Supra Drag Racing Times
mawby
 Share
  • Replies 351
Posted Images
Yay, my first entry on the board :D, if a mod wouldn't mind adding me
1/4 ET 12.30
1/4 MPH 114.19
60ft 2.256
Model JSpec
Turbos T67DBB
Boost 1.5 BAR
Trans 6 spd
Tyres R888
Event SantaPod
Were you running on your 18" rims?
Also I had to shift just as I passed the line which is prolly why it felt like I was lifting off
Hi Jay
Lift you rev limit another 500 and you'll be fine in 4th across the line. This will give you a 125 terminal speed then it down to grip to lower your ET's.
A good run then and your'll be hitting rev limiter just short of the 1/4 mile and it will mean better times :eyebrows:
Gaz
Hi Jay
Gaz
I was going to do that on the day bud, but what with the boost issue I felt there was no point pushing it when I was only going over the line at 1 bar. I've fixed my boost issue now though, fecking solenoid was sticking & gunked up inside. Sprayed some cleaner in & it's been boosting perfectly all day today, at least the car is 100% again :)
Decent going - just need to get that 60ft time down and the ET's will tumble down, there's high 10 second pass potential in your setup :)
York dragway is not the best strip, need to get some 800cc injectors fitted, my 650cc are running at 80% duty at 1.3 bar, with some 800cc in i can turn the boost up and get the car to santapod might get low 11's maybe
Proper old school drag racing at York :cool:
Even let you run on damp surface 'just take it a bit easy until front wheel drive cars have cleared the damp' i was once told :D
If you can launch and get good 60fts at York you will be able to do it anywhere :eyebrows:
  • 3 weeks later...
A few of my times from Crail yesterday - track was damp/wet so hopefully in the dry I can improve them:
Brilliant day out, car was very close with my friends TVR Tuscan, he pipped me very slightly with a 13.13 with a slightly better 60ft time but lower terminal speed.
TT 6 speed, BPU, J Spec, 19' Wheels 1.1 bar
RT: 1.005
60ft: 2.546
ET: 13.566
MPH: 114.8
RT:0.53
60ft: 2.373
ET: 13.191
MPH: 113.9
RT: 0.552
60FT: 2.493
ET: 13.406
MPH: 113.4
Does my 12.7 1/4 set at thunder road count?
It was a 1 mile event on a runway not an official drag strip. the 1/4s were recorded but not the main focus. :p
If so can you add it.
12.7
unknown et
unknown reaction
Uk spec
Stock (steel) 1.3 bar
Auto
18" toyo tr1
Thunder road - Woodbridge Airfield
BPU, Un prepped track, no burnout.
  • 2 weeks later...
It was 5 years ago that I ran 11.822 @ 117.96 which at the time was the quickest time by a stock/hybrid turbo 6 speed manual car. Since then a couple of stock/hybrid auto cars have run quicker.
In 2008 I fitted a Powerhouse Racing Stage 1 single turbo kit with HKS F-CON V Pro which was dyno'd at 496bhp/492ft/lbs at the hubs at 1.4bar. Since then I have struggled to beat my best stock turbo time.
I got close last year with a run of 11.84 @ 120 but trashed the diff!
Finally after months of trying last weekend at Shakespeare County Raceway I finally ran a personal best of 11.671 @ 124.03!
The details are:
60ft - 1.961
330ft - 5.117
660ft - 7.665
1/8th mph - 96.33
990ft - 9.788
1320ft - 11.671
1/4 mpoh - 124.03
Can you add this time to the single turbo list
Simon
  • 2 weeks later...
Time from York raceway today:
11.07 @130.82
60ft 1.5949
Toyo drag sliks 30.0 x 10-15w, BP ultimate @ 1.5 bar. Only got 2 runs in when we swtched ecu to 1.7 bar launch control came in @4500rpm and we could not get it to turn off. We are new to setting and adjusting the Solaris so probably missing some part of the procedure. Its a poor time in relation to the cars potential but 60ft times are getting much better.
11.07 @130.82
60ft 1.5949
Good time Steve, nice 60ft.
Plenty more to come from your set it i'd say ;)
Hey up Gaz, what happened to you for TOTB and Suprapod?
On holiday so can't make either event :(
TOTB was on my list of things to do this year but misses booked holiday instead :rolleyes:
Would have been nice to run at Suprapod also as last year i had to run on 888's after arches killed my MT's :blink:
What you looking for out of your since all mods have been done?
Low 11's? ;)
Steve - brilliant time considering the days events! A 60ft to be proud of :thumbs: wonder what you could manage with radial tyres rather than full on wrinkle wall drag slicks.
Mikey - just need to get the 60ft time down, there's definitely a mid 11 in your setup going by the healthy terminal speed.
Saq - nice result as per your thread, you're on for an 11 with a slightly better launch with your current setup :)
Have updated the times - Steve & Saq, congratulations and welcome to the hall of fame - both of you taking 3rd spot for 60ft time in your respective classes :thumbs:
Thanks for positive comments guys. The track at York had been prepped we launched the car @7500rpm no hint of wheel spin just satdown and went. I don't think radials will give as much grip off the mark, I have a pair of part used 325/50/15s from Kevin Huntley so we will se how they go at Elvington. We will probably use wrinkle walls at Supra pod.
 Share
