Had An Eventful Day!!
Havard
Hi..!!
Had a great day today.....NOT!:(
Things started yesterday when I got a phone call from the contractor who is doing our drive on Monday asked if he could start today (Sunday). I reluctantly said yes and set about clearing the drive for their arrival.
Surely enough this morning they arrived with a big digger and a jack hammer and off they went. Things were going quite well until 2pm, when I was called outside! The contractor said "I'd give Transco a ring if I were you!!" :( They could smell gas after pulling up the concrete slab at the top of the drive! I rang Transco and an engineer arrived within an hour and did some tests. Well what do you know, we have a gas leak!:blink:
I wondered if the contractors had damaged the pipe and spent a good hour worrying about how this was going to end up and also how much it was going to cost! The gas people got out a digging team and found the source of the leak. Basically the steel pipes under the drive had corroded and luckily the mixture of clay, plastic sheeting and the concrete had held most of the leak in. It also looks like it has been corroded for a while too....!! They reckon we'd been quite lucky for the gas not to build up under the house which could have been quite spectacular in different circumstances!!
:bang:
Here are some pics from todays events! Suffice to say, we are in a bit of a mess at the moment with no gas, no heat, no hot water and no drive, so our 3 cars are out in a street that you can't swing a cat in!!:rolleyes: Luckily the work is not chargeable so that's a bonus!
http://img222.imageshack.us/img222/5954/pict1098kn6.jpg
http://img223.imageshack.us/img223/6971/pict1101il0.jpg
http://img223.imageshack.us/img223/6900/pict1102ca1.jpg
http://img91.imageshack.us/img91/5530/pict1099rw1.jpg
http://img91.imageshack.us/img91/9342/pict1100ii9.jpg
I'm meant to be working tomorrow but I will have work people and vans everywhere!!
H.
:blink: Well that is an eventful day !! sounds you was lucky with the gas pipe tho gulp !! If you need owt just ring Paul im off work this week :)
Cheers
-Ian-
I think we'll have enough people here tbh!! Next door is having his drive done tomorrow by a different contractor and they are delivering a skip in the street too.....:( Some of the NW lads have been in our street and know that it's only about 50 yards long with 10 houses!! We will have 4 vans, a flatbed grabber wagon, a small digger and shit loads of cars!!
My neighbours love me!!:D
H.
Is that you croutching in the corner with your "special suit" on? :D
Does this mean that the gas people have to pay for a new drive to be layed or is it too late?
No mate, it was the gas man! I walked outside and saw him with the mask on and said "Fook me, it must be serious if they have to get the SAS involved!!:) Not sure if he found it funny but I chuckled!!
Hmm!! Never thought about claiming for a new drive off the gas company.....:eyebrows: They don't have to disturb much of the ground anyway as they are sending a plastic liner up the inside of the original steel pipe! Good job next door is having his drive done as they will have to dig his up too. The liner they are fitting to the main pipe will cut off his gas, so he has to have is pipework connected properly!!;)
H.
H.
No worries matey ;)
Cheers
-Ian-
No heat, no drive and no hot water but hey.. you still have Sky TV ;)
Also love the way the gas an has all that suit and piping on but the other end seems to be just left in the box... right behind him :blink:
As I am to embark in this new drive stuff, what are you putting down and if you don't mind... at what cost (pm ok?)
I'm having pattern imprinted concrete. It's 3k..:blink: but they are also making the drive wider by filling in a section of garden that we don't use too! May give me 1/2 an extra parking space if we are lucky!!
H.
H.
Good choice. I was thinking the same but halving the size of the drive to cut the cost. She'll have to park hers on the road then and I'll never be blocked in :innocent:
What a double whammy :eyebrows:
At least you found the leak, the gas board are changing all the pipes around where I work in Malmesbury, and blew up three houses, when they didn't spot a leak, and it collected under the house:(
:( These guys yesterday were only young but were really safety conscious. We'll hopefully be sorted later!;)
H.
Sounds like someone was watching over you.
The neighbours certainly would have loved you even more then if your house leaped twenty feet in to the air :D
The worrying thing is you wouldn't have known about it if you weren't having the driveway done.
Have you told your neighbours as maybe their pipes are in a similar state of wear !
It seems that the whole estate will have the same problem Col. We have been lucky that the clay and conrete has held in the majority of the gas!
H.
