SRD New Products and suggestions.....
Jamesy
 Share
  • Replies 126
Posted Images
  • 3 months later...
What about a kit similar to Hose Techniques Kit
http://www.hosetechniques.com/index.php?main_page=product_info&products_id=1993
This kit contains all the Silicone Vacuum hose needed for your application in the correct lengths required for a total of: (32 ft Total)
Also included will be all the extras such as tie wraps, tools, fittings (when applicable) and instructions for FREE!
Each hose in your kit is of the correct proportion, both in length and wall thickness (you can rely on HoseTechniques to have determined the appropriate wall thicknesses for each hose provided in your kit). The color and gloss of our hose will provide a brilliant look to your car engine, and our guarantee provides the confidence that you are installing the highest quality silicone available, designed to eliminate the problems caused by deteriorating* OEM rubber hoses. (*You probably already know about the fact that poor quality hoses can severally affect the performance of your car.)
Suggested Uses - Suggested Hose I.D. Sizes*
Intake Manifold (small fittings) - 03.5mm
Boost Controllers (Greddy, HKS & other) - 03.5mm, 04.mm or 06.0mm
Windshield Washer Bottle - 04.0mm
Intake Manifold (small fittings) - 06.0mm
Radiator Overflow Hose - 06.0mm or 08.0mm
Hood Hold Up Rod - 06.0mm or 08.0mm
Intake Pipe (large fittings) - 08.0mm (includes aftermarket intakes & some radiator overflow)
Misc. covers of hard lines, etc. - 10.0mm (refer to Slit ‘n Groom™ Technique in instructions)
  • 4 weeks later...
  • 1 month later...
 Share
