Scott M's Supra Build Thread
Scott
  • Replies 787
Decided to do another bit of totting up...
Single List Update
Already on the car:
Greddy 4 Row FMIC
HKS SSQV2 Dump Valve
AFR Gauge
EGT Gauge
Boost Gauge
New Oil Pump
New Water pump
Front Crank Oil Seal
Bought (required Items):
Turbo Kit (BL 4" down/mid pipe, BL manifold, AEM intake, lines etc), 900cc Bosch Injectors, FIC rail, GSC Stg1 Cams - £1900
Precision 6765 Billet Turbo - £700
ASI Radiator - £100
Bosch Fuel Pump - £115
Titan/ATI Crank pulley - £250
Aeromotive FPR - £100
Aeromotive Fittings - £30
Fuel Lines - £240
HKS Ti 4" Exhaust System - £600
ECU Sensors, Solenoid, Lambda & Switches - £280
Oil Sandwich Plate - £26
OEM Manifold Nuts - £20
OEM Manifold Studs - £10
OEM Timing Belt - £31
OEM Aux belt - £40
Bought (Non-Required Items):
BC Stainless Springs & Retainers - £285
Power Steering Cooler Kit - £70
Spare Alternator - £105
Vernier Cam Pulleys - £80
Billet Timing Tensioner Bracket - £150
Oil Cooler Kit - £115
ARP Head Studs - £100
Nardi Style Deep Dish Wheel - £79
Steering Wheel Boss Adapter - £55
Steering Wheel Snap off Boss - £65
Short Shifter - £30
OEM Gasket Kit - £240
OEM Crank Pulley Bolt - £8
OEM Thermostat - £40
OEM Sump Bolt - £5
OEM Sump Washer - £1
Oil Pressure/Temp Gauge - £150
Spare Engine - £800
Still to Buy (Required):
Valve Shims - £100
Solaris ECU - £1600
RPS Carbon/Carbon Clutch - £1800
Still to Buy (Non-Required):
Wishbones - £400
New Wheels/Tyres - £2000
New headunit with all the toys - £1500
Refurb Kits for the Brakes - £unknown
Total spent so far £6820
Total still to go £7400 + refurb kits :faint:
Not really got a lot I can do at the moment as I'm waiting on shims to finalize the cams so I decided to turn my attention to the suspension. The suspension topmounts were sticking out like a sore thumb so I decided to paint them.
I'm actually pretty glad I took them off the car, they were starting to corrode already. So much for the nickel coating blah blah protection stuff lol.
Before
During
After
On the car
I'm liking that :)
I'm really happy with how they have came out. Just waiting on the collars to dry and then I'll be able to re-assemble :D
It was actually a daunting process, if they came out crap they would be on show constantly. Hopefully it'll last :)
Stole a couple of hours to get some things finished off...
I bought a stubby kit hub from JP. It really looked the part but unfortunately with the Supra, fitting it means you lose the horn (ooeerr). I didn't fancy that so I decided to fashion my own brush contact. Took a little bit of messing around but I'm pretty happy with the end result. I also fitted one of the ebay short quick release hubs, absolutely cracking bit of kit. Took a little bit of fettling due to me using 2 short kits but other than that it went on great. Feels absolutely rock solid when the wheel is on so I'm over the moon.
You can see the edge of the contact I made here...
I then finished off my coilovers, look pretty good if I don't say so myself. 2 down, 2 to go :)
Edited by Scott (see edit history)
Going well Scotty.
Not keen on the red myself. All the best.
Cheers mate. I wouldn't recommend putting any red in your car if you don't like it :D
This not finished yet ??
Waiting on your expertise and input mate.... what's the holdup?
just read from page one great project mate and some nice work keep it up .
Cheers mate. It's funny, when I first joined projects like this were rare. Now everyone is doing them and going to even more extremes like yourself and Hodge :D
Everything is down to slow motion at the moment. Waiting on Mr T delivering the linchpin shims :D
I loved the wheel I got but the one thing I could never live with was the strange, stick out like a sore thumb, yellow bit. Anyway, got a hold of some dye and went to town. Only done one coat so far, I'll get some more on it when it dries :)
Looking good..
The yellow was a bit of an eyesore..
I really didn't get it. Why on earth would you design a wheel to have red stitching with a yellow centre marker? I was between going black and going red, decided I would stick with the marker to see how it goes. Easy enough to change anyway :)
Good call, looks much better red...
WHats next on the build list?
Going well still I see!
Sorry if I've missed a post anywhere, have you thought about coming into the group buy on the S6? A good saving that's not going to come up often...
BTW chap PM me if there are any bigger parts you're getting from Mr T, my local is giving me a very good rate at the moment (for instance I got UK 4-pot calipers less than £150 each).
I can't bud, I've spent all the money I have at the moment unfortunately. I've actually got parts on hold till the end of the month for when I get paid so I'm actually into minus figures at the moment lol. I'm looking to buy the ECU around Christmastime unfortunately :(
Cheers for the heads up on your Toyota dealer. I think I've got everything I need now but if I do come across anything I'll definitely give you a shout.
Cheers :)
