Supra Track Car Project
Ryan.G
Rest of the Alu panels are now sprayed and fitted :)
All the Braided brake lines are now done also and hooked up... just need to tidy the brake pipe routings with some P clips now.
Also started making up the new wiring loom in the cabin.
Last but not least got my head back from Swindon Race engines who have done one hell of a job. :thumbs:
Just need to get some New head bolts and fly wheel bolts and it all goes back together.
:cool:
  • Replies 1k
Ryan, will you be there tomorrow? I might pop in on my way past, see if I can lend a hand with anything in the new few weeks. Sorry I couldn't make the sand-down paint prep day.
I believe he is at the SRR meet tomorrow.
Sweet. What did they do to the head? Also, I hope you're going to put rubber grommets on those cable going through the body work?
Off the top of my head... :D
- 5 Angle valve job
- Replace stem seals
- Light porting
- Flow test before to see where any gains can be had
- Flow test after
plus loads more but cant think of it this early lol
Yes rubber grommets will be used but dont want to use them just at the moment while im making the loom as if you start putting things through them and then removing, it only makes the seal worse
Ryan
- 5 Angle valve job
- Light porting
- Flow test after
Ryan
Be interesting to now what the before and after flow test results are. :)
The entire wiring loom is now done... WHAT A JOB THAT WAS! :blink:
Tested the electrics last night on the whole car and it worked a treat :)
Also finished all the brakes lines... just need to P clips all the lines and the wiring now.
What do you reckon, Spray the switch board white or do it in Carbon?
Guest ali 556
update ?
not bad so far...but i were you i'd kept the interior black...works for me...
white x white....:taped:
over all not bad....notes :
1- heat wrap your dp or your leg will get burned.
2- apply some heat deadning metrial between you and the floor or your ass will get it...lol
3-
TT 6 spd ratio is 3.13 (usdm) and 3.26 (jdm) dunno about uk :blink:
TT auto is 3.73 for all...swaping auto diff into 6-spd will make your first gear usless....
don't do it..
Started doing the fuel system. Ran a - 8 line from the tank for the feed to the dual feed rail
Made a sealed removable unit for accessing the tank in the back
Also modified the fuel hanger for the -8 line
Had the Timing star all welded as well as the Shortened prop and the Egt boss into the manifold
