BREAKING - J-Spec TT6 45000 miles - V160 & Engine still available
r0cknr0lla
 Share
Hi All,
Breaking a 199 1993 TT6 with very low miles (45000) and MOT history to validate this..
All parts available apart from the ones listed in the first section (I will update this as I go to let you all know). All parts are excluding postage and are based in Haywards Heath.
The car has done around 800 miles since entering the country in 2006 and has had two UK owners. Drives like a dream and pulls like a train but nearly all parts need cleaning up from being sat for a while. Nothing a lick of paint cannot cure.. I would advise new seals around the motor as a precaution although there is absolutely no smoking at all though and shocked me how well it pulled when collecting it.
Pic of the car...
Everything not in the first section is still available so if not listed please ask...
Parts sold so far:
Big case LSD
Bonnet Latches
Front wings
Veilside Bonnet
Rear shock plastic covers
Boot carpet
Drivers side A-Piller trim
Front Arch liners
Window regulators
Front seats
Scuttle panel Seal
Hubs with sensors
Door cards
Armrest
Speaker surrounds
Front Valance
Greddy Oil Cap
Under tray
battery Clamp & tray
Dashboard
Fan Shroud
Tail lights
Window strips
Rear bench
Manual Dials
Momo steering wheel
Carpet
Dash panels
Boot foams & tools
Boot latch panel, two side plastic panels & rear quarter window panels
Side mirrors
Glass Headlights
J-Spec brakes
Exhaust
Front wiper arms
Upper Glove box
Wheels
Rear Badge
Air intake
Throttle Cable
J-Spec number plate holder
Shell with frames and arms
Doors
Side windows
Chrome SMIC Pipes
Steering cowl
Front upper intake
Parts still available:
V160 6 speed gearbox (Incl ECU, mount member & shifter) SSOLD
Rear prop shafts £200
Non VVTI TT engine & all ancillaries, loom & ECU SOLD
Accelerator Pedal £40
Engine bay Loom £150
Dash Loom £60
Front crash bar £45
90 deg Boot plastics from above shock covers £60
Grey Headlining and visors £45
OEM clutch & Flywheel SOLD
Radiator & Fan SOLD
REP Veilside Body kit (front bumper & wing) £200
Pre-facelift Indicators £15 Each
Glovebox (lower) £40
Scuttle panel £90
Centre brake light £50
Door Sill trims £15 Each
Passenger Inner sill plastic trim / Carpet edge trim £15
OEM Din cage with single din radio & Single din tray SOLD
Active spoiler setup without blade (Incl ECU & a non oem switch) £180
OEM Rad pipes (Upper & Lower) £40
Veilside Gear knob SOLD
Aerial £25
Fuel tank cover SOLD
Pics to follow...
No dibs please.. money talks. Please refrain from commenting if you are not interested in buying anything..
Anything not listed please shout..
Cheers all.
  • Replies 148
Door cards are immaculate apart from drivers side right at the bottom as its fraying from shoes scuffing.. can be cleaned up though and hardly noticeable. Unfortunately on pic of passenger side atm..
PM sent!
What the carpet like, any holes or wear marks? pictures? what cost do you think to post that.
Carpet is all good Ric, Will be dying it when its out. No tears etc in it.
I can fold it up but its pretty heavy mate so will have to check postage
Does the Battery clamp come with the metal rod that it bolts on to. If yes Ill take it please. Also do you have the heater controls and how much. Cheers
Yeah Ill send that along mate no problem..
Controls I am keeping I'm afraid :-)
- - - Updated - - -
Bootlid?
Boot lid in a bad way bud, Used epoxy to fit the rear wing and has rust around the windscreen.. you can have it FOC if you want it.
 Share
