Dnk Posted November 22, 2011 Share Posted November 22, 2011 Why wouldnt it? Just pulling your leg Rob I look at a standard bay and think where the **** have you put everything Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 22, 2011 Author Share Posted November 22, 2011 Scott ill have a better look tomorrow, but have you disconnected the 2 green connectors inside the cabin and pulled them through? Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 22, 2011 Author Share Posted November 22, 2011 Just pulling your leg Rob I look at a standard bay and think where the **** have you put everything To be honest i have not moved alot and all your doing is flipping it from top of panel to under the panel.... BUT its sooooo time consuming. Quote Link to comment Share on other sites More sharing options...
hodge Posted November 22, 2011 Share Posted November 22, 2011 Scott is right but only on a TT. By the looks of it this car was an N/A previously. On a TT Scott it splits into 3 as you say, 1 is the fusebox, another goes to the ABS/trac pump and A/C pipe the 3rd runs up the inner wing, through the hole in the back and into the cabin through an orange grommet under the inner arch. If the car has no ABS like Bosscos the loom that goes to the ABS odviously isn't there but the A/C wires come through the back hole in the inner wing. Quote Link to comment Share on other sites More sharing options...
Noz Posted November 22, 2011 Share Posted November 22, 2011 yup Parry done a NA-TT conversion its in his build thread. At one point it was a NA-person-TT... EDIT: photo added of proof!... sorry mate couldnt help myself Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted November 22, 2011 Share Posted November 22, 2011 Nice work. God your engine bay is nice. Anyway, I'm going to try and do a bit of a tuck on mine when it's all put back together. I'm not keen on bits in the boot. Has anyone considered having a bespoke ali washer bottle made to sit under the air diversion plate with a low neck coming through? Even with a big intercooler there should be sufficient room? Quote Link to comment Share on other sites More sharing options...
Scott Posted November 22, 2011 Share Posted November 22, 2011 Scott ill have a better look tomorrow, but have you disconnected the 2 green connectors inside the cabin and pulled them through? Nope, haven't even looked at it properly yet lol. Just thought I would ask to save faffing around Scott is right but only on a TT. By the looks of it this car was an N/A previously. On a TT Scott it splits into 3 as you say, 1 is the fusebox, another goes to the ABS/trac pump and A/C pipe the 3rd runs up the inner wing, through the hole in the back and into the cabin through an orange grommet under the inner arch. If the car has no ABS like Bosscos the loom that goes to the ABS odviously isn't there but the A/C wires come through the back hole in the inner wing. Bingo bango mate. With ABS I am. Is that right enough for me too then John? Just disconnect a couple of plugs in next to the ECU and pull it through? I've already pulled out the ABS/AC loom but I want to tuck the lot in underneath the headlight and just run it inside the inner wing Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted November 22, 2011 Share Posted November 22, 2011 yup Parry done a NA-TT conversion its in his build thread. At one point it was a NA-person-TT... EDIT: photo added of proof!... sorry mate couldnt help myself http://i1040.photobucket.com/albums/b404/Parry_10/IMG00308-20110101-1159.jpg hahaha:D that was when it was running 1mp (one man power) lol Quote Link to comment Share on other sites More sharing options...
hodge Posted November 22, 2011 Share Posted November 22, 2011 That's right Scotty. There's only 2 plugs to pull outing the passanger side next to the ECU and feed it into the engine bay. Oh you need to disconnect the rear washer pipe from under the passanger inner arch too cos it goes through the same grommet as the loom. If you get stuck, drop me a p.m so we don't clutter Robs thread up with useless info. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 22, 2011 Author Share Posted November 22, 2011 Dont worry John, more bits/ knowledge in the thread might help others out... im still learning myself. Hope to get the offside all boxed up tomorrow and wheel on and under arches on ect... then ill have full attention to the nearside and the fuse box. I have a little idea i want to look at in more deph Quote Link to comment Share on other sites More sharing options...
RobD Posted November 22, 2011 Share Posted November 22, 2011 Looks stunning, I'd consider a electric fan setup and loosing the shroud if it was mine, would look even better then Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 23, 2011 Share Posted November 23, 2011 Looks clean mate! Top work! Quote Link to comment Share on other sites More sharing options...
hodge Posted November 23, 2011 Share Posted November 23, 2011 Looks stunning, I'd consider a electric fan setup and loosing the shroud if it was mine, would look even better then Don't let Chris wilson here you say that. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 23, 2011 Author Share Posted November 23, 2011 don't let chris wilson here you say that. Quote Link to comment Share on other sites More sharing options...
RobD Posted November 23, 2011 Share Posted November 23, 2011 Don't let Chris wilson here you say that. He's not a big fan then In terms of decluttering, it would look better! But to keep Mr Wilson happy, don't do it, worst mistake of your life Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 23, 2011 Author Share Posted November 23, 2011 or get a SRD fan kit, they seem to work perfectly Quote Link to comment Share on other sites More sharing options...
RobD Posted November 23, 2011 Share Posted November 23, 2011 or get a SRD fan kit, they seem to work perfectly That's what I was thinking, nice alloy rad also. Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted November 23, 2011 Share Posted November 23, 2011 Looks stunning, I'd consider a electric fan setup and loosing the shroud if it was mine, would look even better then Thats exactly what im going to do in the new year, alloy rad, electric fan set up and a set of robs pulleys when he has had them made. Ive also got a polished top rad pipe to fit when I get the car back Quote Link to comment Share on other sites More sharing options...
RobD Posted November 23, 2011 Share Posted November 23, 2011 Thats exactly what im going to do in the new year, alloy rad, electric fan set up and a set of robs pulleys when he has had them made. Ive also got a polished top rad pipe to fit when I get the car back Good plan! Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 25, 2011 Author Share Posted November 25, 2011 Finished the car now and it has come out great. Just had it running for ages to make sure everything was ok and ran through the lights ect. Quote Link to comment Share on other sites More sharing options...
Westy Posted November 25, 2011 Share Posted November 25, 2011 Looks great Rob! Nice work! Quote Link to comment Share on other sites More sharing options...
Scott Posted November 25, 2011 Share Posted November 25, 2011 Needs a coat of paint to freshen it up but it looks fantastic Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 25, 2011 Author Share Posted November 25, 2011 Needs a coat of paint to freshen it up but it looks fantastic Yeah it does mate i agree. Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 25, 2011 Share Posted November 25, 2011 looks mint mate! Quote Link to comment Share on other sites More sharing options...
hodge Posted November 25, 2011 Share Posted November 25, 2011 Looks good Rob. If you pull the sound deadening off the bulkhead and give it a rub buff up will look loads better IMO. Also the brake booster pipe fits nicely into the scuttle panel too, just to clean up that bulkhead a bit. I think that's where TTs look the worst. Quote Link to comment Share on other sites More sharing options...
