Aerotop roof leak.....again
jackso11
Right, I am fed up with having a wet seat when it rains so its about time I changed the seals. I have tried the old silicone spray trick but no joy.
Who is currently the best person to contact or best place to go to for roof seals? I don't think Nic is currently about so I am a bit stumped, unless I go straight to toyota but am guessing they are v.expensive there.
  • Replies 59
I thought mine was coming through the driver side at the top of the window as when I get in and its raining, the first time I press the brakes it pours the settled water out onto my leg. Last night I had a look and am thinking it is the front seal where the roof butts up to the front.
The caar is a 1994 so new seals must help a bit, otherwise its time to get a rain mac for the car.
Supradibbs, where did you get your seals?
How much was where they?
The following prices I was given by Nic in 2007, but I don't know if they are still those prices, or if Nic is still trading. Hope that helps.
Hi Andrew
I would need to order these, order tiem would be around 4-5 weeks, plus 5-7 days postage to UK
WEATHERSTRIP, ROOF SIDE RAIL, LH = £31 each including postage
WEATHERSTRIP, ROOF SIDE RAIL, RH = £31 each including postage
WEATHERSTRIP, REMOVABLE ROOF, FRONT = £35 each including postage
WEATHERSTRIP, REMOVABLE ROOF, REAR = £35 each including postage
cheers
Nic
I bought mine back in 2006/7 from Mr. T and as far as I remember they were about £36 a side, so not much different from Nic. These are one of those things you expect to cost loads from Mr. T and are surprised how cheap they actually are.
I'm happy to say in this thread of woes, My roof doesn't leak, or rattle for that matter.
