Abz Posted February 27, 2012 Share Posted February 27, 2012 Bloody freezing - however had to get them on Looks great imi! I planned on doing the same but was waiting on the weather as it has been freezing! I have speakers & SRD brackets waiting to go on to. Any tips on applying dynamat? I have never done it before & just seen video's of it. Do you need to remove the protective plastic film? Then stick on using a roller to pull out any bubbles? Quote Link to comment Share on other sites More sharing options...
imi Posted February 27, 2012 Author Share Posted February 27, 2012 Sorry Abz, Sextons dyanmatted the doors so I personally am not in a position to offer any advice. I can tell you that it is pretty hard malleable stuff so don't expect it to be that difficult to apply. I am very happy with the end result. The 17cm infinity's 2 ways have really come to life. Quote Link to comment Share on other sites More sharing options...
Abz Posted February 28, 2012 Share Posted February 28, 2012 Sorry Abz, Sextons dyanmatted the doors so I personally am not in a position to offer any advice. I can tell you that it is pretty hard malleable stuff so don't expect it to be that difficult to apply. I am very happy with the end result. The 17cm infinity's 2 ways have really come to life. Ah, if you don't mind me asking, how much did it cost? Feel free to PM me, I would prefer someone who knew what they were doing to do it. Quote Link to comment Share on other sites More sharing options...
imi Posted March 3, 2012 Author Share Posted March 3, 2012 Ah, if you don't mind me asking, how much did it cost? Feel free to PM me, I would prefer someone who knew what they were doing to do it. Hey Abz - I got Sextons to do that for me years ago so not sure how much it cost exactly however didn't break the bank and was well worth it. Quote Link to comment Share on other sites More sharing options...
imi Posted March 21, 2012 Author Share Posted March 21, 2012 Hi All. Need some advice. Current Setup Have my Oil Filter hooked onto a sandwich plate that has an Oil Temp and an Oil Pressure Probe tapped in. New Setup Would like to fit an Oil Cooler with a thermostatic plate. Seems like it is impossible to tap into the plate for the two probes and there is no space to have the two sandwich plates attached together (assuming that was even possible). What is the best way forward? imi Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 21, 2012 Share Posted March 21, 2012 Hi All. Need some advice. Current Setup Have my Oil Filter hooked onto a sandwich plate that has an Oil Temp and an Oil Pressure Probe tapped in. New Setup Would like to fit an Oil Cooler with a thermostatic plate. Seems like it is impossible to tap into the plate for the two probes and there is no space to have the two sandwich plates attached together (assuming that was even possible). What is the best way forward? imi Hi mate, You can have 2 sandwich plates, just need to use a shorter oil filter which we've doing for years with no problems. The other way is to fit one of my oil filter housing removal studs which then allows you to bolt the sandwich plates straight on to the block with a standard length oil filter. Ta Quote Link to comment Share on other sites More sharing options...
imi Posted March 21, 2012 Author Share Posted March 21, 2012 Thanks Paul - having a look at your website for the said parts. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 21, 2012 Share Posted March 21, 2012 Thanks Paul - having a look at your website for the said parts. Give me a shout if you get stuck. Quote Link to comment Share on other sites More sharing options...
imi Posted March 21, 2012 Author Share Posted March 21, 2012 one of my oil filter housing removal studs which then allows you to bolt the sandwich plates straight on to the block with a standard length oil filter. Ta Would prefer to keep the stock oil filter and the stock oil cooler too (if possible). With that in mind would I be able to squeeze in two sandwich plates (one thermostatic and the 2nd with the probes) and the stock oil filter (or is it too tight)? imi Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 22, 2012 Share Posted March 22, 2012 Would prefer to keep the stock oil filter and the stock oil cooler too (if possible). With that in mind would I be able to squeeze in two sandwich plates (one thermostatic and the 2nd with the probes) and the stock oil filter (or is it too tight)? imi No it won't fit mate, well it will if you cut a hole in your chassis leg! Quote Link to comment Share on other sites More sharing options...
imi Posted March 22, 2012 Author Share Posted March 22, 2012 No it won't fit mate, well it will if you cut a hole in your chassis leg! OK. Is this the shallow filter that you mention Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 22, 2012 Share Posted March 22, 2012 OK. Is this the shallow filter that you mention No its not on my website, its made by Defi, unfortunately out of stock and so is my supplier for about a month approx. Quote Link to comment Share on other sites More sharing options...
imi Posted March 22, 2012 Author Share Posted March 22, 2012 No its not on my website, its made by Defi, unfortunately out of stock and so is my supplier for about a month approx. K. I can wait - no rush. can you let me know the cost of the said filter. Thanks. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 22, 2012 Share Posted March 22, 2012 K. I can wait - no rush. can you let me know the cost of the said filter. Thanks. £18 inc VAT. Quote Link to comment Share on other sites More sharing options...
imi Posted March 22, 2012 Author Share Posted March 22, 2012 Thx Paul. Most probably just going to go with the filter option in order to retain the stock oil cooler too. imi Quote Link to comment Share on other sites More sharing options...
imi Posted May 28, 2012 Author Share Posted May 28, 2012 (edited) Hi All, noticed this while washing my car yesterday after being away for 2 weeks. Is this corrosion, what can I do to address this? Thanks imi Edited March 27, 2013 by Littler (see edit history) Quote Link to comment Share on other sites More sharing options...
Supra-duper Posted May 28, 2012 Share Posted May 28, 2012 It does look like the start of corrosion just above the center cap on that picture. Assuming they're diamond cut, I don't think you can do anything to address it short of having the wheel face refurbed by someone like Ibrar of Speedwells. Quote Link to comment Share on other sites More sharing options...
imi Posted May 28, 2012 Author Share Posted May 28, 2012 It does look like the start of corrosion just above the center cap on that picture. Assuming they're diamond cut, I don't think you can do anything to address it short of having the wheel face refurbed by someone like Ibrar of Speedwells. Thats not good anything I can do to protect the other wheels? imi Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 28, 2012 Share Posted May 28, 2012 Keep them under the bed? Fancy wheels are like fancy women, nice to look at but hard work and expensive to keep, and coveted by all and sundry. Quote Link to comment Share on other sites More sharing options...
Jamesy Posted May 28, 2012 Share Posted May 28, 2012 poorboys sealant http://www.polishedbliss.co.uk/acatalog/poorboys-wheel-sealant-cat15.html Quote Link to comment Share on other sites More sharing options...
Supra-duper Posted May 28, 2012 Share Posted May 28, 2012 Not sure if it will help much but I'd recommend using a wheel sealant such as this.. http://www.cleanyourcar.co.uk/index.php?_a=viewProd&productId=9 It may help, and also prevents brake dust sticking as much etc. Quote Link to comment Share on other sites More sharing options...
imi Posted September 23, 2012 Author Share Posted September 23, 2012 (edited) Picked up the car from Lee Yesterday. Good news - Engine gets the all clear from Mr P and so does the Turbo - used some fuel treatment and a few blasts which seems to have done the trick. Oil Cooler fitted with thermostatic plate LeeP's custom Airbox fitted New Brake All Round FULL SERVICE (all fluids) Couple of bits still need to be addressed - will try and drive the car in the meantime in order to report back to Mr P. Thanks again for being a professional and best of luck with the new garage expansion - will look stunning. LeeP = can you PM me or post the results of the engine test. imi Edited September 23, 2012 by imi (see edit history) Quote Link to comment Share on other sites More sharing options...
Abz Posted September 25, 2012 Share Posted September 25, 2012 Sounds good imi! You should bring along to the Grasshopper meet this Saturday. Would be nice to see you & the black widow! Quote Link to comment Share on other sites More sharing options...
Fitz Posted September 25, 2012 Share Posted September 25, 2012 I'd love a ride in this car Quote Link to comment Share on other sites More sharing options...
imi Posted September 25, 2012 Author Share Posted September 25, 2012 Hey Abz - waiting on Lee to advise on whether he needs the car back this weekend, if not then I will try and make it to the event. Its been a while since I have been to one. no worries Fitz - if its dry then we can go out for a spin (not literally I hope) . imi Quote Link to comment Share on other sites More sharing options...
