LONG LIST of NA & TT Parts for sale
Ibrar Jabbar
 Share
Parts listed below are from:
NA 5spd manual Supra (65,000 Kilometers)
J spec TT Auto(130,000 Kilometers) and UK spec Auto
I will accept offers on most parts, please email me at [email protected], so I can keep track of enquries or call 0121 707 4554.
I will accept payment via Paypal, cheque or bank transfer.
All parts are now removed and ready to go, pictures of all parts are available on request.
Note:
Parts listed are in no paticular order.
UPDATED LIST 30th JAN 2006
[ATTACH]25138[/ATTACH]
ENGINE BITS
X2 Fan Impellers £30 each
Fan Viscous £50
UK TT Inlet Manifold £100
TT cylinder head + cams £150
NA cylinder head +cams £150
X1 Alternator NA £80
Engine mountings £45 each
Gearbox mountings £45
TT VSV, IACV, etc, etc
NA Pulley cover £15
TT Plug cover £35
NA/TT 2nd catalyst £40
NA Diff (non LSD) £100
NA Manual Propshaft £50
TT Auto Propshaft £50
TT Torque convertor £80
NA Clutch Master & slave cylinder + Reservoir £60
NA Brake servo + Master cylinder + Reservoir £80
Power steering cooler pipe £25
J spec brake discs front £25
callipers front £40
J spec brake callipers rear £40
Front shocks (standard KYB) £30 each
All Suspension control arms front and rear
Aircon pipes
AC Condensor + Receiver £80
AC Compressor £80
NA Water Radiator £75
Cam & Crank Pulleys, belt tensioners, etc.
TT Pressure Tank £30
TT OEM BOV's £15
TT Fuel Rail UK spec £30
NA Fuel Rail
440cc injectors + rail £80
TT Oil Cooler UK spec £40
Battery clamp £15
Auto dipstick £10
EXTERNAL + BODY BITS
Full lock set
Wiper Motor front £30
Wiper Motor rear £30
Front wiper arms L+R £30 pair
Rear Quarter glass O/S and X2 N/S £40 each
Rad clamps £15 pair
Boot lock & cables £30
Bonnet lock & cables £40
Bonnet Hinges £20 pair
Tailgate Hinges £20 pair
X4 Tailgate struts £35 each
O/S Original Veilside skirt (needs Little work) £40
Doors OS + NS in red, siver and white £100 each
Door mirrors in red, silver,white and black. £50 each
UK spec headlight washers L+R £30 pair
Gold Toyota logo badges front & rear £5 each
Rear spoiler in black £80
ELECTRICAL BITS
UK Clarion Double Din head unit with remote.[ATTACH]25446[/ATTACH] £80
NA Ignition Coil £50
NA Ignitor £40
Fuel Pump ECU £20
Door control ECU £20
Power steering ECU £20
UK spec Lamp Failure ECU £20
Interior light £10
X2 Ignition Switchs £40
X2 Fuse box Internal UKAuto & Jman
X2 Fuse box External UKAuto & Jman
Radio Amp + Loom £30
Dash tweeters £5
speaker enclosures £10 each
X1 odo £60
Speedo/Rev/Fuel gauges (manual) £50
Window switches O/S + N/S
Window motors/regulators O/S + N/S £75
NA Engine loom £60
Auto Kick down switch £10
No Plate light £15
Active Spoiler ECU £30
X2 Dimmer switches £5
X2 Mirror adjust switches £5
TRAC/ABS Relays
Airbag ECU / L+R Sensors £20
Oil Temp control ECU £20
Deceleration sensor (UK) £20
Fuel pump control ECU £20
Engine ECU UK Auto £100
Gearbox ECU UK Auto £50
INTERNAL BITS
Standard TT 3 spoke steering wheel £60
UK spec steering wheel + Cruise cntrl Switch £60
Steering airbag UK spec £50
Manual Gearbox panel £30
Ashtray £15
Rear View mirror £10
Centre console lid £15
X2 Steering coloums
Top glovebox side vent left & right £10 each
Diagnostic port Panel (below steering wheel) £15
N/S A post panels X3 OS £10
Rear Panel (lock area) (cracked) £10
X2 Sill top panels L+R £10
X2 Steering coloum covers top + Bottom £20
Boot rubber seal £10
Front speaker covers £5 each
Rear Speaker covers £5 each
Rear Inside panels top + bottom L+R £10 each
Pedal set footrest, clutch, brake and accelerator
X2 Lower gloveboxes £30 each
X2 Handbrake lever + switch £20
Bonnet pull handle £5
OS rear strut trim (in boot area) £10 each
Rear seats X2 pairs £20 each
Dashboard complete £40
X2 Heater Matrix £80
X2 Heater motor + ducting box £80
Front seat parts inc Motor etc.
Autogear shift without knob. £20
Ignition lock and key
  • Replies 118
what condition is the boot rubber seal in? Is this something that I could re-use or is it better to buy new?
Also looking for the manual gear panel.
Are the electric mirrors folding.
Please PM or email me with details and prices.
thx
 Share
