Saving a UK TT 6 Speed !!Update Page 9/10 !!
Slutters
 Share
Oh no! A solid crank pulley :blink:
Oh no, another sheep..... ;)
I also added a new alloy flywheel and twin plate that's lighter than stock. I don't see how changing the weight on the crank at one end vs the other will make any difference.
I am willing to test this for you guys, i don't mind being a test dummy! :D
Edited by Slutters (see edit history)
  • Replies 156
Posted Images
  • 3 months later...
Right guys, bit of an update since last time!
Hi guys
Wanted to share this set of mods with you, mostly because I was unaware of the improvements that could be made!
Firstly, thanks to:
http://www.max-boost.co.uk/max-boost - lots of detailed info, even Supra stuff on there! No BS, just simple, easy to read info!
http://www.mkivsupra.net/vbb/showthread.php?197330-FMIC-ducting-install – the inspiration!
Firstly here is a screen shot of the issue. This was on a 20 degree Celsius day, no boost just stop start driving! 52 degrees! Ouch! :(
The point being, this heat is going to heatsoak the intercooler before you even consider the massive load the boost will add! The sensor is located right on the throttle body so is a true reflection of what is going on.
So after much reading I set about reducing my inlet temps, this is the story!
This is how my single setup looked, very similar to many others I have seen!
You can see the black ducting I had to the left, it was clearly going nothing.
This was my previous ducting, it was a quick bodge, you can see how much air flow I was wasting when you compare it to the pic with no bumper.
So, with the bumper off, I set about removing some of the ‘funnel’ to increase my expansion chamber
after
The ducting I made, its made from very thin steel, I will be getting it re-made but I only have a mig. :( It’s fairly light, not as light as aluminium but better than no ducting! All the tiny joins were sealed too.
Next up I wanted to get the air filter out of the bay, I did want to get rid of the K&N after seeing just how bad they were on the MaxBoost website, however my commercial paper replacement was a little…err….too big! :D
Whoops!
So, back to the K&N for a few months until I fine a smaller paper commercial filter.
Wanted some more airflow to the filter so some more came off the bumper
Also, had to make a 4.5” hole in the inner wing, not what I wanted to do but I had no choice.
gasket added
I used this for the inlet pipe, its suitable for 100 degrees and 6 bar so plenty for an inlet
i then lagged this with industrial pipe lagging and sealed with aluminium tape. No **** taking, I know it looks like a big hover… :D
Whilst taking this pic I noticed the second issue!
Look how close the compressor housing is to the exhaust manifold! On big boost it must add some much heat to the already hot compressed air!
So I looked around for something to help!
I found a Saab 9-3 turbo heatshield, 2 bits of aluminium filled with asbestos! Yes! :D
Gave it a clean
Then fitted
I know it looks a bit silly but function of form!
Covered the inlet pipe also
Now the intercooler and inlet is sorted I turned to the radiator. I had AC but never had it gassed. I have removed the rad but left all the pipes so if the next owner wants it, its just a case of 4 bolts and a re-gas.
Intercooler removed showing the old AC rad, that can’t help airflow!
in the next pics you can see all the gaps around the radiator, as air goes for the path of least resistance I was losing some cooling potential here.
Bottom left
bottom
bottom right
And aluminium taped up, 3 layers so its strong and forces the air through the rad instead of going around it!
Also I noticed this gap at the top
added some foam
Started refitting up
Intercooler back on with rubber seals where the ducting meets the edges
just about to fit the ducting and my mate Dan has trolled me! :D
Twat! :D
Anyway ducting on
I found a place to fit the air filter
I had brought an engine tray and a bumper tray but with my new mods they no longer fitted. :( Air flow is much better with a tray and helps to create low pressure in the engine bay.
This is the gap between the fmic and rad, you can see the gap at the bottom, I would be losing lots of air from there!
So, some 4mm plastic sheet!
the underside
Due to my air filter location I didn’t want the wheel throwing water onto the air filter, and I also wanted to use the low pressue of the wheel to pull air past the filter. As my splitter has a duct in it I also wanted to use that as otherwise it’s a waste! So…
Heres the new lower mud guard. You can see the rounded gap near the inside of the wheel to help with airflow
another angle
inside the lower splitter duct, forcing air to the filter
And what’s all that work worth?
Well went for a ride last night and after a long run, sat idling I had temps of….
25 degrees! :D Nearly halved! Dyno next week so lets hope my new mods get me some ‘free’ horsepower!
Right, with mapping due in a few days i decided to do the last few changes ready.
Gave the inlet a clean for the injector bungs to be welded in
HKS Fuel rail O ring!
Leaking!
Inlet removed
TC Delete
Painting up the new inlet
Moved the battery to the boot
Fuel rail and injector bosses welded in
New Water/Meth injection tank
Water injection kit and thinker inlet manifold gaskets
Old OEM vs new ones
Rail painted and injectors installed
And all finished!
Fitting water injection kit
Welded a plate to the end of the chassis leg
Water injection nozzle
Next up was my coil pack upgrade
Old ingnitor
Removing the old injectors
Mojo Coilpacks!
Old at the top Vs the new monstors!
Full guide comes with the kit
Loom in
Igniter removed
New loom
Soldering to old loom
Joining car loom to Mojo
All finished and ignitor gone
All was going well! Car went for mapping
And well.... it blew up :(
So the next day...
Not looking great
Ahh, thats the issue then...
Block is now waiting for some new forged pistons! :D
Head is scrap
Just ordered all the engine parts so while i was waiting i stripped out the plugs i no longer needed from the loom
before
After
Scrap
Also took the chance to do some porting on my wastegate as it was boost creeping
And added some new oil coolers!
Rubber mounted
Bumper trimmed and ducted
Well! That's it for now, lots of updates to come, all the new engine bits are here now. :D Just waiting on machine work.
Wow, nice build Sultters :thumbs:
Can I please ask- when you made up the braided clutch line, do you need any special tools to crimp the end joints?
I always thought any hydraulic hoses need special machines to crimp on the fittings to cope with the higher pressures involved.
Made it myself mate, no need for any special tool's as long as you get a nice clean straight cut it's easy as pie! :D
Some nice work on the ducting of the IC :thumbs: What FMIC is it, it looks quite narrow? A wider FMIC would make better use of the frontal area available.
Are you fitting a turbo blanket? A good quality blanket (Dei) would make a significant difference to the engine bay/intake temps.
Great work but just wish to add that the ducting possibly isn't as efficient as it could be.
I've attached a simple drawing i found explaining why
That's true, however how can you create the bottom picture on the horizontal plane without reducing frontal area?
http://i1170.photobucket.com/albums/r532/karmadino/P1040451_zpsa3328a6f.jpg
It's a 600MM wide core, on the dyno we had to turn off the fans as the inlet temps were so low and Sam needed to get some more heat into the core! :D A turbo blanket would make no difference in my application with regards to intake temps as the filter is out of the engine bay. I will be adding one however for under bonnet temps as you say.
Just to add, my duct sits inside of the orignal bumper mouth like:
So hopefully that edge would prevent the loss of air, however i guess that as the molecules stack up and they reduce in speed to pass through the core you will lose some.
A good quality turbo blanket would make a big difference, it stops the majority of the radiated heat from the turbo, heat that increases the engine bay temps and subsequently the intake and IC piping temps. On a dyno you could get the turbo hot side glowing red but the turbo blanket would be just warm to the touch.
Nice work on the ducting, I'm thinking of mounting my coolers in the side duct instead of behind the intercooler. Looks smart :thumbs:
Thanks mate, i did think of doing that also, however i didn't want to pre-heat the water radiator with the oil cooler's waste air. :( Big HP requires lots of cooling, those 2 oil coolers are both 20,000BTU so only really JUST big enough!
As i said, i will be adding one for underbonnet temps. :)
Yeah I see. My coolers are for the transmission but I don't have any engine oil coolers. Maybe something for the new build.
 Share
