oilman Posted November 2, 2004 Share Posted November 2, 2004 You will have seen us around the boards here and on other Club sites. We have now become a trader here and would like to add this thread to our offer for the Club. If you would like any advice concerning oil we would be happy to help whether it be a recommendation or just general oil related advice on topic. As you will be aware we sell Motul, Silkolene, Castrol, Mobil, Fuchs and Total Oils and will be arranging monthly "group buys" in the future where good savings can be made. You will find tech data on all the oils we sell on our website by clicking here or on our banner: http://www.opieoils.co.uk/lubricants.htm So, if you want a recommendation please provide the following information to allow us to make an accurate one: Make Model Year Engine size and type Driving style (track/road) Modifications above standard bhp Oil Currently used We hope that this thread will be useful to Members and grow into an informative FAQ over time. Cheers Simon Quote Link to comment Share on other sites More sharing options...
oilman Posted November 5, 2004 Author Share Posted November 5, 2004 The most under employed adviser on the boards! Cheers Simon:thumbs: Quote Link to comment Share on other sites More sharing options...
Alex Posted November 5, 2004 Share Posted November 5, 2004 Start point - Simon can you recommend oils for these situations Toyota Supra TT 1993 2997cc I6 Short Journeys Completely standard. Recommended Oil = ??? *************************** Toyota Supra TT 1993 2997cc I6 Long Journeys Completely standard. Recommended Oil = ??? *************************** Toyota Supra TT 1993 2997cc I6 Track Days Only Completely standard. Recommended Oil = ??? *************************** Toyota Supra TT 1993 2997cc I6 Track Days Only 50% Power increase over stock. Recommended Oil = ??? Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted November 5, 2004 Share Posted November 5, 2004 I'll have some of this. Car hasn't been running the same since the last service: ************************** J Spec Supra TT 1993 3000 24V Twin Turbo Road use Apexi air filter, boost controller, turbo timer (that that it matters), full exhaust inc. de-cat pipes, cold plugs... stick my neck out and say 380bhp roughly (anyone?) 10/40 used at mo ************************** Thanks Quote Link to comment Share on other sites More sharing options...
oilman Posted November 8, 2004 Author Share Posted November 8, 2004 Alex, Thanks for the little task. Before I start, you need to take some factors into consideration and these are BHP above stock and driving style (track/road etc) which will have an effect on basestock chosen and/or viscosity as manufacturers recommendations are for stock cars and normal road use. To put it as simply as possible, the more the car is modded or the use is extreme, the more need for either a proper ester/pao synthetic of a slightly thicker oil to give better thermal stability. The Manufacturers book recommendation is for a 10w-40 but of course this could be either mineral oil (lowest quality), semi-synthetic (adequate quality) or fully synthetic ester/pao (top quality/best protection so a sort of better/best situation. It's always best to stay as near to 10w-40 as possible, i.e. 5w-40, 10w-40 or 10w-50 which will be suitable in most cases but bear in mind the following aspects. 5w will give better cold start and short journey protection on a car that is being used on the road. SAE 50 will give more heat tolerance for cars that are running high temps (above 110 degC) so your selection should be based on your driving style and track temperatures if applicable. If you have an oil cooler for example, you can use a 5w-40 and will gain a few extra BHP's through lower oil drag. So, here are my recommendations: Toyota Supra TT 1993 2997cc I6 Short Journeys Completely standard. Recommended Oil Silkolene PRO S 5w-40 (Fully) Silkolene PRO S 10w-50 (Fully) Motul 300V 5w-40 (Fully) Motul 300V 10w-40 (Fully) Silkolene XTR 10w-40 (Semi) Motul 6100 Synergie 10w-40 (Semi) *************************** Toyota Supra TT 1993 2997cc I6 Long Journeys Completely standard. Recommended Oil Silkolene PRO S 10w-50 (Fully) Motul 300V 10w-40 (Fully) Silkolene XTR 10w-40 (Semi) Motul 6100 Synergie 10w-40 (Semi) *************************** Toyota Supra TT 1993 2997cc I6 Track Days Only Completely standard. Recommended Oil Silkolene PRO S 5w-40 (Fully) (COOLER) Silkolene PRO S 10w-50 (Fully) Motul 300V 5w-40 (Fully) (COOLER) Motul 300V 10w-40 (Fully) *************************** Toyota Supra TT 1993 2997cc I6 Track Days Only 50% Power increase over stock. Recommended Oil Silkolene PRO S 5w-40 (Fully) (COOLER) Silkolene PRO S 10w-50 (Fully) Motul 300V 5w-40 (Fully) (COOLER) Motul 300V 10w-40 (Fully) Hope this helps, any questions, please feel free to ask. Details of all the above products, including tech data can be found here: http://www.opieoils.co.uk/lubricants.htm We can always start another "group buy" if people want to order. Cheers Simon Quote Link to comment Share on other sites More sharing options...
oilman Posted November 8, 2004 Author Share Posted November 8, 2004 Originally posted by GeordieSteve I'll have some of this. Car hasn't been running the same since the last service: ************************** J Spec Supra TT 1993 3000 24V Twin Turbo Road use Apexi air filter, boost controller, turbo timer (that that it matters), full exhaust inc. de-cat pipes, cold plugs... stick my neck out and say 380bhp roughly (anyone?) 10/40 used at mo ************************** Thanks I guess that I've answered your question above? Cheers Simon Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted November 8, 2004 Share Posted November 8, 2004 You have mate. Much appreciated Quote Link to comment Share on other sites More sharing options...
LeeT Posted November 8, 2004 Share Posted November 8, 2004 on my uk spec it says that the stock engine should take 10w/30?? please could you pm me a price for silkolene pro s 10w/50 cheers ...lee Quote Link to comment Share on other sites More sharing options...
oilman Posted November 8, 2004 Author Share Posted November 8, 2004 In Europe, 10w-30 is replaced by 10w-40 as 10w-30 is not a readily available grade here. Please email me for prices: [email protected] Cheers Simon Quote Link to comment Share on other sites More sharing options...
oilman Posted June 10, 2008 Author Share Posted June 10, 2008 Just found this old thread. Any questions please post em up here Cheers Guy. Quote Link to comment Share on other sites More sharing options...
Guest civicsam Posted June 11, 2008 Share Posted June 11, 2008 hi simon, got a supra N/A, i do 16 mile journeys twice a day and the same over the weekend and thats it, i do drive quite hard but not crazy! just wanna change my oil and whats best for my non turbo and how much! its standard 220bhp thanks sam Quote Link to comment Share on other sites More sharing options...
keener Posted June 11, 2008 Share Posted June 11, 2008 I'm up for a bit of guidance too. '97 TT Stock engine Used daily, year round car, not used on track. Many thanks in advance! Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted June 11, 2008 Share Posted June 11, 2008 Basics are here guys.... http://www.mkivsupra.net/vbb/showthread.php?t=56684 Quote Link to comment Share on other sites More sharing options...
oilman Posted June 11, 2008 Author Share Posted June 11, 2008 hi simon, got a supra N/A, i do 16 mile journeys twice a day and the same over the weekend and thats it, i do drive quite hard but not crazy! just wanna change my oil and whats best for my non turbo and how much! its standard 220bhp thanks sam Just a 5w-40 synthetic then will be fine http://www.opieoils.co.uk/p-984-fuchs-titan-supersyn-5w-40-high-performance-fully-synthetic-engine-oil.aspx http://www.opieoils.co.uk/p-805-mobil-synt-s-5w-40-superior-performance-synthetic-engine-oil.aspx http://www.opieoils.co.uk/p-877-motul-8100-x-cess-5w-40-gasoline-and-diesel-engine-oil-100-synthetic.aspx http://www.opieoils.co.uk/p-1146-silkolene-pro-s-5w-40-ester-synthetic-oil-for-high-performance-engines.aspx There are a few to choose from Cheers Quote Link to comment Share on other sites More sharing options...
oilman Posted June 11, 2008 Author Share Posted June 11, 2008 I'm up for a bit of guidance too. '97 TT Stock engine Used daily, year round car, not used on track. Many thanks in advance! See my reply to civicsam Cheers Quote Link to comment Share on other sites More sharing options...
oilman Posted January 5, 2009 Author Share Posted January 5, 2009 Any advice on oil required, please feel free to ask as I can help you You will also find some useful info on my website here http://www.opieoils.co.uk/c-341-car-service-packs.aspx All the best for 2009 Cheers Guy Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 5, 2009 Share Posted January 5, 2009 hi do you just specialise in engine oil ? if not can you reccomend the best oil for the 5 speed w58, the car has been turbo converted and is runinng 330 bhp and is regularly abused Quote Link to comment Share on other sites More sharing options...
oilman Posted January 5, 2009 Author Share Posted January 5, 2009 hi do you just specialise in engine oil ? if not can you reccomend the best oil for the 5 speed w58, the car has been turbo converted and is runinng 330 bhp and is regularly abused We specialise in all things oily. Which car is this in or is it a special? Cheers Guy Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 6, 2009 Share Posted January 6, 2009 its in a n/-t supra Quote Link to comment Share on other sites More sharing options...
oilman Posted January 7, 2009 Author Share Posted January 7, 2009 Have you dont a TT conversion or a big single? If it is a TT then we would suggest a 5w-40 synthetic, if it is a big single used in anger then 10w-50 synthetic. For the 5 speed box a good 75w-90 such as th Silkolene Syn5 75w-90 http://www.opieoils.co.uk/p-850-silkolene-silktran-syn-5-75w-90-fully-synthetic-gear-oil.aspx Cheers Guy Quote Link to comment Share on other sites More sharing options...
TLicense Posted January 7, 2009 Share Posted January 7, 2009 Hello Guy, I'm in the process of building an engine. What are your recommendations on oils for initial start-up and running in etc. Cheers, Quote Link to comment Share on other sites More sharing options...
oilman Posted January 7, 2009 Author Share Posted January 7, 2009 To run in use a 10w-40 semi synthetic, these are all 100% mineral base so ideal for the job. http://www.opieoils.co.uk/p-990-fuchs-titan-xtr-10w40-high-performance-semi-synthetic-engine-oil.aspx Cheers Guy Quote Link to comment Share on other sites More sharing options...
TLicense Posted March 7, 2009 Share Posted March 7, 2009 Hello guy, Many thanks for that. What would be your suggested oil / filter change schedule for a new build engine? Cheers, Quote Link to comment Share on other sites More sharing options...
oilman Posted March 8, 2009 Author Share Posted March 8, 2009 If you are running in use a mineral based oil, a 10w-40 semi synthetic is ideal for this. Run for around 1000 miles then switch to a decent synthetic. Cheers Guy Quote Link to comment Share on other sites More sharing options...
CarlM Posted April 17, 2009 Share Posted April 17, 2009 Hi Simon, was hoping you could pick the best oil and oil filter for me, thanks Make: Toyota Model: Supra Year: 1993 Engine size and type: N/A J-Spec Auto Driving style (track/road) Mainly just a few short journeys in the evenings and weekends, very rare long journeys. Modifications above standard bhp: None Oil Currently used: Unsure Quote Link to comment Share on other sites More sharing options...
