1993 Toyota Supra Aerotop NA-T
Josh42
 Share
Hi all,
As much as I really don't want to do this, a house deposit is a necessary.
Spec as follows:
162,000km
Imported in 2001
3 UK owners
570.9hp, 533lbft @ 1.3bar
Engine
Refreshed OEM GE block (bored, honed)
86.5mm CP forged pistons
Manley H beam forged rods
ARP studs (mains and rods)
ACL race bearings (Mains and rods)
New OEM 2JZ-GTE oil pump
New OEM water pump
New OEM crank pulley
New OEM Valve Stem Seals
New OEM 2JZ-GE Head gasket
ARP Head studs
NEW OEM gasket/seal kit
Air conditioning delete
Transmission and clutch
W58 5 speed manual (rebuilt in 2016)
RPS max clutch with street disc
New OEM release bearing
A01B Torsen LSD
Ignition
NGK BKR7EIX Iridium plugs
New OEM distributor cap
New OEM rotor arm
New OEM HT leads
Brakes
EU Spec Toyota brakes - refurbished with stainless Pistons, pins and clips.
- 4 pot fronts, 2 pot rears
OEM discs and pads
Wheels & Tyres
Fronts - Rota Torque Drift 9.5J ET30 (+3mm spacer)
Toyo T1 Sport 235/40/18
Rears - Rota Torque Drift 9.5J ET30
Toyo T1 Sport 255/35/18
Suspension
HSD dualtech adjustable coilovers
Whiteline adjustable FR/RR ARB
New OEM front & rear stabiliser bar links
Fuelling
Walbro 255lph Fuel pump
New OEM fuel filter
Fuel pulsation damper bypass hose
Siemens DEKA 650cc Injectors with plug & play harnesses
ECU & Sensors
AEM V2 Standalone ECU
AEM 3.5bar map sensor
AEM UEGO wideband kit
Greddy OLED Electronic Boost Controller
Turbo & Intake
BorgWarner S360 0.88 undivided T4 Flange
Garage Whifbitz 4" Intake
K&N 4" Cone filter
Turbosmart Hypergate 45mm wastegate
Toyosports 3" FMIC core
Custom 2.5" FMIC pipework
Exhaust
3" HKS Hi Power Silent catback exhaust
3" Garage Whifbitz second decat
3" Garage Whifbitz downpipe with flexi section fitted
Garage Whifbitz external screamer pipe
Garage Whifbitz NA-T log manifold
Interior
Black leather electric seats
Black headlining
Black carpet
Dash panels refurbished to OEM finish
Exterior
OEM 3L2 Renaissance Red (resprayed June 2013)
OEM Active spoiler (blade only)
Facelift front indicators
Clear side markers
Facelift rear lights
Facelift front headlights
Roof seals replaced
Full Carbon TRD spoiler with sides body coloured
APR Carbon cooling panel
6000k HID dipped beam
Price is £13500 OVNO
Please feel free to ask any questions.
[ATTACH]217637[/ATTACH]
[ATTACH]217638[/ATTACH]
[ATTACH]217640[/ATTACH]
[ATTACH]217641[/ATTACH]
[ATTACH]217642[/ATTACH]
[ATTACH]217643[/ATTACH]
[ATTACH]217644[/ATTACH]
[ATTACH]217646[/ATTACH]
That looks gorgeous, can't see this hanging around!
Cheers mate, fingers crossed - I'm hoping it doesn't before I change my mind.
Lovely car Josh, good luck with the sale mate.
Cheers Mike, not through choice really, more of a necessity im afraid
Thank you all for the very kind comments.
I REALLY don't want to sell the car. I've finally got it to the spec/state where I'm happy with it, but a house is a necessity now.
If there was any other way, I would make it work:(
 Share
