BREAKING 2001 2JZ-GTE VVTI V161 single turbo
JackyBoi
 Share
I have decided to break my Supra so below is a list of items for sale. Please be patient with me in terms of updating this thread, replying to all PMs and photographing items! Just a few points first:
-All items are collection only unless otherwise stated. I might be able to arrange shipping for smaller items at the buyers’ expense but collection is always preferred
-Will accept bank transfer, PayPal (buyer must cover fees or send as gift) or cash on collection
-Nothing is guaranteed until money has been exchanged!
-Items will be stripped off the car over the next couple weeks so more pictures will follow
All parts have come off my J-spec 2001 2JZ-GTE VVTi V161 from factory. It was imported in 2014 with around 82,000km/51,000 miles and has since covered 14,783 miles in the UK, totalling 65,783 miles.
ENGINE & COMPONENTS
Stock 2JZ-GTE VVTi engine with all ancillaries, inlet manifold, throttle body etc. The following parts were installed as brand new in 2015:
- ARP headstuds
- 2 x -12AN breathers welded to cam covers
- Valve stem seals
- TRD engine mounts with brackets
- OEM front crank seal
- OEM crank pulley
- OEM cam cover seal & cam seals
- OEM timing belt
- Toyota water temp sensor
- Carbon spark plug cover
- NGK Iridium spark set grade 8
Issues: on last start-up (15/04/17) the engine started and warmed up fine but after 15 minutes started to idle very lumpy as if not running on all 6 cylinders, also there was a tapping noise coming from the lifters. I have videos of all this. This was when it sat for 4 months after my turbo failed. Will get these issues diagnosed before selling! Compression test on 30/08/16 showed 135psi in cylinders #1-3, 130psi in #4-5 and 128psi in #6.
PRICE: £1200 SOLD
Genuine HKS SSQV BOV: £100 SOLD
Whifbitz oil catch tank with -12AN breathers: £60 SOLD
Billet rad brackets: £30 SOLD
TRD oil filler cap: £50 SOLD
OEM radiator: £50 SOLD
TURBO & INDUCTION
BoostLabs Borg Warner S366 turbocharger:
- .91 A/R divided T4 housing
- 4” v-band welded onto turbine housing
- Higher flowing billet wheel
- Polished high flow compressor housing
- Has only covered less than 15 miles off boost on my car and 46 miles on the previous owners’ car who bought it as brand new
PRICE: £750 SOLD
Driftmotion -4AN oil feed with DEI heat sheath: £40 SOLD
Brand new PHR -10AN oil drain with DEI fire wrap 3000: £150 SOLD
Modified T4 twin scroll eBay manifold with DEI titanium heat wrap (braced, re-welded, removed slag): £100 SOLD
2 x Turbosmart 38mm Ultragates: £400 SOLD
4" polished intake pipe with genuine K&N air filter: £100 SOLD
4" v-band 316 stainless downpipe with DEI heat wrap: £100 SOLD
Whifbitz 4" FMIC and piping: £350 SOLD
2 x screamer pipes with DEI heat wrap: £40 SOLD
ECU & FUEL COMPONENTS
Syvecs S6GP ECU with loom adapter for VVTi + map calibration switch, knock sensor and Pierburg boost solenoid (installed by Whifbitz as brand new in 2015): £1200 SOLD
Whifbitz fuel rail + fitting kit with Asnu 850cc injectors: £650 SOLD
Walbro 450lph fuel pump: £60 SOLD
Fuelab 535 FPR with gauge: £80 SOLD
EXHAUST
4" custom made straight pipe from grade 316 stainless steel + rear box with a 4"-3" reducer: £500
DRIVETRAIN
Full V161 Getrag 6 speed conversion kit with 65,783 miles all in perfect working order. Kit includes:
- V161 6 speed gearbox works perfectly no crunching etc
- Spec Street Clutch Stage 2+
- Spec flywheel 6 speed
- Clutch pedal
- Mounts
- Shifter components
- Prop shaft
PRICE: £5500
(More photos in post #54)
SHELL & OTHER
2001 MKIV 2JZ-GTE TT6 VVTi Facelift - Japanese import with 65,783 miles. Some info:
- Toyota 040 super white from factory - some minor paint chips, two dents on front nearside fender, very slight rusting under rear nearside arch from when it was rolled (see pictures)
- BC racing coilovers
- All suspension components
- ‘UK’ spec front brake kit (big)
- ‘J-spec’ rear brake kit (small)
- All VIN numbers in place
- Chassis is rust free, fully under sealed
- New Toyota rear upper arm O/S fitted in 2015
- New Toyota rear anti roll bar links fitted in 2015
- No engine, gearbox, wheels or interior – only what’s listed above
PRICE: £4000
Facelift JDM headlights: £450 SOLD
Facelift JDM rear lights: £150 SOLD
TRD half-carbon spoiler: £220 SOLD
OEM front bumper – slightly chipped, one small scuff: £100 SOLD
RMM Type 2 polyurethane lip – chipped, needs respray: £50 SOLD
Modified Veilside spats (not currently fitted): £50 SOLD
Carbon fibre bonnet dampers: £40 SOLD
AEM AFR gauge with Bosch LSU 4.9 wideband sensor: £100 SOLD
Momo Mod 07 steering wheel with boss: £140 SOLD
Pioneer Double-Din Headunit: £200 SOLD
Vibe 6" speakers x2: £30 SOLD
Turbosmart 2 bar boost gauge: £20 SOLD
Recaro driver seat with rails: £250 - has one cigarette burn where your butt sits
OEM JDM passenger seat with rails - mint: £150
OEM rear seats: £200 SOLD
OEM facelift black front carpets: £100 SOLD
OEM facelift boot carpet: £100 SOLD
Black boot interior carpet: £100 SOLD
OEM flare: £20 SOLD
OEM spare wheel: £offers
Boot interior plastics: £120 SOLD
Rear speaker panels: £80 SOLD
OEM white electric folding mirrors: £100 SOLD
OEM driver & passenger door cards: £200 SOLD
Entire dashboard + panels: £400 SOLD
Heater control unit: £25 SOLD
Boot polystyrene left side: £20 SOLD
Boot polystyrene right side with tools: £50
Centre glove box unit: £50 SOLD
Due to huge interest in interior/exterior parts they will all be sold separate from the shell I just need some time to add them all into this list!
WHEELS
19" Work Emotion D9R - 19x10.5 et30 rear, 19x9.5 et38 front - some slight curbing on front wheels
Includes Michelin Pilot Super Sport rear tyres in 295/35/19 and Pirelli P-zero front tyres in 255/35/19 – both have excellent tread left
PRICE: £1200
  • Replies 74
Sorry guys my inbox is blowing up not helped by the fact it isn't telling me if a message has actually sent or not. Still lots of parts to add to this list
- - - Updated - - -
What diff is in it?
It's a small case open diff, A02A I think
I'll take the ashtray please mate if you don't mind posting it with it being small?
PM me a price, cheers.
Ashtray?
EDIT FTW STEVO!
Someone has asked about the manual gear surround, let me check if they meant with or without the ashtray
Front wings?
Will stay with shell until further notice :)
Front and Rear subframes please mate if you don't sell as complete shell.
/QUOTE]
Okay mate
Whifbitz oil catch tank with -12AN breathers. Will it be sold with all the fittings and hoses? if yes I'm interested
Sold with both braided lines and AN fittings
 Share
