jza800 Posted June 21, 2014 Share Posted June 21, 2014 I have done a compression test on my 2jzgte, i have 150 psi on all 6 cyl. dont think thats is good.. and on 4 off 6 sparks plug it was soaped in oil, do i have a headgasket fault or is my piston rings worn??? Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 21, 2014 Share Posted June 21, 2014 150 is fine on the gte . youl prob find the oil is dripping from the cam cover gaskets , very common Link to comment Share on other sites More sharing options...
jza800 Posted June 21, 2014 Author Share Posted June 21, 2014 no oil from the cam covers, they are toal dry... i could see that my pistons was wet on the top off the pistons on those cyl that had oil on the spark plugs, and what i think is oil.. Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 21, 2014 Share Posted June 21, 2014 is the car smoking? if the rings are worn allowing oil past it will be smoking. and I doubt youd have 150psi per cylinder. is the car using oil? Link to comment Share on other sites More sharing options...
jza800 Posted June 21, 2014 Author Share Posted June 21, 2014 the car dont smoke, and it dont use oil, it only use i Little Water... Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 21, 2014 Share Posted June 21, 2014 doesent over heat or over pressure the system? Link to comment Share on other sites More sharing options...
jza800 Posted June 21, 2014 Author Share Posted June 21, 2014 no it dosent overheat, and it dont seems like it over pressure the system.. Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 21, 2014 Share Posted June 21, 2014 don't worry then . clean it up put it back together and enjoy. Link to comment Share on other sites More sharing options...
jza800 Posted June 21, 2014 Author Share Posted June 21, 2014 no, oil in cyl is not normal.. Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 21, 2014 Share Posted June 21, 2014 it would have fallen through when you took the plugs out. if it was getting into the combustion chamber when the car was running youd know. Link to comment Share on other sites More sharing options...
Nic Posted June 21, 2014 Share Posted June 21, 2014 Why did you do a compression test, was there a problem? Are you sure it's oil, not just carbon build up and a little petrol? Link to comment Share on other sites More sharing options...
jza800 Posted June 21, 2014 Author Share Posted June 21, 2014 because the car use Water, so i did a compression test to see if i had a headgasket fault, then i did see that i had 4 spark plugs that so soaped in oil and the rest 2 was dry.. yes i am positiv that it is oil, as it smells like oil.. Link to comment Share on other sites More sharing options...
safcdixon Posted June 21, 2014 Share Posted June 21, 2014 When i changed my plugs the other week they had oil on them aswell, but they have everytime ive changed the plugs for the last 4yrs, mine uses no water at all, i dont think the oil on the plugs has anything to do with your water loss problem. Check your core plugs for weaping Link to comment Share on other sites More sharing options...
wile e coyote Posted June 21, 2014 Share Posted June 21, 2014 If worried about head ghen have a snif test done Link to comment Share on other sites More sharing options...
Swampy442 Posted June 21, 2014 Share Posted June 21, 2014 150 on all 6 cylinders is fine. Was the oil on the outside of the plugs, i.e. the part not in the cylinder? Might be leaking cam cover gaskets. Link to comment Share on other sites More sharing options...
Fizzy T Posted June 21, 2014 Share Posted June 21, 2014 I have the same thing but I'm not really worried about it, Mine is on the last two spark plugs furthest to the rear of the engine. It's a failed cam cover gasket, slight oil seepage is getting to the top of the spark plugs on mine so it was only on the threads when I took the plugs out. It wasn't inside the chamber and on the elements. Link to comment Share on other sites More sharing options...
shaz2010 Posted June 23, 2014 Share Posted June 23, 2014 Would oil on the plugs off a Leakey cam cover gasket cause the car to smoke at all ? Link to comment Share on other sites More sharing options...
safcdixon Posted June 24, 2014 Share Posted June 24, 2014 Would oil on the plugs off a Leakey cam cover gasket cause the car to smoke at all ? Aslong as it wasnt getting past the plugs into the cylinders no, if you have a slack plug it might a but it wouldnt be enough oil to be seeable imo it would be such a small amount it woukd burn off very quickly Link to comment Share on other sites More sharing options...
The Raven Posted June 24, 2014 Share Posted June 24, 2014 Both me N/As had the same both down to failed cam cover gaskets. It showed no signs of smoke or anything else wrong with it Link to comment Share on other sites More sharing options...
