Tricky-Ricky Posted May 14, 2009 Share Posted May 14, 2009 I run them at 14.7-15:1 off boost depending on the rpm and load Reason they are hotter on the Solaris equipped car is also a part of the reason why they make more torque and spool up quicker as i set something slightly different which is used alot in the racing world and it works wonders with the 2jzgte. Your Egts are low as you only run of the wastegate rick not 1.6bar I think i can guess what that might be:) I only run 1.1 to 1.35 bar via a separate boost controller. Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted May 14, 2009 Share Posted May 14, 2009 I think i can guess what that might be:) I only run 1.1 to 1.35 bar via a separate boost controller. Its nothing to do with ignition timing. Quote Link to comment Share on other sites More sharing options...
little num Posted May 15, 2009 Share Posted May 15, 2009 i have uk twins and in 6th gear flat out then hit the speed limiter i see 900's and my sender is in cylinder 1 exhaust output, is this high, i use water and meth that come in at 0.8. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 15, 2009 Share Posted May 15, 2009 i have uk twins and in 6th gear flat out then hit the speed limiter i see 900's and my sender is in cylinder 1 exhaust output, is this high, i use water and meth that come in at 0.8. I think the std setup runs a bit higher EGTs from what i remember, simply due to the manifold, turbos and downpipe design, the whole lot is somewhat more restrictive than a single setup. Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 16, 2009 Author Share Posted May 16, 2009 I have removed the turbo. Pics to follow. I spun it when I removed the compressor and it still stuck, it wasn't catching on the compressor housing. The oil everywhere is from me cranking the engine over with the oil feed removed to see if it was getting oil (I figured I couldn't do any more damage to it). The turbine is catching on the central cartridge (not the housing) when I spun it with the housing removed. I can't see how the housing can warp enough to cause that damage, there is nothing in the housing that goes anywhere near that part of the blade (unless I'm mistaken). Also checkout my manifold. I'm assuming this is fooked? Can anyone confirm? I guess I'm looking at new turbo & manifold now? (possibly full turbo kit) Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted May 16, 2009 Share Posted May 16, 2009 What manifold is it Jay? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 16, 2009 Share Posted May 16, 2009 I would say that the turbine damage is simply due to the divided gasket going, and the manifold distortion is also a result of that, is one of known causes of the turbine damage, Is there any play in the shaft of the turbo? the exhaust turbine will catch on the plate when removed from the housing as its a loose fit until bolted up. Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 16, 2009 Author Share Posted May 16, 2009 What manifold is it Jay? Sound Performance Rob. I would say that the turbine damage is simply due to the divided gasket going, and the manifold distortion is also a result of that, is one of known causes of the turbine damage, Is there any play in the shaft of the turbo? the exhaust turbine will catch on the plate when removed from the housing as its a loose fit until bolted up. There is a tiny amount of play in the turbine shaft Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 16, 2009 Share Posted May 16, 2009 I guess the manifold could be saved by carefully grinding out the divider, i presume the turbo housing is divided? so if you have the turbo repaired i think it would be wise to change it. Just out of interest where the other two also divided? Be interesting to know how many of the others that failed where also divided housings? Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 16, 2009 Author Share Posted May 16, 2009 I guess the manifold could be saved by carefully grinding out the divider, i presume the turbo housing is divided? so if you have the turbo repaired i think it would be wise to change it. Just out of interest where the other two also divided? Be interesting to know how many of the others that failed where also divided housings? The turbo isn't divided Ricky, the other one wasn't either. Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 16, 2009 Author Share Posted May 16, 2009 Considering this is the 1st time I've attempted anything like this I don't think I've done too bad Just need to decide on the way forward now. New tubular manifold/new cast manifold/repair this manifold, GT35R, GT4088R, T67DBB. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 16, 2009 Share Posted May 16, 2009 The turbo isn't divided Ricky, the other one wasn't either. Where you using a gasket? even if you weren't i still think the divider becoming overheated and melting could have been the reason for the blades looking like that, i never use a gasket, just paste, as i know from experience just how easily turbo gaskets can fail. Quote Link to comment Share on other sites More sharing options...
Wez Posted May 16, 2009 Share Posted May 16, 2009 Do you have a pic of the gasket you removed? If you are using divided housings on an undivided manifold or visa versa you should use a undivided gasket. Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 16, 2009 Author Share Posted May 16, 2009 No gaskets were used guys, just paste Quote Link to comment Share on other sites More sharing options...
michel lane Posted May 16, 2009 Share Posted May 16, 2009 looks like something went through the turbo blades causing the problem. The manifold can be repaired. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 16, 2009 Share Posted May 16, 2009 looks like something went through the turbo blades causing the problem. The manifold can be repaired. Yeah! like melted bits of the manifold, by the looks of the turbine surround. Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted May 16, 2009 Share Posted May 16, 2009 Time for a new manifold i would say Jay. Give Whiffins new maninfold and a t67Dbb a try Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 16, 2009 Share Posted May 16, 2009 Wow that manifold does look fooked, might be able to machine it flat and grind out the divided part but as said id try one of Pauls manifolds as he is a uk trader offering a full warranty on them. Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 16, 2009 Author Share Posted May 16, 2009 I pm'd Paul earlier this morning for details on his manifold with a T67DBB Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 17, 2009 Share Posted May 17, 2009 Nice idea to test that combo Quote Link to comment Share on other sites More sharing options...
L33 Posted May 17, 2009 Share Posted May 17, 2009 were u using a turbo blanket on this turbo? Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 17, 2009 Author Share Posted May 17, 2009 were u using a turbo blanket on this turbo? Nope Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 19, 2009 Author Share Posted May 19, 2009 Well I've decided on the new setup. Just like to thank the guys who's ears I bent on the phone/pms asking advice Since I've taken this apart myself I need to put it back myself, I decided against the Whiffin manifold in case it moved the turbo & I couldn't get my downpipe on . The same reason was why I decided against a cast manifold. So I've decided to get a genuine HKS GT manifold (which is basically what my current SP manifold is copied from) so fitment should be exactly the same. Turbo wise I've gone with the popular T67, but I've gone with a one of the new range of Precision T67DBB's with the billet wheel (new compressor design). Should be able to see the same power my GT40 was putting out with a lot less stress I haven't given the final go ahead yet, so if anyone has any "Noooooooo don't do that because" comments I'd like to hear them sonner rather than later Quote Link to comment Share on other sites More sharing options...
b_have Posted May 19, 2009 Share Posted May 19, 2009 Nice combo jay, I use the HKS GT manifold, great quality. Interested to see the new Billet wheel on the T67, whats the price/availability on this turbo? Quote Link to comment Share on other sites More sharing options...
Luxluc Posted May 19, 2009 Share Posted May 19, 2009 I am running a HKS manifold on my PHR stage 1 ... very nice piece Quote Link to comment Share on other sites More sharing options...
