MattP Posted February 15, 2010 Share Posted February 15, 2010 hi guys having a problem with my heater matrix it still kicks out heat but when its on it smells nasty. I have tried putting some coolant flush through the system and it hasnt got rid of the smell is it due a new matrix? or something simple that might fix this problem Link to comment Share on other sites More sharing options...
trinitom Posted February 15, 2010 Share Posted February 15, 2010 it could be the blower filters, i think there is a spray for that. Link to comment Share on other sites More sharing options...
hoff Posted February 16, 2010 Share Posted February 16, 2010 Is the smell anti-freeze? If so, you sound like there is a problem. Is the footwell wet at all, any mist on the windscreen? Link to comment Share on other sites More sharing options...
j_jza80 Posted February 16, 2010 Share Posted February 16, 2010 I'd prize up the carpet from around the transmission tunnel on both sides, there should be water there if the matrix is leaking (mainly on the passenger side) Link to comment Share on other sites More sharing options...
stevie_b Posted February 16, 2010 Share Posted February 16, 2010 "smells nasty" - you might need to expand on that for us. If nasty means mouldy, it should be as simple as treating your aircon with an antibacterial agent. If nasty means coolant smell, that indicates a coolant leak, which probably means a new heater matrix. Link to comment Share on other sites More sharing options...
MattP Posted February 16, 2010 Author Share Posted February 16, 2010 theres no leak on the system from what i can tell. when i say it smells nasty its not coolant its like a rustic smell theres no smoke or dampness etc just a horrid smell. Link to comment Share on other sites More sharing options...
pbryant_knight Posted February 16, 2010 Share Posted February 16, 2010 Has some small chav kid crapped in your engine bay while you haven't been looking? they can be nasty like that can the Chavs Link to comment Share on other sites More sharing options...
jon5698 Posted February 16, 2010 Share Posted February 16, 2010 I am having problems with my heating as well, it takes about 1hr before it starts to kick out hot air. I have ordered a new thermostat and radiator cap from mr t and am going to change the coolant over the weekend to see if it cures it. Link to comment Share on other sites More sharing options...
MattP Posted February 16, 2010 Author Share Posted February 16, 2010 il do what i do best with toyotas give it a kick Link to comment Share on other sites More sharing options...
stevie_b Posted February 17, 2010 Share Posted February 17, 2010 il do what i do best with toyotas give it a kick What, the matrix? It's a couple of hours of spannerwork until you can even see the thing. jon5698: if you change the coolant, try hose-flushing the matrix in both directions whilst you're at it. Let us know if a new stat/cap works. Link to comment Share on other sites More sharing options...
nigelboyne Posted February 17, 2010 Share Posted February 17, 2010 il do what i do best with toyotas give it a kick do you have headlight washers. when i bought the supra same sort of sick smell coming in to the car taught it was the heater as only came in when turned on turns out to be stagnic stale water in the washer bottle Link to comment Share on other sites More sharing options...
Ric Posted February 17, 2010 Share Posted February 17, 2010 give your local detailing/valeting place and ask for a interior odour bomb application (probably called different things) but most will know what you are asking for They basically put a machine in your car and run it for 30 minutes with the blowers on full, its meant to clean all the crap out, kill bacteria whats making the smell! Link to comment Share on other sites More sharing options...
Dnk Posted February 17, 2010 Share Posted February 17, 2010 give your local detailing/valeting place and ask for a interior odour bomb application (probably called different things) but most will know what you are asking for They basically put a machine in your car and run it for 30 minutes with the blowers on full, its meant to clean all the crap out, kill bacteria whats making the smell! You can buy an aerosol that does the same thing, Ibrar a trader on here had some a while back, turn the aircon on and set to recirc and close all the windows, set off the aerosol and leave inside the footwell. Worked a treat in my car Link to comment Share on other sites More sharing options...
Ric Posted February 17, 2010 Share Posted February 17, 2010 Or that yes I've never had any experience with the aerosols so probably just as good, halfords also sell those i think Link to comment Share on other sites More sharing options...
jon5698 Posted February 17, 2010 Share Posted February 17, 2010 What, the matrix? It's a couple of hours of spannerwork until you can even see the thing. jon5698: if you change the coolant, try hose-flushing the matrix in both directions whilst you're at it. Let us know if a new stat/cap works. Thanks for the advice stevie, is that just a case of putting a hose pipe onto the radiator top hose and running water through it, and then doing the same with the bottom hose? Link to comment Share on other sites More sharing options...
Abz Posted February 17, 2010 Share Posted February 17, 2010 (edited) ... Edited February 17, 2010 by Abz Plonker of a missus (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted February 18, 2010 Share Posted February 18, 2010 Thanks for the advice stevie, is that just a case of putting a hose pipe onto the radiator top hose and running water through it, and then doing the same with the bottom hose? You need to remove the in and out feeds that fit to the matrix which are between the the back of the engine and the bulkhead, then with a hose pipe put on one side then the other which might loosen up anything in there. Ignore the green and red arrows Link to comment Share on other sites More sharing options...
stevie_b Posted February 18, 2010 Share Posted February 18, 2010 What Dnk said. You don't need to touch anything around the radiator when flushing the matrix. Link to comment Share on other sites More sharing options...
Dnk Posted February 18, 2010 Share Posted February 18, 2010 The only thing i'd add is to try hot water as that tends to loosen up grime and sludge better than cold Link to comment Share on other sites More sharing options...
jon5698 Posted February 18, 2010 Share Posted February 18, 2010 Thank you both for that, i will let you know on saturday if it has worked Link to comment Share on other sites More sharing options...
MattP Posted February 19, 2010 Author Share Posted February 19, 2010 problem solved i used a comma odour bomb i got from halfords for abot 12quid and the nasty smell has gone. big saving on getting a new matrix Link to comment Share on other sites More sharing options...
