Scooter Posted March 31, 2017 Share Posted March 31, 2017 Ok, my 1994 TT split a turbo coolant hose during the week, a pin prick hole luckily and little coolant loss. Just as a heads up really i've added the picture of what I found within, horribly cracked and degraded (sorry the pic is so bad). When i removed it was noticeable bulged and it 'crackled' in my hand when i squeezed it which prompted me to slice it down it's length. It's one of the front two pipes that are only a few inches long and are on the front of the turbo's just behind the intercooler pipework, near the front vsv's. Anyway 10mm (3/8) heater hose and all is good again, but i know there are at least a couple of similar pipes oil filter side (main rad ones i've already changed) that i'll need to attend to sooner rather than later. Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted September 10, 2017 Share Posted September 10, 2017 that looks bad, I'm currently replacing lots of parts like this, replaced a good few now, just going to be a bit of a journey. most people would say if its not broke leave it, yeah but some things like this that are cheap enough and easy enough to change I'm going to change, and I mean everything, in time of course Quote Link to comment Share on other sites More sharing options...
The Raven Posted September 10, 2017 Share Posted September 10, 2017 Yeah my P.S pipe more or less went from being ok to falling apart. Alot of the rubbers are going to need doing as a matter of course soon Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted September 10, 2017 Share Posted September 10, 2017 Thats hectic.. Do you have the part numbers of the hoses you replaced? Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 10, 2017 Author Share Posted September 10, 2017 I've only replaced two 16284-46020 pipes, but I used generic hose/tubing. Need to get round to the harder to access ones at some point. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted September 10, 2017 Share Posted September 10, 2017 I've only replaced two 16284-46020 pipes, but I used generic hose/tubing. Need to get round to the harder to access ones at some point. Thanks mate Quote Link to comment Share on other sites More sharing options...
jonny mac Posted September 11, 2017 Share Posted September 11, 2017 quite a common thing I've noticed now on the various older Toyota's I've worked on, the rubber is just getting to that age now where it will perish and collapse now, recently I'd seen a heater matrix pipe split on a 1jz because the hose was just so old and weak, luckily was caught in time before boiling the engine. this turbo pipe you've had split also happened to one my mates with a mkiv supra, it must be the temperature difference taking it's toll on the older pipes Quote Link to comment Share on other sites More sharing options...
stevie_b Posted September 11, 2017 Share Posted September 11, 2017 I've only replaced two 16284-46020 pipes, but I used generic hose/tubing. Need to get round to the harder to access ones at some point. I think several of the coolant hoses on my NA could do with replacing. Are there any guidlines you can pass on about getting generic hoses? How do you get the bends correct? Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 11, 2017 Author Share Posted September 11, 2017 The two I changed have a slight bend and so straight 'will do', I might have just got some from my hose stash can't remember (I think these two are 10mm Internal diameter?). Any with a defined angled bend in I'd be minded to get from Toyota or a copy with the same 'set' angle. Quote Link to comment Share on other sites More sharing options...
JasonR24 Posted September 11, 2017 Share Posted September 11, 2017 Thanks for the share, might have to look up the cost of all the hoses and replace them as a precaution. No doubt that will be pricey! Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 11, 2017 Author Share Posted September 11, 2017 The two pipes I did are coming in at over £10 per pipe, they are only 4-5" long and pretty much straight. The others look to be £13-£17 per pipe! I think you could get away with doing the turbo side ones, these must see the extreme heat/heat cycles. Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 11, 2017 Share Posted September 11, 2017 Worth doing all the hoses, same goes for the brake lines, ps lines and brake caliper seals Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted September 16, 2017 Share Posted September 16, 2017 been down Toyota today to pick a load of bulbs up for my dash restoration. while I was there, I asked about the coolant lines, on with the parts computer again. there are 4 turbo coolant pipes in total, I ordered them all , £75 2 in this country , 1 in Toyota big warehouse in Europe and the other has to come from japan. there are 3 extra turbo bypass pipes looking at the computer I think, plus there are an 4 additional water coolant pipes. plus theres oil pipes for the turbos also. couple of hundred id imagine from mr T , Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted September 27, 2017 Share Posted September 27, 2017 £73 and this is just the 4 turbo pipes, Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 27, 2017 Author Share Posted September 27, 2017 Indeed! the top two are the ones I did with regular hose (very little curvature) Not so bad if you look at the cost over 15 odd years but still a bit rich!? Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted September 27, 2017 Share Posted September 27, 2017 do you lose much coolant when changing them? Quote Link to comment Share on other sites More sharing options...
Scooter Posted September 28, 2017 Author Share Posted September 28, 2017 Well as mine sprung a pin hole leak and the two I did are 'up top' when I pulled them (after everything had cooled down!) they were pretty much dry with no spillage. If you are doing this on a non leaker then I would either drain a bit from the rad tap underneath, or undo the top hose and lower it and drain into a container etc to lower the level? Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted September 28, 2017 Share Posted September 28, 2017 Well as mine sprung a pin hole leak and the two I did are 'up top' when I pulled them (after everything had cooled down!) they were pretty much dry with no spillage. If you are doing this on a non leaker then I would either drain a bit from the rad tap underneath, or undo the top hose and lower it and drain into a container etc to lower the level? Quote Link to comment Share on other sites More sharing options...
