ballsdeep Posted May 15, 2014 Share Posted May 15, 2014 (edited) I'm struggling to locate a knock sound, I can only hear it inside the car and it sounds like its from under the passenger foot well? I can make it knock by tapping the accelerator peddle just enough for the rpm to raise a bit, but it doesn't seem to be there while driving. Any ideas guys hopefully someone else has experienced this? Edited May 29, 2014 by ballsdeep (see edit history) Link to comment Share on other sites More sharing options...
mellonman Posted May 15, 2014 Share Posted May 15, 2014 maybe engine mount hard to say though, engine mounts noramaly have a vibration through the cab at idle Link to comment Share on other sites More sharing options...
ballsdeep Posted May 15, 2014 Author Share Posted May 15, 2014 Engine mount was my first thought but I haven't noticed any vibration other than last week I though i could feel a bit through the gear stick but put it down to the road? Any tests I can do to rule this out! Link to comment Share on other sites More sharing options...
SupraLEDrears Posted May 15, 2014 Share Posted May 15, 2014 Crankshaft pulley test? Mine disintegrated last week so worth checking anyhow Link to comment Share on other sites More sharing options...
Tyson Posted May 15, 2014 Share Posted May 15, 2014 Engine mount was my first thought but I haven't noticed any vibration other than last week I though i could feel a bit through the gear stick but put it down to the road? Any tests I can do to rule this out! Gearbox mount ? Link to comment Share on other sites More sharing options...
ballsdeep Posted May 15, 2014 Author Share Posted May 15, 2014 Crankshaft pulley test? Mine disintegrated last week so worth checking anyhow Gearbox mount ? Good call, it's been a while since I last checked the crank pulley and I know the gearbox mount rubbers are not the best! Link to comment Share on other sites More sharing options...
ballsdeep Posted May 29, 2014 Author Share Posted May 29, 2014 Picked up on something today, may be nothing but any info I can give you guys might help me identify what this worrying noise is and my jerky throttle response? So here's a short video unfortunately the knock can't be heard but what you can see is as I'm very gently raising the rpm to 1k the needle suddenly jumps a couple of hundred rpm? May or May not be linked but certainly doesn't help with cruising and causes a jerky acceleration but only at take off. http://youtu.be/E2NTCbT9BFU The knock I can hear it at 1000rpm - idle and 8/900rpm - when rolling in 1st gear while gently increasing speed? Link to comment Share on other sites More sharing options...
ballsdeep Posted July 1, 2014 Author Share Posted July 1, 2014 (edited) I still have this knock issue and can't for the life of me find where it's coming from? I checked the crank pulley but the tip ex marks from the last test are still there so ruled this out. It literally happens every time I press the accelerator one single knock? The car runs fine, boosts fine apart from one small issue with a very slightly jerky accelerator feel when getting on and off but Could this be down to a slightly out tps? Any more ideas? Edited February 23, 2015 by ballsdeep (see edit history) Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 1, 2014 Share Posted July 1, 2014 Check the torque on the crank pulley bolt, the Tipex test only shows de-lamination, it won't show a pulley that's loose on the crank. if it is loose it needs removing and the keyway examining in the pulley and in the crank. Link to comment Share on other sites More sharing options...
ballsdeep Posted July 1, 2014 Author Share Posted July 1, 2014 Think I might move to Shropshire really wish I could just drop the car off to you and be done with it. What should it be torqued too? Link to comment Share on other sites More sharing options...
Dnk Posted July 1, 2014 Share Posted July 1, 2014 243 ft lbs or 330 nm Link to comment Share on other sites More sharing options...
ballsdeep Posted July 1, 2014 Author Share Posted July 1, 2014 243 ft lbs or 330 nm Link to comment Share on other sites More sharing options...
Ian C Posted July 1, 2014 Share Posted July 1, 2014 what should it be torqued too? ft Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 1, 2014 Share Posted July 1, 2014 Ahh, yes, FT, the torque figure that even precedes Imperial figures Sometimes called 6 foot tube tight. Link to comment Share on other sites More sharing options...
ballsdeep Posted February 23, 2015 Author Share Posted February 23, 2015 iv ignored this for a while but it's time to get to the bottom of this! crank pulleys been off and on while the water pump was done and it looks like new! Torqued up and its still there. I'm just wondering if there's any evidence of flywheel or clutch knock? But mainly Im wondering if there's any tests I can do to see if it's the gearbox or engine mounts knocking? Link to comment Share on other sites More sharing options...
Tyson Posted February 23, 2015 Share Posted February 23, 2015 did you ever check the gearbox mounts ? Link to comment Share on other sites More sharing options...
TheTurtleshead Posted February 23, 2015 Share Posted February 23, 2015 Take the auxiliiary pulley off, run the car briefly and see if it's still there. Link to comment Share on other sites More sharing options...
ballsdeep Posted February 24, 2015 Author Share Posted February 24, 2015 did you ever check the gearbox mounts ? I'm not exactly sure what to look for? Any guidance Take the auxiliiary pulley off, run the car briefly and see if it's still there. Link to comment Share on other sites More sharing options...
trebor69 Posted November 8, 2015 Share Posted November 8, 2015 Did you get to the bottom of this? Link to comment Share on other sites More sharing options...
Ian C Posted November 10, 2015 Share Posted November 10, 2015 If not, check your cambelt is tensioned Mine made a rattley-knock when lifting and dropping revs, the tensioner was totally shot Link to comment Share on other sites More sharing options...
ballsdeep Posted November 10, 2015 Author Share Posted November 10, 2015 Sorry I forgot to update, the good news is its running smooth again with no knocking but Im afraid I can't comment on what was causing it to knock but the throttle response issue I think was down to the incompatible or duff iat sensor that I was using (aem). So I Resorted back to the na oem one and had it remapped again. If I remember rightly the tps was slightly out so I reset it and had the map tweaked because I had to put a new e-manage in, that's when the knock stopped, then lately iv just removed the aem iat sensor and put the na one back in and opted for a full remap again from tuning developments which resulted in it making slightly more power from 370 to 385bhp and more importantly it drives better! Link to comment Share on other sites More sharing options...
