AndrewOW Posted January 16, 2012 Share Posted January 16, 2012 (edited) I'm now producing the Supra active spoiler manual override modules. This module fits on to the active spoiler ECU plug and switch, with an easy to follow guide, and allows you to have full control over the positioning of the front spoiler on the fly. I've had quite a lot of interest, I thought it would be easier to update my initial post with the main details. Has your car got the active spoiler in place, and it functions normally? The module enable you to fully control the positioning of the active spoiler, either up, down or somewhere in between. Once this is installed, there is no auto setting, so you will have to remember the position for speed bumps, etc. The left button on the switch is Off/Up, and the right button allows you to control the Down position. I can provide either a standard fitment which just plugs into the ECU plug behind the dash, or if you need the full loom, which goes through the bulkhead to the active spoiler motor near the driver's headlight. I've redesigned the module to be easier to fit, and using colour coded wires, which should make the fitting an easy process. (If I can fit it, then anyone can!) I will provide full fitting instructions on an emailed PDF, which should be simple to follow, or please use an auto electrician to fit it for you. The standard version (without loom) costs £55 plus postage, and the full loom version costs £65 plus postage (this is mainly for foreign postal costs, and for the UK, £10). If you're interested, then please contact me. Well, I thought I would provide a quick snap of the override module to show what it looks like, and hope it doesn't look too complicated to install. I provide full installation instructions too. Standard version Full loom version And a few videos of it in action: Edited November 21, 2014 by AndrewOW Update. (see edit history) Link to comment Share on other sites More sharing options...
BOB B Posted January 16, 2012 Share Posted January 16, 2012 This is a good bit of kit, it gives you full control over the spoiler, up for lumps down for looks, great. Link to comment Share on other sites More sharing options...
tony tt Posted January 16, 2012 Share Posted January 16, 2012 How much would it be Andrew? I quite like the spoiler down all the time and just raise it for speed bumps etc Link to comment Share on other sites More sharing options...
Scott Posted January 16, 2012 Share Posted January 16, 2012 Did the mods authorise this group buy? Link to comment Share on other sites More sharing options...
ellis Posted January 16, 2012 Share Posted January 16, 2012 I'd like another one as mine does play up when the car is hot for some obscure reason! Link to comment Share on other sites More sharing options...
AndrewOW Posted January 16, 2012 Author Share Posted January 16, 2012 Did the mods authorise this group buy? This is not a group buy, just a little promotion of this product. I'd like another one as mine does play up when the car is hot for some obscure reason! Strange. I've redesigned Garfy's module to make it easier to fit, and is constructed better than previous, so maybe a new one may work better for you. Link to comment Share on other sites More sharing options...
ballsdeep Posted January 16, 2012 Share Posted January 16, 2012 can this be made to work without having the loom, only reason im asking is im not 100% sure its there.. Link to comment Share on other sites More sharing options...
AndrewOW Posted January 16, 2012 Author Share Posted January 16, 2012 I can provide a version that includes the loom to the motor, which means you can connect it directly to the switch behind the dash. As long as the ECU is there behind the dash (ie, some kind of wiring to a switch on the dash), then it is possible to fit it. Link to comment Share on other sites More sharing options...
96sz Posted January 16, 2012 Share Posted January 16, 2012 Hi. I have a Garfy module at the moment, but dont have an ecu, just a loom Garfy made from the module to the spoiler motor. Unfortunately it has stopped working, so would you be able to make a similar set up with your module? If so, how much would it be? Thanks. Link to comment Share on other sites More sharing options...
AndrewOW Posted January 16, 2012 Author Share Posted January 16, 2012 Hi. I have a Garfy module at the moment, but dont have an ecu, just a loom Garfy made from the module to the spoiler motor. Unfortunately it has stopped working, so would you be able to make a similar set up with your module? If so, how much would it be? Thanks. Yes, of course. PM'd. Link to comment Share on other sites More sharing options...
ballsdeep Posted January 16, 2012 Share Posted January 16, 2012 I can provide a version that includes the loom to the motor, which means you can connect it directly to the switch behind the dash. As long as the ECU is there behind the dash (ie, some kind of wiring to a switch on the dash), then it is possible to fit it. pm'd Link to comment Share on other sites More sharing options...
Josh Posted January 16, 2012 Share Posted January 16, 2012 Very interested. I put mine down every time I stop, even if it's just for a second. I'd love for it to be down all the time (except for speed bumps). PM me more info (if that's what the plan is) Link to comment Share on other sites More sharing options...
Havard Posted January 16, 2012 Share Posted January 16, 2012 Can you pm me the costs Andrew, ta...!! Link to comment Share on other sites More sharing options...
Littler Posted January 16, 2012 Share Posted January 16, 2012 I'm interested too, could you PM me cost etc... Cheers! Link to comment Share on other sites More sharing options...
AndrewOW Posted January 16, 2012 Author Share Posted January 16, 2012 Very interested. I put mine down every time I stop, even if it's just for a second. I'd love for it to be down all the time (except for speed bumps). PM me more info (if that's what the plan is) Can you pm me the costs Andrew, ta...!! I'm interested too, could you PM me cost etc... Cheers! PM'd Link to comment Share on other sites More sharing options...
Josh Posted January 16, 2012 Share Posted January 16, 2012 I get paid Friday, so will let you know then Cheers! Link to comment Share on other sites More sharing options...
AJI Posted January 17, 2012 Share Posted January 17, 2012 Can I also have a PM with a few more details ie. cost, ease of fitment etc. Cheers. Link to comment Share on other sites More sharing options...
Havard Posted January 17, 2012 Share Posted January 17, 2012 Just had a nice change of PM's with Andrew, sounds a great deal. If I have any problems fitting it, I will employ M_Life to sort it out. He only charges a Sunday lunch for most jobs..!! H. Link to comment Share on other sites More sharing options...
neilp9876 Posted January 17, 2012 Share Posted January 17, 2012 I'm interested if you can post up some details. Does it remove the "auto" function all together or can it work as "auto" or manual? Can it have a trigger to revert back to "auto" if you go above a certain speed? Link to comment Share on other sites More sharing options...
AndrewOW Posted January 17, 2012 Author Share Posted January 17, 2012 I'm interested if you can post up some details. Does it remove the "auto" function all together or can it work as "auto" or manual? Can it have a trigger to revert back to "auto" if you go above a certain speed? I've updated my original post with some of the features including the loss of the 'auto' function, etc. Link to comment Share on other sites More sharing options...
Burna Posted January 17, 2012 Share Posted January 17, 2012 Is it possible to wire the box of tricks so that when it is switched on and in use, it sets the active spoiler to a permanant down position. Then when you switch off the box of tricks, it reverts to standard auto mode? I really don't want to completley lose the auto mode, yeah I'm fussy I'm 99% sure this is how the old Blitz module worked, but they are as rare as rocking horse poo! Link to comment Share on other sites More sharing options...
AndrewOW Posted January 17, 2012 Author Share Posted January 17, 2012 Is it possible to wire the box of tricks so that when it is switched on and in use, it sets the active spoiler to a permanant down position. Then when you switch off the box of tricks, it reverts to standard auto mode? I really don't want to completley lose the auto mode, yeah I'm fussy I'm 99% sure this is how the old Blitz module worked, but they are as rare as rocking horse poo! As answered on Facepants: Unfortunately, this module bypasses the ECU entirely, and makes the spoiler fully manual only. I do like the idea of being able to have both, but that would mean fiddling about with the spoiler's ECU, and Garfy hasn't done that. This module replaces the ECU. I'd imagine the Blitz version would cost loads as it has to fit on the existing plug too. Sorry about that, but this module is good anyway. Link to comment Share on other sites More sharing options...
Scott Posted January 17, 2012 Share Posted January 17, 2012 How many wires are on the module? Link to comment Share on other sites More sharing options...
AndrewOW Posted January 17, 2012 Author Share Posted January 17, 2012 There are 8 wires on the module. Link to comment Share on other sites More sharing options...
Scott Posted January 17, 2012 Share Posted January 17, 2012 There are 8 wires on the module. Would it not be possible to have them switchable? Link to comment Share on other sites More sharing options...
