Go Back   The mkiv Supra Owners Club > Technical > Project Cars
Notices
Closed Thread
Thread Tools Display Modes
Old 10-07-08, 14:55   #1
JamieP
Boost Junkie!
Club Member
JamieP's Avatar
Sales Feedback: 100% (118)
Cool JamieP's New Supra Project!
Picked up my new car today, 6 speed TT with only 34,000 miles, very happy with it, drives so nice.
Body will be staying stock but with a few carbon add ons.
All the spanner work is being done by LeeP @ Supra Racing Developments
Mapping by Ryan at 2bartuning
List of parts i have brought so far and quotes from the manufactures.
Boost Logic T67 dbb .68AR Turbo kit
Quote:
Originally Posted by Boostloglic
# T67 Precision Turbo .68ar
# Boost Logic Ceramic Heat Coated SUS321 Tig Welded Tubular Header
# Tial 44 mm Wastegate
# 4” Stainless Steel 304 Downpipe
# 4” Stainless Steel 304 Midpipe
# 4” Aluminum Intake Pipe
# 2 1/2" Aluminum Intercooler Pipe
# Braided Oil feed and Return Kit with Aeroquip fittings and Lines
# 4" AEM Filter
# K&N Breathers (x2)
# High Quality Silicone Connecters
# Clamps and Miscellaneous items.
# 620-670rwhp
Brembo 6-Piston MonoBlock 14.0'' Big Brake Kit
Quote:
Originally Posted by MVP
Wow, Brembo has done it again! Introducing the finest big brake kit ever made for the Supra!
This newest kit makes use of Brembo’s stiffest cast caliper, the 6-Piston Monoblock. This caliper is found only in Brembo’s High Performance Gran Turismo Kits. The 6-piston caliper distributes forces more evenly with the extra pair of pistons along the bigger pad for a greater swept area to give the driver more modulation, longer pad & rotor life. The monoblock caliper means no bolts holding the caliper together. For the same size it is lighter weight and stronger. This monoblock 6-piston caliper is physically bigger than the F50 4-piston yet it weighs only 0.4lbs. more!!
This 2-piece system rotor system weighs in at a significant weight saving as compared to your stock rotors and calipers.
Boost Logic Front Mount Intercooler
Quote:
Originally Posted by Boostlogic
This the largest intercooler availabe out on the market!! Our front mount intercooler has enough flow to support 1500+ RWHP. Our endtanks are made of 5000 series aluminum alloy and is .125" thick. The intercooler has a 3" inlet and 4" outlet and has 3 support locations on top and 2 on the bottom. Both endtanks come standard fully polished. No cutting is required to fit the intercooler in the car and the stock bumper support does not need to be removed.
HKS TI 4" exhaust
Quote:
Originally Posted by HKS
For extreme horsepower applications, the HKS Racing Muffler system, constructed of 102mm diameter stainless steel piping, a 170mm Titanium muffler assembly and a 115mm tip, is the lightest system and the highest flowing exhaust system HKS has to offer.
Stage 3 RPS Street Max Clutch
Quote:
Originally Posted by RPS
RPS's MAX Series clutch is a perfect for medium duty use like bigger turbos, more boost, and NOS. This clutch will hold 600ftlb of torque
Solaris S6GP
Quote:
Originally Posted by Solaris
Welcome to the home of Solaris. A new breed of high end engine control solutions. Developed from technology used at the highest levels of motorsport, Solaris ECUs provide the user with degrees of control and function previously only available to the motorsport industry.
Our products have been tailored to bring you these high end features combined with the flexibility more road-car biased ECUs offer. http://www.solaris-ecs.co.uk/s6gp.php
DASH2 Display Unit
Quote:
Originally Posted by race-technology
The DASH2 is a slimline, water resistant (IP65) data display system, with a custom LCD screen and a diecast aluminium enclosure for use either as a standalone unit or with our range of data logging products. With configurable display screens, independent alarms and the ability to accept signals from up to six external sensors when used in standalone mode, the DASH2 can be tailored to fit almost any automotive display application. With a suitable ECU adaptor the DASH2 can even receive and display data directly from your engine management system. http://www.race-technology.com/dash2_2_31.html
HKS DLI
The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output
Power Enterprize 800cc Drop In Injectors
Quote:
Originally Posted by Power Enterprise
The most reliable & precise injectors, co-produced with DENSO, Exclusively offered by Power Enterprise and currently used by the WRC, Time Attack & JGTC.
Innovate LM-2 Wideband
Quote:
Originally Posted by Innovate
The LM-2 combines an air/fuel meter, a full function 32-channel datalogger, and powerful software to deliver a complete tuning workshop for less than the cost of one dyno day. Whether you have a piggy-back fuel controller, race carb, aftermarket ECU, OBD-II tuning software, or a flash/chip programmer, an LM-2 is the measurement tool you need to dial in maximum HP.
Tein Super Street coilovers
Quote:
Originally Posted by Tein tech info
Bosch 044 Fuel pump
Quote:
Originally Posted by Thor on the bosch 044
Very high flow pump originally designed for the K-jetronic systems of the Audi rally cars. Supports over 600bhp.
Driftworks oil cooler kit.
Quote:
Originally Posted by Driftworks
This is a complete kit comprising of a -10 19 row oil cooler, -10 oil cooler hoses and a thermostatic sandwich plate with -10 fittings.
Tial 50mm bov
The Tial BOV is the best quality USA-made BOV on the market. The housing is made of 6061 Aluminum and this BOV has a 50mm opening to dispel air through
R7436-9 NGK Spark plugs
Apexi EGT Gauge
Apexi Boost Gauge
Few bits left to get but im getting there, also want to get a uk bonnet vent on it and i have a areo front lip.
I will keep this thread updated with the cars progress.
Good to be back
Boostlogic T67 turbo kit
water line kit
Boostogic FMIC kit
HKS dli
RPS street max clutch
LM-2
Power enterprize 800cc drop in
Apexi EGT Gauge
Apexi Boost Gauge
HKS Ti 4"
Tial 50mm BOV
Silicon pipe
Bosch 044 fuel pump
Clutch release bearing
AEM water/meth kit
Boostlogic Turbo blanket
Solaris S6GP
Greddy intake manifold
Q45 throttle body
JUN cam gears
JUN Camshafts 256/256
Brembo 6-Piston MonoBlock 14.0'' Front and Rear Big Brake Kit
Tein super streets
19" Sienna Generation split rim with Toyo R888 295/30x19 and 235/35x19.
Recaro seats from an evo 8
Bride seat subframes
Carbon spark plug cover
APR carbon rad plate
Tein strut brace
Steering boss kit
Momo steering wheel
Spare 6 speed TT diff
Facelift headlights
DASH2 Display Unit
Fitting Dash2
Clear front and side indicators
Pillar gauge pod
Thor speedo converter
Alpine head unit
Zunsport Front Grille
Geo set up
Leather retrim
Update.... 8/8/2009 managed a 10.9 @ 126mph standing 1/4mile at suprapod today.
Click here to watch JamieP drifting, view from Bignum chase car
Click here to watch JamieP drifting at Llandow 2009
Click here to watch JamieP on track part 1
Click here to watch JamieP on track part 2
Click here to watch Dash2 display
Click here to watch Dyno run
__________________
The Black Beast
850 BHP & 680 ftlb
10.5 @ 138 mph Standing 1/4 Mile
190 MPH Standing One Mile..
Click For My Youtube Page
JamieP is online now
Old 10-07-08, 15:01   #2
JamieP
Boost Junkie!
Club Member
JamieP's Avatar
RPS clutch
Tial 50mm BOV and HKS DLI
LM-2 wideband.
Boostlogic T67 DBB
Boostlogic heat coated manifold
Boostlogic 4" downpipe and mid pipe
Tial wastgate
Lee did a compression test before starting work on the car.
1 - 185
2 - 185
3 - 185
4 - 185
5 - 190
6 - 189
Engine as when he started work on it.
Stock twins removed.
Turbo and exhaust installed.
New brakes
New fuel pump in.
__________________
The Black Beast
850 BHP & 680 ftlb
Old 10-07-08, 15:20   #3
JamieP
Boost Junkie!
Club Member
JamieP's Avatar
Quote:
Originally Posted by kosmic View Post
Very nice mate, Looks mint!! Are you leaving it black?
Staying black.
__________________
The Black Beast
850 BHP & 680 ftlb
Old 10-07-08, 15:25   #4
JamieP
Boost Junkie!
Club Member
JamieP's Avatar
It has UK brakes, they seem good so i will probs stick with them
__________________
The Black Beast
850 BHP & 680 ftlb
Old 10-07-08, 16:40   #5
JamieP
Boost Junkie!
Club Member
JamieP's Avatar
Quote:
Originally Posted by Wez View Post
Do you need a fuel pump
Sure do
Thanks guys, glad to be back in one.
Ive machine polished it 3 times and hand washed it 3 times today, coming up nice now, final hand polish and interior left to do, engine bay is saturdays job
__________________
The Black Beast
850 BHP & 680 ftlb
Old 10-07-08, 17:00   #6
JamieP
Boost Junkie!
Club Member
JamieP's Avatar
Its not very quick yet, still limited to 112mph nice to drive but cant really compare it to the Monaro.
__________________
The Black Beast
850 BHP & 680 ftlb
Old 10-07-08, 17:03   #7
kosmic
What search button?
Club Member
kosmic's Avatar
Sales Feedback: 100% (12)
Quote:
I know theyre world apart but how does say a Single Supra as your previous one compare to the Monaro VXR?
kosmic is offline
Old 10-07-08, 17:05   #8
JamieP
Boost Junkie!
Club Member
JamieP's Avatar
Hard to say, Id guess it would be similar speed to a 550bhp supra.
__________________
The Black Beast
850 BHP & 680 ftlb
Old 10-07-08, 17:33   #9
Mike B
still learning....
Club Member
Mike B's Avatar
Sales Feedback: 100% (5)
Good stuff....
I see you have come over to the dark side... black that is.
I'm very happy with my t67, on a .83 housing though, I'd recommend getting both so you can try it; I have not tried the '68 as I'm more than happy with the '86 and my egt are so low!!!
Supprised you are not tempted to a set of eagle rods.. lighten the engine up a bit...?
also suspension.. you going to make this one handle?
oil cooler?
and what maifold?????
cast?
either way remember to fit a support!
__________________
built vvti 6speed, T67DBB,
will I ever put that spanner down?? Hell no!
Mike B is offline
Old 10-07-08, 18:05   #10
paul mac
quest for road supremacy
Club Member
paul mac's Avatar
Sales Feedback: 100% (17)
nice choice of turbo Jamie, i would say the T67 DBB has to be the ultimate all rounder for a 6 speed, slightly quicker spool than the T88
__________________
93 JDM T61 510 hp
my motor
paul mac is offline
Old 10-07-08, 18:10   #11
JamieP
Boost Junkie!
Club Member
JamieP's Avatar
Quote:
Originally Posted by Mike B View Post
Good stuff....
oil cooler?
cast?
Its a complete Boostlogic kit.
Boostlogic tubular manifold.
Oil cooler is on the list to get and im torn between a CW suspension setup (its just he is so far away) and a coilover kit.
__________________
The Black Beast
850 BHP & 680 ftlb
Old 10-07-08, 18:29   #12
supra matt
almost finished
Club Member
supra matt's Avatar
Sales Feedback: 100% (28)
good to see you back mate and a good solid car to start project on .Also would you not be better of with so nice wide wheels on the back to cope with the power and your driving style lol
__________________
Yes i no i cant spell
supra matt is online now
Old 10-07-08, 18:34   #13
JamieP
Boost Junkie!
Club Member
JamieP's Avatar
Staying stock for now with some R888's
__________________
The Black Beast
850 BHP & 680 ftlb
Old 10-07-08, 18:35   #14
Steve
Posting is my life!
Super Moderator
Steve's Avatar
Sales Feedback: 100% (32)
Jamie, i am happy to lend a hand if needed. Have just fitted the exact same Boostlogic Kit as you are getting
I can recommend the CW suspension setup too
__________________
1/4 ET 11.9070
1/4 MPH 120.81mph
New setup, new times coming soon!
My Garage
Smarter Security Solutions Ltd
Steve is offline
Old 10-07-08, 18:39   #15
JamieP
Boost Junkie!
Club Member
JamieP's Avatar
Any help would be appreciated mate, especially getting the twins off
Gonna start it first week of august
__________________
The Black Beast
850 BHP & 680 ftlb
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
vBulletin - Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 2004 - 2010, The mkiv Supra Owners Club (mkivsupra.net)
