teddan Posted April 21, 2012 Share Posted April 21, 2012 (edited) I am going to built a 1000hp single turbo. So this will be my building thread. I bought the car last summer. Last owner was a truckmehnical guy but nothing was done properly and it was not finlized. The cables for the fuelpump was just scaled and wiring togheter so the fuelpump was running randomly it was also running on the first ignitionstage...not good. The car is a 6speed with a greddy trust kit but some parts will be remomved because we are going for 1000hp:p -------------------------------------------------------------------------------------------------------------------------------------- NEW SETUP 2015 Engine Cp pistons (20 over) Upgraded wristpins (0.250 wall thickness) BC sportman rods with ARP625+ (Should be same as Brian Crower Pro Series Rods) Titan billet main caps with ARP bolts ACL Race bearings Main L19 bolts Brian Crowe 280 Race Cams Brian Crowe Springs and Retainers kit Titan Cam Gears Welded timing gear Billet Tensioner Greddy Timing belt VAG ignition coils 1.5mmm cometic headgasket Fuel Setup Bosch 2200cc Dual 6AN PTFE Feeding lines 6AN Retur line 2xWalbro 450 LPH Aeromotive fuelpressure regulator Flexi fluel sensor Engine mangement MaxxEcu Plug In Google Nexus7 GEN2 tablet to MaxxECU MaxxECU PWM module Ethanol sensor for fuel temperature and ethanol content Exhuast and Turbo Precision GT42-7675R 2x44mm TIAL wastegates, 1bar springs Custom made exhaust manifold in stainless steel. 4 Inch SS downpipe and midepipe Garage Whifbitz 4" S/S Supra Exhaust Twin Box Big KN air filter Transmission Clutch RPS Billet Carbon Triple Disc V160 gearbox Torsen LSD TRD 6 Speed Gearbox Mount 3.5" driveshaftshop prop -------------------------------------------------------------------------------------------------------------------------------------- 2012 spec It will be running on E85 Setup for the moment Engine mangement Aem v1 for the moment Trust intercooler Wilsson intake 3,5 HKS fulrail HKS DLI Trust Turbo 78 Clutch RPS billet Parts orderd Titan Motorsports Dampend 2JZ-GTE Crank Pulley Titan Motorsports 2JZ Cam Gears Brian Crower 2JZGTE CAMSHAFTS Race 280 BC Springs and Retainers for the 2jz (B0300) ARP Main Stud Kit For MKIV Clevite 77 Engine Bearing Package for the 2JZ Supra CP Pistons for Toyota Supra MK4 (20 over) Brian Crower 2JZGE Sportsman Connecting Rods Toyota OEM Supra MKIV (MK4) 2jza-gte Engine Gsket/Rebuild Kit Greddy Timing belt Running belt Part to order ARP L19 main caps?? Turbo pictures from the pick up the start of the project. Engine on the way out so close.... Some part home Edited April 11, 2016 by teddan new spec! (see edit history) Link to comment Share on other sites More sharing options...
tkddav3 Posted April 21, 2012 Share Posted April 21, 2012 sounds like an epic build mate Link to comment Share on other sites More sharing options...
Westy Posted April 21, 2012 Share Posted April 21, 2012 Looking forward to seeing your progress! Link to comment Share on other sites More sharing options...
FOSTA Posted April 21, 2012 Share Posted April 21, 2012 I'm liking this Subscribed! Link to comment Share on other sites More sharing options...
Ricky49 Posted April 21, 2012 Share Posted April 21, 2012 All the best with it dude Link to comment Share on other sites More sharing options...
teddan Posted April 21, 2012 Author Share Posted April 21, 2012 Going to send the pistons to the moon:sos: Next stage will be to drill the block for my new pistons. It will take some weeks... Link to comment Share on other sites More sharing options...
teddan Posted April 22, 2012 Author Share Posted April 22, 2012 (edited) Seems that the rods are weight in allready? Edited April 22, 2012 by teddan (see edit history) Link to comment Share on other sites More sharing options...
JamieP Posted April 22, 2012 Share Posted April 22, 2012 Good luck with it. Best add some brakes to that list, look like j-specs in the picture? If you want any chance of laying down a 1000bhp on the street you are going to need a serious wheel/tyre setup. I know of a very nice turbo for sale Link to comment Share on other sites More sharing options...
Ricky49 Posted April 22, 2012 Share Posted April 22, 2012 I know of a very nice turbo for sale Cheers mate had no interest in my 67mm yet:p Link to comment Share on other sites More sharing options...
teddan Posted April 22, 2012 Author Share Posted April 22, 2012 JamieP: You are so right There will be brakes and tyres later on. Just bought a new peugoet 508 SW GT to have to clear out my two v70 for sale. High cash flow:wasnotme: Link to comment Share on other sites More sharing options...
teddan Posted April 27, 2012 Author Share Posted April 27, 2012 Someone that has ideas about a fuelpump for 1000hp on e85? Link to comment Share on other sites More sharing options...
dive_popo Posted April 27, 2012 Share Posted April 27, 2012 2x Bosh 040 Link to comment Share on other sites More sharing options...
teddan Posted April 30, 2012 Author Share Posted April 30, 2012 for the moment I am running 2x Walbro 255l/h... ...too small Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 30, 2012 Share Posted April 30, 2012 Aeromotive A1000, I also believe Weiand make a monster fuel pump that can easily cope with 1000wbhp. I've never been a fan of multiple fuel pumps, if you can get a single pump to do the job, do. Lyndon. Link to comment Share on other sites More sharing options...
teddan Posted May 14, 2012 Author Share Posted May 14, 2012 Parts under way to machine shop Balance Unfortunally the owner before mounted the new RPS clutch, and it seems like they have grinded the hole from paint so now we have a gap of 0,1mm on the axle . So we will make the hole bigger and fit a schim so it can be centred. I bought aem control soleniod 30-2400. Do anyone knows if I can buyt a controller and gauge unit as well and connect it to? Link to comment Share on other sites More sharing options...
teddan Posted July 22, 2012 Author Share Posted July 22, 2012 (edited) Painted! hmm I got a package A really nice thing Jamie P old one New bearings I did not have any V-blocks so putted all the main bearings in. Maybe I just should put in the end bearings? My biggest runout was 0,025mm. Up to 0,06mm are OK Then I mounted the thrust bearings Just mounted the old main bearing bolts by hand Thrust bearing check Then just pull the crank up and zero the DTI and then putted the crank down. I got 0,11mm and manual accept between 0.020mm and 0.220mm. OK This is my first engine built so I take huge amount of photos so if you see something wrong or something I forgot please write it Thanks Edited July 23, 2012 by teddan (see edit history) Link to comment Share on other sites More sharing options...
JamieP Posted July 22, 2012 Share Posted July 22, 2012 Glad it got there in one bit, nice turbo that, spools just as fast as my 7175 i have now, you are going to piss your pants the first time that comes on full boost;) Link to comment Share on other sites More sharing options...
ibby Posted July 22, 2012 Share Posted July 22, 2012 Glad it got there in one bit, nice turbo that, spools just as fast as my 7175 i have now, you are going to piss your pants the first time that comes on full boost;) its poo mate poo looking good Link to comment Share on other sites More sharing options...
teddan Posted July 22, 2012 Author Share Posted July 22, 2012 You should includ dipers when you sell it Link to comment Share on other sites More sharing options...
ibby Posted July 22, 2012 Share Posted July 22, 2012 You should includ dipers when you sell it did you read the terms and conditions ? If it dont say, you dont get Link to comment Share on other sites More sharing options...
Radio Posted July 23, 2012 Share Posted July 23, 2012 Sod the brakes...............get an x harrier jump jet parachute brake. (Cheap from the M.O.D auctions) Ha! Link to comment Share on other sites More sharing options...
TubbyTwo Posted July 23, 2012 Share Posted July 23, 2012 This is going to be an epic build I think. Subscibed!!! Link to comment Share on other sites More sharing options...
Westy Posted July 23, 2012 Share Posted July 23, 2012 Nice build progress. Should be a monster once finished! Link to comment Share on other sites More sharing options...
teddan Posted July 23, 2012 Author Share Posted July 23, 2012 parachute brake seems to be a good ide No I did not read the terms I just thought it was NL01 For the moment the workload on my job is high so the progress with the car will be slow for a while..... Nice that you like the thread Link to comment Share on other sites More sharing options...
teddan Posted July 29, 2012 Author Share Posted July 29, 2012 ARP for the main bearing in and fitting the main squirters Checking the main clearance. Mine was in the upper level around 0,040mm. But I will leave it like this due to the high performance on this engine. Maximum allowed clearance is 0,060mm I bought a scale to check the pistons. Amazing result. Check this.. pic heavy! So next task is to set up the ring gap. Thinking of going in the dragracing class Link to comment Share on other sites More sharing options...
