Rich.2211 Posted January 27, 2015 Share Posted January 27, 2015 Unless I'm missing something obvious or misread, the lack of thermostat won't be the cause of it overheating unfortunately. Link to comment Share on other sites More sharing options...
T2 MSW Posted January 27, 2015 Author Share Posted January 27, 2015 Unless I'm missing something obvious or misread, the lack of thermostat won't be the cause of it overheating unfortunately. Really? having no thermostat would not direct water correctly round the waterways? Link to comment Share on other sites More sharing options...
Rich.2211 Posted January 27, 2015 Share Posted January 27, 2015 (edited) Really? having no thermostat would not direct water correctly round the waterways? The function of the thermostat (when one is fitted I might add) is to prevent the flow of coolant to the radiator until the engine is warmed up. The purpose being to get the engine up to temperature as quickly as possible, not to cool the engine down as is the common misconception. Having no thermostat would just mean the car takes longer to get up to temperature as coolant will be flowing through the rad straight from start up. Edited January 27, 2015 by Rich.2211 (see edit history) Link to comment Share on other sites More sharing options...
T2 MSW Posted January 27, 2015 Author Share Posted January 27, 2015 Well I'm unsure what else it can be. There is no airlock. The water is moved round the system. only other thing it could be is damage to the water pump or the fans arnt pulling air through the radiator. What at I dont understand is stationary that temp stays dead on 89-90 degrees. It's inly when driving it goes up and this is not on boost either. Link to comment Share on other sites More sharing options...
Rich.2211 Posted January 27, 2015 Share Posted January 27, 2015 Daft question maybe, the electric fan(s) are spinning the right way aren't they? Link to comment Share on other sites More sharing options...
T2 MSW Posted January 27, 2015 Author Share Posted January 27, 2015 Yes if you put your hand behind them they are pushing air into the engine bay therefore pulling it through the rad Link to comment Share on other sites More sharing options...
jay200bhp Posted January 27, 2015 Share Posted January 27, 2015 brake bracket thingys will be with you tomorrow by 1pm Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 28, 2015 Share Posted January 28, 2015 Those shrouds are crap, when stationary they are great as they allow the fans to suck air through the two fan aperatures. However once moving they block off a large amount of the rear surface area at the back of the rad. I'd suggest that's your problem. With a large FMIC and no ducting it will only compound the issue. Link to comment Share on other sites More sharing options...
T2 MSW Posted January 28, 2015 Author Share Posted January 28, 2015 brake bracket thingys will be with you tomorrow by 1pm Your a legend thank you very much. Link to comment Share on other sites More sharing options...
supra matt Posted January 28, 2015 Share Posted January 28, 2015 (edited) Maybe a silly question but its not just a duff temp sensor is it.? And as said if it has no state it will take ages to heat up hence not much heat in coming out the heater in the car I would also make sure your rad cap fits right as will also cause this as the system is designed to be pressureisd , also what coolant are you running at the moment mate? , Edited January 28, 2015 by supra matt (see edit history) Link to comment Share on other sites More sharing options...
T2 MSW Posted January 28, 2015 Author Share Posted January 28, 2015 Rad cap is new and tight. Coolant is some blue mix stuff. Going to get toyota stuff today. Link to comment Share on other sites More sharing options...
T2 MSW Posted January 28, 2015 Author Share Posted January 28, 2015 (edited) So looks like the cooling issue is down to a failed head gasket. So disappointed its unreal and right now no idea what to do with it. Ive ordered a block tester to verify what I thinks wrong with it. If that shows up gasses in the water ill pull the head and have a look then decide what to do with it Oil cap was just getting worse and worse when the new coolant was put in today. Turned the car off before it got anywhere near temp as oil cap was just full of white gunk. Edited January 28, 2015 by T2 MSW (see edit history) Link to comment Share on other sites More sharing options...
Ian Ian Posted January 28, 2015 Share Posted January 28, 2015 Ouch gutted for you Mike, the head gasket didn't last long im assuming it was a heavy duty one too Fingers crossed you can get it fixed easy enough Cheers -Ian- Link to comment Share on other sites More sharing options...
T2 MSW Posted January 28, 2015 Author Share Posted January 28, 2015 Ouch gutted for you Mike, the head gasket didn't last long im assuming it was a heavy duty one too Fingers crossed you can get it fixed easy enough Cheers -Ian- Stock toyota one mate. There really should be no reason to use anything else. I can only think one of the surfaces was not true, even though I had the head skimmed or its overheated and warped the head. Not an easy fix and I'm not sure I can be bothered Link to comment Share on other sites More sharing options...
Supraleeturbo Posted January 29, 2015 Share Posted January 29, 2015 Gutted for you mate but if funds are there then fix her and you will find the love again Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 29, 2015 Share Posted January 29, 2015 Stock toyota one mate. There really should be no reason to use anything else. I can only think one of the surfaces was not true, even though I had the head skimmed or its overheated and warped the head. Not an easy fix and I'm not sure I can be bothered What head studs did you put in, and is it a standard longblock? Link to comment Share on other sites More sharing options...
mellonman Posted January 29, 2015 Share Posted January 29, 2015 arh mate that is a shame , hope its not as bad as you think Link to comment Share on other sites More sharing options...
T2 MSW Posted January 29, 2015 Author Share Posted January 29, 2015 Standard long block yes and head studs were L19s Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 29, 2015 Share Posted January 29, 2015 Standard long block yes and head studs were L19s Just wondering three things. Do you know the torque wrench you used was calibrated correctly, and what torque did you do them up to? in addition, although I'm not sure about the L19's, some ARP head studs come with smaller than standard head washers. The smaller washers can dig into the head and cause the head to lift under high boost. I have an ARP head kit in the garage at the moment which definitely has the smaller washers, hence I'll be re-using my stock washers when I fit them. Worth a check! Link to comment Share on other sites More sharing options...
T2 MSW Posted January 29, 2015 Author Share Posted January 29, 2015 (edited) Not calibrated no, however I used 2 wretches to check them. think they were torqued in order through 30, 60 then 90 but it's in this thread somewhere so I'll check. Do do you know the diameter of the stock washers and I'll check when I decide what I'm doing with it? edit - just checked the above is correct in ft/lbs Edited January 29, 2015 by T2 MSW (see edit history) Link to comment Share on other sites More sharing options...
JamieP Posted January 29, 2015 Share Posted January 29, 2015 It's been a long road, you can't give up now Mike. Link to comment Share on other sites More sharing options...
T2 MSW Posted January 29, 2015 Author Share Posted January 29, 2015 It's been a long road, you can't give up now Mike. i know, just lost the motivation for it. It's either getting broken after I find what's wrong with it or a built motor. Got to stop pricing up parts in my head Link to comment Share on other sites More sharing options...
supra matt Posted January 29, 2015 Share Posted January 29, 2015 Sorry to see this mate but if it was head gasket would it not of been picked up on the dyno at your power ? you need to get a leak down test done and also do a compression test . Link to comment Share on other sites More sharing options...
T2 MSW Posted January 29, 2015 Author Share Posted January 29, 2015 Sorry to see this mate but if it was head gasket would it not of been picked up on the dyno at your power ? you need to get a leak down test done and also do a compression test . Yeah waiting for a block tester and then I'm going to do tests and take it from there. Link to comment Share on other sites More sharing options...
supra matt Posted January 29, 2015 Share Posted January 29, 2015 Fingers crossed its nothing to major mate, out of interest what have you done with the water ways on the inlet side of the head,? Link to comment Share on other sites More sharing options...
