitely worth doing but as above I'd get a decat and bigger exhaust first just to get a feel for it and see if any gremlins rear their head. Nothing worse than going full BPU straight away and having to get the turbos rebuilt Edited June 21, 2016 by JasonR24 (see edit history) Link to comment Share on other sites More sharing options...
gordy.r Posted June 21, 2016 Share Posted June 21, 2016 "Speed costs money, how fast can *YOU* afford to go?" Isn't this why God* created credit cards... *(insert whichever God/non god/deity/etc you believe in / follow) Link to comment Share on other sites More sharing options...
supra_ufo Posted June 21, 2016 Share Posted June 21, 2016 Its the best thing ever, just had my dynoed a few weeks ago, managed a [email protected], I have rebuilt J Spec turbos on mine. I should be able to push 1.4 BAR in mine just a bit worried about the ecu and injectors being stock so need an AFR gauge to monitor it all. Link to comment Share on other sites More sharing options...
JasonR24 Posted June 21, 2016 Share Posted June 21, 2016 Its the best thing ever, just had my dynoed a few weeks ago, managed a [email protected], I have rebuilt J Spec turbos on mine. I should be able to push 1.4 BAR in mine just a bit worried about the ecu and injectors being stock so need an AFR gauge to monitor it all. Is that 400 whp? Link to comment Share on other sites More sharing options...
supra_ufo Posted June 21, 2016 Share Posted June 21, 2016 Is that 400 whp? Fly wheel, torque figure was about 430 Link to comment Share on other sites More sharing options...
girth45 Posted June 21, 2016 Share Posted June 21, 2016 Mine is full bpu , i see the figures being quoted and accept different dynos give different results , mine achieved 354 bhp at the wheels and 350lbft torque , on two different dynos, so why so many achieving 400 bhp at the wheels! In answer to the question yes makes a great difference. Mine is a 97 tt vvti tiptronic auto. Link to comment Share on other sites More sharing options...
Dim Sum Posted June 21, 2016 Share Posted June 21, 2016 BPU is the way forward. Personally the BPU is should be how the car should of been released. Really transform the Supra:flame: Link to comment Share on other sites More sharing options...
Marty Posted June 21, 2016 Share Posted June 21, 2016 Performance difference is huge when you bpu the car, you'll be pleasantly surprised if it's speed you're after. Personally i prefer the drive of a catted supra though, mine feels more responsive throttle wise. Link to comment Share on other sites More sharing options...
alibabba Posted June 21, 2016 Share Posted June 21, 2016 Mine is full bpu , i see the figures being quoted and accept different dynos give different results , mine achieved 354 bhp at the wheels and 350lbft torque , on two different dynos, so why so many achieving 400 bhp at the wheels! In answer to the question yes makes a great difference. Mine is a 97 tt vvti tiptronic auto. Take it to the track. Mph doesn't lie A proper bpu spec runs +/- 120mph in the quarter, which is around 400whp depending the dyno you use. Mph might be a little lower 116-118mph using 98ron fuel. Link to comment Share on other sites More sharing options...
monkey3 Posted June 21, 2016 Share Posted June 21, 2016 Mine is full bpu , i see the figures being quoted and accept different dynos give different results , mine achieved 354 bhp at the wheels and 350lbft torque , on two different dynos, so why so many achieving 400 bhp at the wheels! In answer to the question yes makes a great difference. Mine is a 97 tt vvti tiptronic auto. Mine was 319.7 at the wheels, 418.2 at the FW and 352.1 torque somewhere or another. I just thought it was generally accepted to give the biggest figure in everything in life - "well it was that length at some point so that's the figure I'll quote". Also, wasn't the stock 280 / 320bhp at the FW? Link to comment Share on other sites More sharing options...
Scooter Posted June 21, 2016 Share Posted June 21, 2016 Performance difference is huge when you bpu the car, you'll be pleasantly surprised if it's speed you're after. Personally i prefer the drive of a catted supra though, mine feels more responsive throttle wise. I have two at present (one completely stock) so can drive them back to back and initially I was not that impressed by the bpu below 2nd turbo range (not sure it's worse (it was on mine due to a boost control issue) but no better), I have since done the first turbo mod to slightly up the boost and it feels much better from the bum dyno/responsiveness. The removal of the boost controller has meant the max boost is only 1 bar at present I need to open out my restrictor ring a smidge. Take it to the track. Mph doesn't lie A proper bpu spec runs +/- 120mph in the quarter, which is around 400whp depending the dyno you use. Mph might be a little lower 116-118mph using 98ron fuel. Flat out ie always in the 2nd turbo zone and yes you are right it's always pulling much harder than the stock one. Link to comment Share on other sites More sharing options...
Chris Bailey Posted June 21, 2016 Share Posted June 21, 2016 Mine was 319.7 at the wheels, 418.2 at the FW and 352.1 torque somewhere or another. I just thought it was generally accepted to give the biggest figure in everything in life - "well it was that length at some point so that's the figure I'll quote". Also, wasn't the stock 280 / 320bhp at the FW? How can you loose 100bhp from the flywheel to wheels? Doesnt sound like an accurate dyno. Link to comment Share on other sites More sharing options...
