TSS sprint setup
dr_jekyll
 Share
  • Replies 116
ok some good news and some bad news
good news.
the car passed the mot with no advisorys, the tester said it was tip top :)
bad news
i tested the loudness with an i phone and it showed 138db. dose that sound a bit high to be rite to you? im hopeing the app is just miles off
  • 2 weeks later...
it was supposed to be a trough dash :( i even baught the air saw to chop my dassh up . but o offerdx it up today and it is the dash dodger
it is the safty 21. question is, do i send it back and have to wait onothe 5 weeks or do i just get it on for this season and get a better one next year
got a bit more done today
i had to relocate my afr guage due to the cage obstructing it where it was.
and i fitted the kill switch pedrosixfor kindly sent me. i also fitted the pull cord to the scuttle pannel
all i need now is to fit the cage and im on track on feb the 12th for some testing:)
Edited by dr_jekyll (see edit history)
If it passes scrutiny I'd run with it for this year Craig, feck it, you have it now, see how you get on with the series and the car this year.
Then, next year, if you want to continue running the Supra you could probably strip the interior and get someone like Andy Robinson to build you a proper cage thats FIA complient and a structural part of the car, that way you can try out various forms of motorsport with the same car, TSS, Time Attack, Drift, Drag, a good cage is essential for all these. You'll sell this cage next year no problem.
  • 2 weeks later...
got a few more bits done. fitted the cage and i have to say the cusco cage was a perfect fit , verry tight and easy to install. i striped another few pounds of weight , panels/ wires ect and iv done all the wiring for the kill switch.
pics to follow
verry close to being ready for action now
  • 2 weeks later...
Craigs slacking lol, so here is the updated list.
Secure smaller battery, Done
cover battery positive Done
fit yellow earth Done
Remove alarm Done
Fit engine kill and pull cord Done
Remove air con Done
Weight reduction , rear seat belts , trim ect Done
Reset timing In progress
Fit cage Done
Fit stickers Done
Fit spoiler Done
mot and tax Done
sound test 102 db limit to be tested
Re wrap the manifold Done
Fit new clutch In progress
Source and fit new suspension In progress
Replace Turbo and manifold gaskets In progress
Relocate oil catch can Done
Fabricate new IC pipe work Done
Acquire sponsors In progress
Edited by nevins (see edit history)
he's team/ project manager. :)
yea sorry about the pics ive been pretty busy in work but luckily the arc angel nevins has been on the case and been helping out . he kindly riped out my aircon sysytem yeaterday and removed the remainder of the sound deadening as well as sorting some sponsers for the car.
the car is in a million pices at the moment so when shes back in one piece and rwady for rockingham ill get snapping.
 Share
