Spec list so far for my build, have I missed anything?
Parry_10
Ok so my goal is to make 700fwhp with a rev limit of 7200-7500rpm.
Here is a list of things I have so far that come to mind may have missed a few bits here and there. If something isnt on the list that you think I will need let me know:
Nur motorsport Carbon fibre rear arches, 50mm wider each side.
Nur motorsport Carbon front arches, 40mm wider each side.
Hybrid Full Carbon Doors
Seibon Full Carbon Tailgate
RMM front spoiler
Facelift front & rear lights
Clear indicators
Stubby aerial
Zunsport Front Grille
Custom bonnet vents, aerocatches
Ridox carbon boot lip
Tein flex coilovers
Fiske alloys
Stock bottom end (only done 60k) - its been compression tested
6 speed v160 gearbox- (again done 60k)
6 speed big case prop
Big case UK spec auto LSD with correct shafts
TT6 engine loom
6 speed flywheel
Garage whifbitz adjustable cam pulleys
SRD twin electric fan kit
Polished cam covers with custom -12 breathers and braided lines with fittings
SRD alumimum undertray
Greddy pulley set
Twin bosche 044 in tank fuel pump set up
Whifbitz id1000 injector and fuel rail set up
Twin fuel filter set up with braided lines aero fittings etc
Aeromotive FPR
Line lock kit
Whifbitz 4" exhaust
Nardi steering wheel with boss and quick release hub
Greddy 4” fmic
SRD alloy radiator
Billet timing belt tensioner
Titan crank Pulley
Carbon fibre slam panel
Carbon fibre spark plug cover
Stage 2 head- Fully ported+polished, brian crower ti springs and retainers, new teflon coated valve stem seals
ARP headstuds
All gaskets new toyota gaskets inc headgasket
Greddy intake manifold- fully port matched
Q45 throttle body 90mm
KAD brakes with upgraded stainless pistons and new seals- AP racing 356mm discs
Comp turbo- 6765 billet, .81ar, 3”v band
T4 turbo blanket
PHR downpipe and midpipe 3”
PHR turbo oil lines
HKS 60mm wastegate
HKS exhaust manifold
Syvecs toucan screen
All syvecs sensors
Mocal/SRD oil cooler kit and power steering cooler
HKS ssqv bov
I think all I have left to buy is:
Syvecs ecu
Clutch
Cams
Seats
ngk racing sparkplugs
Edited by Parry_10 (see edit history)
You will need irridium grade 8 or 9 or go for the racing ones Jamie P always recommends
You may also want to consider new coil packs and clips as higher power and boost tend to highlight faults eg misfires on older items.
Good luck with build - looks like another great supra in the making
Yes will be getting the ngk racing plugs cheers:) got a set of low mileage coilpacks which I will try for the time being.
You will want a new OEM oil and water pump and I would recommend getting a new crank pulley whilst you are there.
Got a titan crank pulley. Oil pump is low miles and had new front seal recently and the bottom end is mint. Water pump is new basically
The plugs are the NGK r7436-9's, also get yourself some heat wrapping and a turbo blanket.
However, isn't 700RWHP a little optimistic on that turbo?
Ok cheers, got turbo blanket. Will be getting heat wrap for the turbo and wastegate lines. HKS manifold is already heat wrapped. And its 700FWHP mate not RWHP, not optimistic at all:)
Nice setup. But I believe You will definitely need :
1- New oem oil and water pump
2- arp L19 or 625+ headstuds otherwise head will lift
3- Ati crank pulley will be good idea
4- depending on the boost, you might need hks dli or motec cdi-8 for ignition
5- I prefer Tial bov instead of Hks.
