Homer 69 Posted December 15, 2006 Share Posted December 15, 2006 Name: BPU Also known as: Basic Performance Upgrade Full decat What is it? BPU stands for “Basic Performance Upgrade”, a term coined by US firm Suprastore for a basic upgrade package for the TT Supra. BPU is essentially what other marques refer to as "Stage 1” engine modification. The BPU upgrades allow the engine to produce more power by raising the boost pressure the turbos produce. In stock form, the TT produces 0.76bar (11psi), however this can be raised; it's generally accepted that the stock ceramic Jspec turbos will handle 1.2bar (17.4psi). The Export spec (UK/Euro/US) has steel blades so will, in general, survive at higher boost pressures. 1.4bar (20.3psi) is not unheard of. 1.2bar is the "accepted" safe limit with regards to a) detonation, b) actually getting more power, and c) some level of longevity. It's also accepted that you're taking an allbeit very small risk each time you use full boost. 1.2 bar is generally safe, but at 1.4 you're pushing your luck. There are limitations with pressures above 1.2bar, the turbos are already outside of their efficiency range and the additional heat generated will raise the intake air temperature considerably – thus negating the effect of increased boost pressure. In both Jspec and export spec, BPU will raise engine power to around 400bhp. Not only will it release more power but it allows much quicker turbo spool-up, which vastly increases drivability. How it works In stock form, the boost pressure the turbos produce is controlled by back pressure in the exhaust system (I.e. highly restrictive catalytic converters and exhaust system). There are two approaches to BPU dependant on the model of car; as such the next section is split between Jspec and Export spec: Fundamentals of BPU Jspec: To raise boost beyond the stock level the restrictive catalytic converters are removed, thus allowing the turbos to spin faster and produce more boost pressure. There is a down side to this. With both cats removed the turbos will in fact over speed far past their safe limit and reach over 1.6bar (23.2psi). This is due to the small size of the jspec wastegate which cannot cope with the increase in exhaust gasses. At these pressures the ceramic blades in the turbo can become detached from the shaft and therefore cause catastrophic failure of the turbo. In order to add some restriction back in to the exhaust a restrictor ring is added to the exhaust system. A restrictor ring is simply a metal plate that fits normally between either between the 1st and 2nd decat pipes, or the 2nd decat and cat-back. The centre of the restrictor is drilled out to a smaller diameter than the exhaust itself (normally around 2inches). A properly sized restrictor should bring the maximum boost pressure down to 1.2 bar or less. UK/Euro/US (Export) spec: To raise boost beyond the stock level the restrictive catalytic converters are removed, thus allowing the turbos to spin faster and produce more boost pressure. Different to the jspec, the export spec has a larger wastegate which can handle the increase in exhaust gasses. Therefore boost pressure will be maintained at only slightly above stock levels, typically 0.85bar (12.3psi). In order to raise this further it is necessary to install a Boost controller to change the way in which the wastegate opens. A restrictor ring is not required on the export spec Note: On both models it’s possible to raise the boost with simply adding a Boost controller or Bleed valve; however this is not recommended since the huge resistance of the cats is still in place. This will result in significant extra heat being generated in the manifold and could cause serious engine damage due to raised exhaust gas temperatures. Parts required: Obviously all that’s needed to raise the boost pressure is a double decat & restrictor ring (Jspec) or double decat & boost controller (export spec). However, it will not work without further modifications. The following will be required in both models: 1) Aftermarket cat-back exhaust The stock cat back (the pipe after the 2nd decat pipe) is extremely restrictive. In order to allow a good free flowing system this needs to be replaced with an aftermarket system. There are a huge amount of systems available, but any good quality aftermarket system will be suitable for a BPU level of modification. 2) Fuel cut defender The stock ecu will initiate fuel cut when boost pressure reaches 1 bar for a 3 second period. In order to stop this, a device is needed in order to trick the ecu into thinking the boost pressure is lower. (See quick link for further details) 3) Updated fuel pump The stock fuel pump in the jspecs is not considered suitable for BPU level power, the one in the export spec is higher specification and will be suitable. However as many of these cars are approaching 13 years old it should be standard practice to replace the fuel pump. The Walbro pump is commonly used, however the standard pump that comes with the export spec is a better specification and has quieter operation (though considerably more costly). 4) Colder grade spark plug With an increase in boost, a ‘colder’ grade plug is required with a closer gap. There are two basic options: - Iridium IK22 plugs - NGK BCPR7ES The iridium’s will last longer (most people get >10k miles) but typically cost £60 a set The NGK’s need replacing around 3k miles, but cost £14 a set Recommended, but non-essential parts: That’s it for the required parts, though there are two items which are highly recommended to ensure you can monitor the health of your engine: 1) Boost gauge A simple electronic or mechanical boost gauge can be mounted in the dash to view the boost pressure. An electronic boost gauge is recommend as most will come with a peak hold or even playback function, thus allowing easier monitoring of maximum pressures 2) AFR gauge Also known as Air/Fuel ratio. This has a wideband O2 sensor mounted in the 2nd decat which measures the air/fuel mixture of the exhaust gases. This is very important to monitor, otherwise you won't know if the air/fuel ratio runs lean under high boost (and therefore result in piston meltdown). Though it won’t allow adjustment, it will warn you that something is not right if it does go lean. 3) EGT gauge (optional to AFR gauge) Also known as Exhaust Gas Temperature. This has a temperature probe fitted into one of the exhaust runners (as close to the cylinder as possible). It performs basically the same function as the AFR gauge by monitoring the condition of the exhaust gases. High temps (sensor mounted post turbo 950degrees is dodgy, >1000degrees is a very bad thing!) will likely result in engine damage due to lean mixture. However there are some cons when comparing this to the afr gauge: - It is much slower to react - Failure of the temp probe (i.e disintegration) will result in the particles entering the turbos potentially causing failure - The exhaust runner requires drilling and tapping which can result in swarf entering the manifold before the turbo. This could result in damage to the turbo blades. A safer place to tap the probe is in the exhaust or downpipe after the turbo. It will stop the risk of swarf ending up in the turbo and turbo damage in the event of probe failure. There is a downside - Installing it post-turbo introduces such a big and variable heatsink into the equation it's pretty much useless. People take anything from 100 to 250degC off the aforementioned maximum, meaning that your gauge could read 800degC and mean anything from imminent meltdown to running nicely. No-one has put an EGT sensor before and after the turbo and datalogged the variance so it's 100% guesswork, and that's the last thing you want on the ragged edge. 4) Intercooler A replacement or aftermarket intercooler isn't required, however you need to ensure your current intercooler is in good condition and allows smooth airflow though the core. Many of the stock IC's on older cars are now in very poor condition and suffer from corroded fins, if yours is like this it should be replaced prior to going bpu. Quote Link to post Share on other sites
Rayman 11 Posted January 15, 2007 Share Posted January 15, 2007 Awesome thread this, makes BPU really easy to understand, is there not a typo under colder plugs, is it not Ik24 that are used for BPU rather than Ik22. It probably wont make much difference but i just thought thats what was generally recommended? Quote Link to post Share on other sites
Andyhannah 87 Posted January 16, 2007 Share Posted January 16, 2007 Very informative that darryl,very useful. Quote Link to post Share on other sites
Jake 24 Posted January 16, 2007 Share Posted January 16, 2007 is there not a typo under colder plugs, is it not Ik24 that are used for BPU rather than Ik22.No I think it's correct. IK22 are more than adequate for BPU. Running too cool a plug offers no benefit and they are more prone to fouling. Quote Link to post Share on other sites
carl0s 16 Posted January 16, 2007 Share Posted January 16, 2007 3) Updated fuel pump however the Bosch 044 which comes with the export spec is a better specification and has quieter operation (though considerably more costly). Is this definately correct? It's just that I'm trying to find more info on the 044 and I can see that some people are using it but there's a common conception that this pump doesn't do very well at lifting fuel out of the tank. So, is this the pump that the UK cars have fitted as standard then? Quote Link to post Share on other sites
Sheefa 30 Posted January 18, 2007 Share Posted January 18, 2007 Best guide I've read so far. Great job mate! Quote Link to post Share on other sites
carl0s 16 Posted February 19, 2007 Share Posted February 19, 2007 In answer to my own question.. The stock UK pump is most definitely NOT a Bosch 044, or anything like it. It's not even made by Bosch at all. So, any chance of correcting the article? Quote Link to post Share on other sites
Glosphil 2 Posted February 19, 2007 Share Posted February 19, 2007 Well done mate, wish you'd of written that when I joined lol Quote Link to post Share on other sites
carl0s 16 Posted February 19, 2007 Share Posted February 19, 2007 FFS, everytime I point out this mistake, someone replies in front with a "great post!" thing, meaning I don't get noticed grrr. Quote Link to post Share on other sites
RobSheffield 86 Posted February 19, 2007 Share Posted February 19, 2007 FFS, everytime I point out this mistake, someone replies in front with a "great post!" thing, meaning I don't get noticed grrr. Great post Quote Link to post Share on other sites
Homer 69 Posted February 19, 2007 Author Share Posted February 19, 2007 In answer to my own question.. So, any chance of correcting the article? Cheers Carlos, I searched high and low and couldn't confirm or disprove the Export pump spec so left it as it was. Seeing as it's CW who posted that I'll correct the article Is anyone able to supply the model and type of pump used on the export spec? Quote Link to post Share on other sites
SupraStar 3000 16 Posted February 19, 2007 Share Posted February 19, 2007 great post. thanks mate Quote Link to post Share on other sites
carl0s 16 Posted February 20, 2007 Share Posted February 20, 2007 Cheers Carlos, I searched high and low and couldn't confirm or disprove the Export pump spec so left it as it was. Seeing as it's CW who posted that I'll correct the article Is anyone able to supply the model and type of pump used on the export spec? Everything I've found so far just says "Nippon", (that being Denso, right?) I think I have a part number too: 23221-46110 Quote Link to post Share on other sites
carl0s 16 Posted February 20, 2007 Share Posted February 20, 2007 It is a great post, btw. Thanks Homer Quote Link to post Share on other sites
Omlaysause 4 Posted March 16, 2007 Share Posted March 16, 2007 Perfect .. this is exactly what I'm looking to do with mine, nothing radical but a bit more Oomph!! So can someone enlighten to an approx cost for the BPU stuff. I already have a Cat back exhaust although I don't know if it has a restrictor ring in it. Everything else as far as I know is stock other than an induction kit, which doesn't do anything. I'm near Edinburgh and wondered if anyone know's who could do the work. I've spoken to TDR but his Dad's unfortunately a bit busy just now Quote Link to post Share on other sites
Homer 69 Posted March 18, 2007 Author Share Posted March 18, 2007 So can someone enlighten to an approx cost for the BPU stuff. I already have a Cat back exhaust although I don't know if it has a restrictor ring in it. Everything else as far as I know is stock other than an induction kit, which doesn't do anything. I'm near Edinburgh and wondered if anyone know's who could do the work. I've spoken to TDR but his Dad's unfortunately a bit busy just now This isnn't really the right place to ask since its a tech discussion I recommend you contact some of our traders and look for the best deal: Envy, Miami-GT, Whifbitz, MVP, PHR - in no particular order! Quote Link to post Share on other sites
tDR 6 Posted March 18, 2007 Share Posted March 18, 2007 Homer - on the spark plug recommendation. BKR7E are the ones to recommend by default NGK wise. These are ISO fitment as per the OEM plugs. The BCPR7ES will work but they're very slightly longer from the base of the insulator to the tip where the coil pack seats, since they are the older JSO fitment standard. In practice these are a good bet when you have old and worn coil packs and are suffering misfires as a result - the snugger fit helps. Also, perhaps mention the NGKs should be gapped at 0.9mm at BPU level and that iridium plugs come pre-gapped at a smaller gap than stock so don't touch as you risk damaging their fragile very thin centre electrodes if you try to gap them. Also there is no mention that IK22's are made by Denso. Otherwise - excellent article! Cheers, Brian. Quote Link to post Share on other sites
carl0s 16 Posted March 18, 2007 Share Posted March 18, 2007 Homer - on the spark plug recommendation. BKR7E are the ones to recommend by default NGK wise. These are ISO fitment as per the OEM plugs. The BCPR7ES will work but they're very slightly longer from the base of the insulator to the tip where the coil pack seats, since they are the older JSO fitment standard. In practice these are a good bet when you have old and worn coil packs and are suffering misfires as a result - the snugger fit helps. Also, perhaps mention the NGKs should be gapped at 0.9mm at BPU level and that iridium plugs come pre-gapped at a smaller gap than stock so don't touch as you risk damaging their fragile very thin centre electrodes if you try to gap them. Also there is no mention that IK22's are made by Denso. Otherwise - excellent article! Cheers, Brian. How about BKR7E-VX? I've always just fitted them - it says not to regap them on the box, and I haven't actually checked them with a feeler gauge. All OK? (car not gone bang yet anyway.. ) Quote Link to post Share on other sites
Guest nick_t Posted March 18, 2007 Share Posted March 18, 2007 how much difference does bpu make with regards performance and number of horses cheers Quote Link to post Share on other sites
tDR 6 Posted March 18, 2007 Share Posted March 18, 2007 How about BKR7E-VX? I've always just fitted them - it says not to regap them on the box, and I haven't actually checked them with a feeler gauge. All OK? (car not gone bang yet anyway.. ) BKR7EVX are a discontinued line - these were platinum plugs (extended service intervals) at around 4 times the price of the copper BKR7E's. There isn't a problem gapping platinum plugs as far as I'm aware so always worth a check with a set of feeler gauges although I suspect they will be around 0.8mm from the factory given the print on the box. They are the grade 7 heat range still so will be fine at BPU level since they are also one heat range colder than stock but for me I've never had issues with the good old NGK coppers so why change when they're reliable and low cost? The VX have been replaced by the iridium IX range by the way, at similar cost. Cheers, Brian. Quote Link to post Share on other sites
tDR 6 Posted March 18, 2007 Share Posted March 18, 2007 how much difference does bpu make with regards performance and number of horses cheers You awaken the beast and go from around 320bhp to around 390bhp. Cheers, Brian. Quote Link to post Share on other sites
carl0s 16 Posted March 18, 2007 Share Posted March 18, 2007 BKR7EVX are a discontinued line - these were platinum plugs (extended service intervals) at around 4 times the price of the copper BKR7E's. There isn't a problem gapping platinum plugs as far as I'm aware so always worth a check with a set of feeler gauges although I suspect they will be around 0.8mm from the factory given the print on the box. They are the grade 7 heat range still so will be fine at BPU level since they are also one heat range colder than stock but for me I've never had issues with the good old NGK coppers so why change when they're reliable and low cost? The VX have been replaced by the iridium IX range by the way, at similar cost. Cheers, Brian. I didn't know that, thanks. I bought my last set of BKR7EVXs about four weeks ago, so I take it the discontinuation is a fairly recent thing? They were £4.54 + vat each from my local Partco. Quote Link to post Share on other sites
AndyT 23 Posted April 5, 2007 Share Posted April 5, 2007 Very nice sir. Thanks. I know what to look for, ask about to find out what's been done to the one I'm getting now. [GRIN][/GRIN] Quote Link to post Share on other sites
TonyP 1 Posted April 5, 2007 Share Posted April 5, 2007 Great post. Even I understood it! Quote Link to post Share on other sites
Guest johnny Posted April 8, 2007 Share Posted April 8, 2007 that was good.this is my first supra its standard. dont think it that quick but will get a few mods and get it sorted... have a six speed box ready to go in to it soon Quote Link to post Share on other sites
