JayJay1374 Posted March 17, 2014 Author Share Posted March 17, 2014 Collected a set of recaros today. From an import integra type r. Mint condition and local too! Just need to either fit them to the standard subframes, get some made or try and find a set forsale. Link to comment Share on other sites More sharing options...
JayJay1374 Posted March 23, 2014 Author Share Posted March 23, 2014 Progress! The engine is in! What a nightmare. It really didn't want to go back on the mounts, after a lot of jiggling and repositioning it eventually went in. Mounts bolted up. Gearbox all bolted up and propshaft bolted up. Link to comment Share on other sites More sharing options...
JayJay1374 Posted March 24, 2014 Author Share Posted March 24, 2014 Tonight I got the exhaust bolted up, a/c and piwersteering pumps bolted on, aux belt on, loom back in and under the dash, fuel lines on. Not much left now Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 14, 2014 Author Share Posted July 14, 2014 (edited) I haven't updated this for a while...... After getting the engine in and everything pumbed up it wouldn't start. A visit from hodge diagnosed the valve timing being out. After hours of repeatedly taking shims out, swapping them round. Re measuring. Fitting new shims it all went back together and the compression was tested. And was all good. Fuel pump fuse back in. First turn of the key and she started straight up. Running better than ever. Last job was bleeding and adjusting the clutch pedal then she was back on the road. New steering wheel and snap off boss fitted. Recaros in the car mounted. Awesome seats. So comfy Also managed to find a mint manual gear surround and set of dash panels which I got painted up in White again. Since the rebuild I did 1000 miles running in period and all went well. Even attended a few shows and meets. Aswell as getting the private reg on. Edited July 14, 2014 by JayJay1374 (see edit history) Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 14, 2014 Author Share Posted July 14, 2014 Also attended the NE rolling road day at evotune in Durham. Rolled 368.9 @1 bar. Link to comment Share on other sites More sharing options...
DaveR Posted July 14, 2014 Share Posted July 14, 2014 Nice thread, matey, I've only just seen it. I like the success stories! Link to comment Share on other sites More sharing options...
JackyBoi Posted July 14, 2014 Share Posted July 14, 2014 Awesome car, reminds me a bit of my one Link to comment Share on other sites More sharing options...
Krister Posted July 14, 2014 Share Posted July 14, 2014 Any reason you didnt put aftermarket rods while you had the engine apart? The rods are the limiting factor on these engines and a set of Eagle rods are only around 350GBP and they can handle up to 1000hp. Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 14, 2014 Author Share Posted July 14, 2014 I couldn't afford rods at the time. I was bone skint whilst rebuilding the engine. In the future if I do go for more power I'd happily pull the engine out and strip it again as it was actually quite a nice job. Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 14, 2014 Author Share Posted July 14, 2014 Nice thread, matey, I've only just seen it. I like the success stories! Awesome car, reminds me a bit of my one Thanks lads. There's no feeling better than starting an engine you rebuilt yourself. Link to comment Share on other sites More sharing options...
MattP Posted July 14, 2014 Share Posted July 14, 2014 I didnt even notice you changed the seats lmao Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 15, 2014 Author Share Posted July 15, 2014 I didnt even notice you changed the seats lmao Cheers mate. You only see the car nearly every week haha. Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 15, 2014 Author Share Posted July 15, 2014 I had a look down my unit last night and eventually fitted my new smoothed bumper with lip. Then when I started the car to leave I noticed oil leaking quite badly from the front crankshaft oil seal. Not happy. It's only lasted 2500 miles since the rebuild. Looks like I will be heading to toyota to order another one today. Gonna have to cancel the wheel alignment I had booked. Link to comment Share on other sites More sharing options...
safcdixon Posted July 15, 2014 Share Posted July 15, 2014 Looks loads better mate! No way on the crank seal Jonny you have some pretty crappy luck dude Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 15, 2014 Author Share Posted July 15, 2014 Tell me about it mate. It did weep a little after the rebuild. Then it stopped after about 300 miles. I assumed that it was just getting seated right. Last night it ran for about 5 mins and left a 20cm puddle. It was quickly dripping onto the arb then off. Link to comment Share on other sites More sharing options...
supra_ufo Posted July 15, 2014 Share Posted July 15, 2014 nice one mate, should have the video uploaded after work, ive managed to upload Shaz's Love the seats, they felt real comfy well done on bringing it back to life Link to comment Share on other sites More sharing options...
TheTurtleshead Posted July 15, 2014 Share Posted July 15, 2014 Tell me about it mate. It did weep a little after the rebuild. Then it stopped after about 300 miles. I assumed that it was just getting seated right. Last night it ran for about 5 mins and left a 20cm puddle. It was quickly dripping onto the arb then off. You most likely pushed the seal in too far, (Standard supra problem). Needs to be flush with the front face of the oil pump and no more or you'll block the oil drain just behind the seal. That, or you've scratched the sealing surface/it has an age related groove worn into it. Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 15, 2014 Author Share Posted July 15, 2014 nice one mate, should have the video uploaded after work, ive managed to upload Shaz's Love the seats, they felt real comfy well done on bringing it back to life Thanks mate. Shaz's video looks awesome! Thanks for filming on the day. Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 15, 2014 Author Share Posted July 15, 2014 You most likely pushed the seal in too far, (Standard supra problem). Needs to be flush with the front face of the oil pump and no more or you'll block the oil drain just behind the seal. That, or you've scratched the sealing surface/it has an age related groove worn into it. Thanks mate. I will have to investigate when removing the old seal. Will take a lot more care this time around. It's a new oil pump so there shouldn't be any marks on the seal surface but you never know. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted July 15, 2014 Share Posted July 15, 2014 Thanks mate. I will have to investigate when removing the old seal. Will take a lot more care this time around. It's a new oil pump so there shouldn't be any marks on the seal surface but you never know. Seal surface is on the crank not the pump Although you can also damage the face on the pump. Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 15, 2014 Author Share Posted July 15, 2014 Well I will check everything. Should have it sorted by the weekend. Link to comment Share on other sites More sharing options...
MattP Posted July 15, 2014 Share Posted July 15, 2014 Your not the only one with issues Im stripping this car back as we speak :/ I dont think We will be getting to Scottish Modified Link to comment Share on other sites More sharing options...
MattP Posted July 15, 2014 Share Posted July 15, 2014 Do you get your parts from a rep called Michael Gott at Durham Jay? Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 21, 2014 Author Share Posted July 21, 2014 Yeah either him or alannah. He always gives discount! Link to comment Share on other sites More sharing options...
JayJay1374 Posted July 21, 2014 Author Share Posted July 21, 2014 Well what a weekend. Mega busy! Repainted my ukspec brake all round with new decals. No pictures. Went and picked up a 97tt auto in RSP! Bought with the intention of either breaking it or fixing it. Also fitted my new crankshaft oil seal. Also robbed the imaculate headlights out of the RSP. I need to get under it properly but the rear subframe is bent but I'm just worried it's bent the body mounts. The car crabs terribly! Link to comment Share on other sites More sharing options...
