My VVTI GT35R Single Conversion
MarkR
 Share
  • Replies 494
Posted Images
Few more out of order...
Now this is how you do a wiring harness. This one is for the manual gearbox to engine loom connection. Note the really nice outer covering. Wayne really pays special attention to the small things.
Look how much was removed from the VVTI stuff:
Dash with the gauges a little skew... They will be lined up once fitted.
Edited by MarkR (see edit history)
I initially asked Wayne @ SPC to pop the AEM water injection tank in the boot, but he had a better idea and asked if it was okay. He explained the idea, and I think he did an awesome job. See below for pics:
The mounting spot:
The filling spot:
The hole cut for the filler neck:
The rubber grommet to protect the filler and the bodywork as well as clean up the look of things:
Coming on now, I like how you have mounted the water injection tank although the IC pipework looks very close to that front tyre, have you checked it on full lock?
Thanks, it was Wayne's idea and I really like it (although it does limit me with regards to making a cold airbox feed). I'll get him to check the full lock. Cheers for the heads up.
 Share
