Idiots guide to changing rear speakers
paulj1
Pretty much exactly as Dim Sum mentioned, the cover is very easy to take off with a butter knife or flat head.
Then I remember mine had 4 screws and the usual two wires. Once you take off the cover you'll have a better understanding :)
Refit with a rolling pin maybe? :D
  • 2 months later...
I have briefly attempted to remove my rear speakers but it's too wet and dark to keep trying. I have removed the 4 screws from the drivers rear speaker but the speak isn't moving at all. It's like stuck. Do I need to give it a real good pull or do anything else?
There is a bit of glue holding it in place.
Just pry it off and all will be fine
