To blow or not to blow.... ?
Kaamos
An externally vented BOV has no benefit, it only makes the car sound like a bus door is opening when letting off the throttle under boost.
You can fit one to a stock engine, the stock recirc setup is only there to reduce annoying noises.
if you do get one get a hks ssqv :D mint
Quite honestly shane, the HKS is the worse sounding BOV i've heard, I hated the one on mine. It sounded like a mouse farting :D
This one is my favourite, old school Blitz:
I find with my Blitz BOV, it only makes a noise if you want it to, so suddenly letting go of the throttle does it, but not if you do it gradually, just makes that quiet chattering noise.
Thats how all vent to atmposhere BOV's sound. Let off under higher boost and it'll operate (the whoosh, or nouse fart/bus door sound), let off under light boost and it will result in compressor stall which is the air being forced back though the air filter due to the BOV not venting. When you hear chatter, it's not the BOV making the noise, it's air being pushed back through the air filter by the compressor stalling.
Hi mates !
the newbie I am is wondering, what's the benefit of a blow-off-valve ?
I mean, ok there's the strange sound, but what else ?
Is it much work to fit one on a stock engine ?
Thanks for your enlightenments :)
Noticed you are from France, is yours a Japanese or European model Supra?
are there any drawbacks ?
Yes on a UK spec Supra there are drawbacks
The stock blow off valve recirculates the air back into the intake. The UK Supra uses a MAF (Mass Airflow) sensor, if you fit a BOV that vents to atmosphere it will screw up the air/fuel mixture.
Options are to either leave stock BOV fitted, or fit an aftermarket BOV and vent this back into the intake system. Blitz and HKS both make adapters to recirculate the air, but this will make the BOV almost inaudible.
An externally vented BOV has no benefit...
I'm no expert (never having owned a turbo'd car), but I didn't realise that was the case. I would have thought all BOVs help to prevent stalling the turbo and hence prolong its life.
I'm pointing this out just in case the OP has got the wrong end of the stick (it sounds like he's considering removing the BOV completely, stock or not), but I've probably succeeded only in confusing things even more. :)
The stock supra already has a "blow off valve" if thats what you want to call it. It's that round thing about 1inch across on top of the engine. It recircs the air back into the intake to reduce noise (Same as pretty much all turbo production cars), instead of to atmosphere (which causes the chirp sound)
The stock one is perfectly fine for use on bpu.
Isn't it the case that the stock recirc gets overwhelmed when the boost is increased? So a larger aftermarket BOV is required to stop stalling the turbos if you're running hybrids or a single?
If the stock one does leak it's not because it can't handle it, it's because it'll be knackered.
It's a bit of an old myth this one, similar to the rising rate FPR's that were hawked on here a few years ago.
Ah, I see. My misunderstanfing. I'll move on now. :D
