Calzo21 Posted December 8, 2012 Share Posted December 8, 2012 Shoulda just got a TT wouldn't of had this predicament Quote Link to comment Share on other sites More sharing options...
Tyson Posted December 8, 2012 Share Posted December 8, 2012 Insurance? Technically it's the same engine so you wouldn't necessarily declare it? True but you would have to tell the DVLA of the engine swap due to the fact it now has a different engine number, this would then show up to your insurance company when they look up its info. Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 8, 2012 Author Share Posted December 8, 2012 True but you would have to tell the DVLA of the engine swap due to the fact it now has a different engine number, this would then show up to your insurance company when they look up its info. It doesn't effect your insurance though. I had an engine changed by my warranty when it went pop, insurance stayed the same. I was more interested to know whether the block would give any advantages. I doubt ill buy a tt lump as they seem hard to find, so it would be going single or supercharged, so i guess my question is this block better for that or no real difference. Quote Link to comment Share on other sites More sharing options...
David P Posted December 8, 2012 Share Posted December 8, 2012 (edited) There's an after-market ECU that can be used with this VVTI 2J variant to re-map the inlet cam and to give more power at the expense of economy. http://www.2jzgarage.com/2012/02/2jzgte-vvti-aftermarket-support/ Edited December 8, 2012 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Tyson Posted December 8, 2012 Share Posted December 8, 2012 It doesn't effect your insurance though. I had an engine changed by my warranty when it went pop, insurance stayed the same. I was more interested to know whether the block would give any advantages. I doubt ill buy a tt lump as they seem hard to find, so it would be going single or supercharged, so i guess my question is this block better for that or no real difference. I never said it would My response was to that of Dangerous Brain saying you don't have to tell your insurance company. Now insurance companies hate paying out, crazy I know but they will take any opportunity to not give you a penny. An engine swap is a great way to completely void your policy, regardless of whether it only puts on 1 BHP more ! It is unlikely they would check the engine number but if they do then you are well and truly up poo creek without a paddle. It would have to be exactly the same engine it came from the factory with and it isn't. Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 8, 2012 Author Share Posted December 8, 2012 There's an after-market ECU that can be used with this VVTI 2J variant to re-map the inlet cam and to give more power at the expense of economy. http://www.2jzgarage.com/2012/02/2jzgte-vvti-aftermarket-support/ That is for the gte? But assume the same principle still applies. Would this not be the same with the non vvti 2jz anyway, i could get an aftermarket ecu and tweak things a bit? Can anyone tell me whether this engine would be better for a future big build or whether it will make no real difference at all? And whether it would just be the engine loom, ecu and engine that i would need to convert. Quote Link to comment Share on other sites More sharing options...
Scooter Posted December 8, 2012 Share Posted December 8, 2012 I 'think' you will have to swap the sump for a supra one.............it's not IMO in any way worth considering the swap. Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 8, 2012 Author Share Posted December 8, 2012 I 'think' you will have to swap the sump for a supra one.............it's not IMO in any way worth considering the swap. Ok thanks. Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 8, 2012 Author Share Posted December 8, 2012 What price do tt lumps usually go for? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted December 8, 2012 Share Posted December 8, 2012 What price do tt lumps usually go for? £1500-£2000 ish depending on what comes with it. Quote Link to comment Share on other sites More sharing options...
kill1308 Posted December 8, 2012 Share Posted December 8, 2012 Insurance? Technically it's the same engine so you wouldn't necessarily declare it? Insurance issues aside, it's a lot of work for what is potentially a marginally better engine. I don't know anyone that would, for example, swap an engine to gain 5hp and a small handful of torque. If you're going to do an engine swap, make it a TT.... if you can't afford it, then don't go down this route because it's the cheaper option, you'll be very disappointed with the results. Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 8, 2012 Author Share Posted December 8, 2012 Insurance issues aside, it's a lot of work for what is potentially a marginally better engine. I don't know anyone that would, for example, swap an engine to gain 5hp and a small handful of torque. If you're going to do an engine swap, make it a TT.... if you can't afford it, then don't go down this route because it's the cheaper option, you'll be very disappointed with the results. Tbh i wasnt planning on going the tt route, but if this engine had been a huge advancment on the one currently in my car i would have swapped and used that as the basis for my build next year. Quote Link to comment Share on other sites More sharing options...
SPG Posted December 8, 2012 Share Posted December 8, 2012 £1500-£2000 ish depending on what comes with it. I have been struggling to find a decent TT lump for less than £2k as of late, Paul Whiffins was the last I noticed which was sold on here for 2.5k Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 8, 2012 Author Share Posted December 8, 2012 Its quite a lot of money really, considering how much gain going single gives. Still lots to think about then. I guess one advantage having a non vvti is that the engine itself is less complicated, in theory making it easier to work with. Quote Link to comment Share on other sites More sharing options...
David P Posted December 8, 2012 Share Posted December 8, 2012 That is for the gte? But assume the same principle still applies. Would this not be the same with the non vvti 2jz anyway, i could get an aftermarket ecu and tweak things a bit? Can anyone tell me whether this engine would be better for a future big build or whether it will make no real difference at all? And whether it would just be the engine loom, ecu and engine that i would need to convert. With engine, loom, sensors and ECU, the job should be plug&play, enough. The VVTI is a 2J with an extra dimension, stock ECU('s) or use one after-market ECU to manage engine and another (linked in link) to manage the cam timing, if running Auto you could use even another to control the transmission and have flappy-paddle gear-changes. If you plan to stay N/A, you could get more out of a VVTI than a non VVTI. I am working on an N/A 75mm t.b. conversion that would be interesting to add into the possibilities. The VVTI's I believe had lighter con-rods and a higher rev-limit, these would be plenty strong enough for N/A, yet would need swapping for non VVTI rods to boost to more than 7psi? "Kirk" has posted some pic's and info about con-rod differences on here somewhere in a "Branners" O.P. thread. Quote Link to comment Share on other sites More sharing options...
Pulley Posted December 8, 2012 Share Posted December 8, 2012 Only advantage of this engine over usual NA 2jzge is its coilpacks and not dizzy I'd buy one to do an NA-T with Quote Link to comment Share on other sites More sharing options...
David P Posted December 8, 2012 Share Posted December 8, 2012 Only advantage of this engine over usual NA 2jzge is its coilpacks and not dizzy I'd buy one to do an NA-T with If that's all you want, it would be simpler to fit coil-packs to your GE. Quote Link to comment Share on other sites More sharing options...
Pulley Posted December 8, 2012 Share Posted December 8, 2012 If that's all you want, it would be simpler to fit coil-packs to your GE. I already am, but I was just saying Gains with the vvti setup as stock are pretty small , wouldn't be the reason I'd swap between NA engines Having a ready to go coilpack engine would be an advantage if you don't know how to retro fit the setup ,coilpacks, ecu, cam position ect ect Just my opinion, Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 8, 2012 Author Share Posted December 8, 2012 (edited) With engine, loom, sensors and ECU, the job should be plug&play, enough. The VVTI is a 2J with an extra dimension, stock ECU('s) or use one after-market ECU to manage engine and another (linked in link) to manage the cam timing, if running Auto you could use even another to control the transmission and have flappy-paddle gear-changes. If you plan to stay N/A, you could get more out of a VVTI than a non VVTI. I am working on an N/A 75mm t.b. conversion that would be interesting to add into the possibilities. The VVTI's I believe had lighter con-rods and a higher rev-limit, these would be plenty strong enough for N/A, yet would need swapping for non VVTI rods to boost to more than 7psi? "Kirk" has posted some pic's and info about con-rod differences on here somewhere in a "Branners" O.P. thread. This sounds very interesting indeed! I think i may look further into it. The economy gains (before modding) also seem a bonus. Also are the rods on the vvti thinner/weaker, i remember reading something about this with the vvti gte engine. Edited December 8, 2012 by scott87 (see edit history) Quote Link to comment Share on other sites More sharing options...
Herb Posted December 8, 2012 Share Posted December 8, 2012 Hey David! That 75mm throttle body conversion sounds really interesting Regards, Herbert With engine, loom, sensors and ECU, the job should be plug&play, enough. The VVTI is a 2J with an extra dimension, stock ECU('s) or use one after-market ECU to manage engine and another (linked in link) to manage the cam timing, if running Auto you could use even another to control the transmission and have flappy-paddle gear-changes. If you plan to stay N/A, you could get more out of a VVTI than a non VVTI. I am working on an N/A 75mm t.b. conversion that would be interesting to add into the possibilities. The VVTI's I believe had lighter con-rods and a higher rev-limit, these would be plenty strong enough for N/A, yet would need swapping for non VVTI rods to boost to more than 7psi? "Kirk" has posted some pic's and info about con-rod differences on here somewhere in a "Branners" O.P. thread. Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 8, 2012 Author Share Posted December 8, 2012 Do you also happen to know whether the vvti n/a engine ecu is capable of being mapped. I've been told the standard 2jzge is not. Quote Link to comment Share on other sites More sharing options...
Herb Posted December 8, 2012 Share Posted December 8, 2012 I've got a remapped ECU installed on my NA. Very few people on here have it because it's not a cheap option. It's a Mine's VX Rom ECU. Regards, Herbert Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 8, 2012 Share Posted December 8, 2012 Remapped as you would an AEM or Syvecs, no. Modified like Herb's MiNES VX then yes. You would be far better getting a TT engine and stock ECU Quote Link to comment Share on other sites More sharing options...
scott87 Posted December 9, 2012 Author Share Posted December 9, 2012 Cheers. It seems that the vvti would allow for more tweeking compared to the standard ge. Quote Link to comment Share on other sites More sharing options...
jay200bhp Posted December 9, 2012 Share Posted December 9, 2012 i would bin all ideas of vvti...turbo or not... get a tt engine and loom ecu etc and go that way ooo buy a tidy tt..... or even a single depending on your future intentions..buying a done single will save you no end ... Quote Link to comment Share on other sites More sharing options...
