Single turbo reccomendations
Tsia
 Share
  • Replies 158
Posted Images
We always you the 1.00AR divided on pretty much all the precision turbos
After a chat with Ryan when I was putting together my current setup, he advised me against the 1.15 AR I was initially thinking about.
The tests SP did in the US on a built 3.0 showed better result on the 0.84 AR that the 0.96 (open housing).
I haven't seen the dyno sheets of the divided housings yet, but I suppose the 1.00 would be the max to use on a 3.0.
I'd go tubular just because of the better sounding exhaust note. Also with a tubular manifold you can get it true divided setup. Log manifolds are open.
+1
Plus, tubular manifolds are better for pump fuel ; with cast manifolds, EGT's will go a lot higher at higher boost levels compared to tubular manifolds.
Cast manifold are ok at high boost if you run ethanol.
Edited by Luxluc (see edit history)
I've gone with a 1.00AR divided housing for my 6870 (for built 3.0l) on Lee's and Reid's recommendation.
I have gone with the .84 so would be interesting to compare the spool and power difference at same boost levels. Did you get the SP or HP housing?
 Share
