2Bartuning Track Car - One off and only done 1450 Miles
Ryan.G
 Share
Here is a chance to own a fully chassis rebuilt and track prepared Supra.
Built in 2009/2010 by Autotec2004 and 2Bartuning (Ryan.g).
The concept of this car was to make the Supra as light as possible in track based trim and completely balanced. To achieve this most of the original chassis was removed and rebuilt using lighter T45 (aircraft grade) chromoly tubing. Whilst rebuilding the chassis we decided that the engine could be moved back 15inches, which would make the supra as close as possible to being 50/50 weight distribution.
The whole build was documented and posted below to see the level of care, safety and workmanship which was involved.
http://www.mkivsupra.net/vbb/showthread.php?170424-Supra-Track-Car-Project
I could talk for days about this car but its best to grab a seat and read the whole of the project.
To summarise the build in pictures for those who don’t want to read the whole project thread see below.
One black TT Stripped
All Shell structures are lightened
Mock up of engine fitment
Chassis remade to suit engine placement
Chassis Skinned in Aluminium
Engine Mounts and Prop remade
V Mount Rad and Intercooler setup made
New Lightweight and collasable Nascar steering column made
Ohlins Rebuilt by Chris Wilson
Bonnet remade to suit V mount setup
Chassis put on spit and primed
Sprayed
All sub frames strengthend
Panels, suspension and brakes added
Head rebuilt and worked by Swindon race engines
Chassis all back together
Engine back in and mapping
Tilton pedal box added
Car took to airfield for testing, setup and weighing
Car as it looked in 2010
New turbo added and engine bay finished off
Where all weight was lost in build we needed to add more downforce so wing and other aero parts added, Also replace roof scoop with carbon roof
Flat floor was designed for more downforce and exhaust system was redesigned
Engine Spec:
3.0 2JZGTE
Full Race Head built by Swindon race engines – See build thread for more info
HKS 264 Cams
ARP Head Bolts
New - Toyota Head Gasket, Oil pump, Water pump and full engine gasket set.
Borg Warner 91/79 Turbo
Custom Manifold and down pipe
50mm Tial V Band wastegate routed back into downpipe
Custom air filter
V Mounted Intercooler and Radiator with alloy expansion tank.
Thermal protection intake manifold gasket
800cc PE Injectors
RPS Lightened flywheel
RPS Street Max Clutch
-8 Braided fuel lines throughout
Bosch 044 after swirl pot with walbros in tank for pickup
Engine produces 600bhp and 550ftlb at 1.5bar. Can be tuned to 1.8bar on new owners request but 600bhp is more than enough to get used to car.
Electronics:
Syvecs S6GP with full knock:
Wideband Knock
Wideband Lambda
Oil Pressure
Oil Temp
EGT
Fuel Pressure
Crankcase pressure
Individual Wheels speeds Used for full traction control part of S6
2 x Cal switches for Changing engine power, traction level
Race Technologies Dash2
Race Technologies DL1 Datalogger all link via can to dash and ecu
Chassis:
Tilton Pedal Box with braided lines throughout car
Custom lightweight steering rack with NASCAR collapsible unit for safety
Sparco Race Steering wheel with removable hub
4 Pot Front Brakes
6 Pot Rear KAD Brake
Portford R4 Pads
New Toyota Discs
Titon Anti roll bars
Ohlins 2 way adjustable suspension
Custom built 40litre fuel tank with external swirl pot and Bosch 044 pumps
Full GT Carbon Wing
Full Alu Flat floor with custom diffuser
Cobra Bucket seats with TRS Harnesses
Custom Front F40 Splitter
Toyota OEM Sideskirts and Spats
Complete alu flat floot
Enkei Light wheels with R888
Lexan Windows
Front and Rear tow points
Carbon Roof
And much more which i just cant think of!!
Car is priced at £25,000
Forgot to say this car is FULLY ROAD LEGAL AND HAS MOT :)
:blink:
That is just insane! This is the ultimate track machine!
I saw this at a Wheels Of Motion meet, it is a stunning machine :cool:
Ryan, do you know what the power to weight ratio is?
  • 2 weeks later...
 Share
