JamieP Posted February 8, 2014 Share Posted February 8, 2014 Can somebody with a facelift TT6 upload a picture of the speedo cluster for me please. Thanks Jamie. Quote Link to comment Share on other sites More sharing options...
Ian C Posted February 8, 2014 Share Posted February 8, 2014 Â Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 8, 2014 Author Share Posted February 8, 2014 Perfect, so that's turbo pressure at the top, Is that 1 bar? I was just looking at my NA clocks, I have the volt gauge there, I was thinking I could put a black 52mm boost gauge there instead, I want to keep it looking OEM but with the only addition of a decent boost gauge. Quote Link to comment Share on other sites More sharing options...
kitch79 Posted February 8, 2014 Share Posted February 8, 2014 I wonder why that pic is called "don't try this" :-) Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 8, 2014 Share Posted February 8, 2014 Perfect, so that's turbo pressure at the top, Is that 1 bar? I was just looking at my NA clocks, I have the volt gauge there, I was thinking I could put a black 52mm boost gauge there instead, I want to keep it looking OEM but with the only addition of a decent boost gauge. I've often thought about this too, if you could get it to fit behind the dash panel it would look fantastic (especially if the illumination matches the others.) Quote Link to comment Share on other sites More sharing options...
Hassan Posted February 8, 2014 Share Posted February 8, 2014 I wonder why that pic is called "don't try this" :-)Â Maybe because he is doing over 150mph Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 8, 2014 Author Share Posted February 8, 2014 I've often thought about this too, if you could get it to fit behind the dash panel it would look fantastic (especially if the illumination matches the others.)Â Would be close I think, the hole is about 50mm, I will get it apart for a look when I get time. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 8, 2014 Share Posted February 8, 2014 The issue will be the 'dash pod', that contains the gauges and sits behind the dash panel. It's all one peice, and removing part of it may prove to be impossible. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 8, 2014 Author Share Posted February 8, 2014 Ahh I see, don't really want to lose the clock. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 8, 2014 Share Posted February 8, 2014 Did you think the 'triple gauge cluster' (volt, temp, fuel on an NA) were individual gauges? Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 8, 2014 Author Share Posted February 8, 2014 I've never pulled a facelift dash apart before, I'm still going to look at it, I might be able to get one in there, even if it's flush with the front that's fine. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 8, 2014 Share Posted February 8, 2014 Without removing part of the Gauge pod/cluster, there won't be room. To be fair, it's been a few years since I last looked at one, but I'm pretty certain. Â Unless you can get something digital? Quote Link to comment Share on other sites More sharing options...
listy Posted February 8, 2014 Share Posted February 8, 2014 Could you not pull them all out and replace them with slim line aftermarket gauges? I know one of them is fuel, but you must be able to get an aftermarket fuel gauge surely? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 8, 2014 Share Posted February 8, 2014 Could you not pull them all out and replace them with slim line aftermarket gauges? I know one of them is fuel, but you must be able to get an aftermarket fuel gauge surely? This is the problem: Quote Link to comment Share on other sites More sharing options...
listy Posted February 8, 2014 Share Posted February 8, 2014 Ah I see.....I thought there may have been a way to just replace those gauges. Evdently not Doesn't look good JP Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted February 8, 2014 Share Posted February 8, 2014 Yes as above your not going to be able to do it would have to be clock or vent im afraid unless you get a tt cluster Quote Link to comment Share on other sites More sharing options...
Ian C Posted February 8, 2014 Share Posted February 8, 2014 The boost gauge is also fairly pointless, it kinda registers positive boost at a very low amount and that's about it. Quote Link to comment Share on other sites More sharing options...
Littler Posted February 8, 2014 Share Posted February 8, 2014 Not sure if they do a facelift version but you could go the phr route? Â Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 8, 2014 Share Posted February 8, 2014 Ah I see.....I thought there may have been a way to just replace those gauges. Evdently not Doesn't look good JP Â I don't know, removing the lens and needle from the stock boost gauge may create enough room to fit a small, shallow digital boost gauge. I personally prefer analogue boost gauges myself though. Â Also, someone could test what happens when the cable ribbons are removed that connect the various gauges to the pcb. If that works, it may be possible to cut the boost/voltage gauge from the stock instruments. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 8, 2014 Author Share Posted February 8, 2014 Not sure if they do a facelift version but you could go the phr route?  http://img.tapatalk.com/d/14/02/09/8u4eze4y.jpg Does look good, more money than I want to spend though. Quote Link to comment Share on other sites More sharing options...
Abz Posted February 8, 2014 Share Posted February 8, 2014 Jamie I have been looking into doing something similar with mine, not sure if a boost gauge would fit but have seen an oil pressure/temp gauge in there. I'll be looking further into soon. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 8, 2014 Share Posted February 8, 2014 It looks as if the bezel could be cut down at the back too, creating approx. 25mm. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 8, 2014 Author Share Posted February 8, 2014 That looks good Abz, I don't want a digital screen though, Boost gauge is the only gauge I want, Syvecs can look after everything else. I think I will just put one in place of the clock, I've got a watch after all. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 8, 2014 Share Posted February 8, 2014 Perhaps you could mount a digital boost gauge in there? Â This one is made to replace the stock boost gauge in an MR2, it's made by US company VEI Systems http://www.veisystems.com/products/Â http://www.emspowered.com/storefront/index.php?main_page=product_info&cPath=61_62_64_74_75&products_id=208 Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 8, 2014 Author Share Posted February 8, 2014 I just want it looking stock Nic, it don't want a digital display. Quote Link to comment Share on other sites More sharing options...
