Uprated tailgate struts
Guest Rays the roof
 Share
Guest Rays the roof
After significant interest in these I have found an engineering company (via a member on here Peter Richards) who will help with these. He has already done a pair for Peter some 5 or so years ago and he says they are still working perfectly.
They will provide more resistance than the stock struts and hence eliminate you getting a sore head if you have fitted a heavier aftermarket
What he does is remove the brackets off the existing struts and fit them to an uprated new strut. The turnaround time will be 2 - 3 weeks and you will send your struts direct to them. They will then do the neccessary work and return them to me for a clean up prior to sending back to you.
I have negotiated a price for the pair including P & P of £90. I believe Toyota charge £170+ for a new inferior pair so thats a saving of over £60 for a more powerful set!!
Need 5 pairs minimum for this to be viable:
1.
2.
3.
4.
5.
  • Replies 84
Guest Rays the roof
any chance of supplying these polished? Might be nice to have a bit of shiney stuff at the back und as well as the front end :)
I'm sure I can for an extra £5 you bloody Magpie!! :p
Guest Rays the roof
stop upping the price! :p
Thanks to you I have just increased the price by another £5. What was your mobile number again so I can forward it on....:p
I guess they have to be made first. :)
What is the turn around time of these?
Made this a little clearer for you in my first post matey. Should have gone to Specsavers :p
If Ray really loved us, he'd get an example set made up to show us :p
Well I don't so go away and stop mithering me. What do you think this is a business?? ;)
If the order is made after the 25th (payday) I will have some of these :D
My current ones may aswell be filled with candy floss, the lifting power they have only makes a hamster jealous, everything else in the world is stronger.
No sweat! So you want a polished set with led lights on and the option to fit a smoke machine at a later date??
AND YES I AM IN A SARCY MOOD FOR A CHANGE!
:innocent: i realy need to keep it shut :taped:
:D all seriousness ray ray! be a nice chap and keep a set on 1 side till my income picks up again ;)
 Share
