grahamc Posted June 13, 2007 Author Share Posted June 13, 2007 Hi Graham Boost depends on the strength of the engine, fuel being used, etc. max I'd want to run at on road fuel and on a relatively stock engine would be around 1.4bar. I generally run at 1.2bar which is insanely quick, 1.4bar spins the wheels up in the dry in 3rd. I'll check the price for you. cheers Thats seems like some decent figures, and te sort of route that I would like to go. The max boost figure is not an everyday figure. Most of the time I would drive around with the boost reduced. Look forward to it. Nic...is that dyno @ the wheels or Fly? (lovely smooth delivery) Does look nice and clean. What are the other parts required to get the turbo fitted and running properly? turbo manifold downpipe Quote Link to comment Share on other sites More sharing options...
Branners Posted June 13, 2007 Share Posted June 13, 2007 I obviously wasnt paying attention last week when you had problems with your car. I thought you were on a fully built engine with a single turbo. Is your spec as it stands AEM ECU, built engine and hybrid sequentials, ie stock based uprated turbos? JB Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted June 13, 2007 Share Posted June 13, 2007 Nic...is that dyno @ the wheels or Fly? (lovely smooth delivery) Estimated Fly Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 13, 2007 Author Share Posted June 13, 2007 I obviously wasnt paying attention last week when you had problems with your car. I thought you were on a fully built engine with a single turbo. Is your spec as it stands AEM ECU, built engine and hybrid sequentials, ie stock based uprated turbos? JB Standard engine not fully built. Hybrids, link ecu, hks fuel system (680), walbro fuel pump, 264 cams, fmic, and the other usuals Quote Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2007 Share Posted June 13, 2007 Estimated Fly Quote Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2007 Share Posted June 13, 2007 What are the other parts required to get the turbo fitted and running properly This is the full spec, the parts highlighted in red were installed when I converted to the GT35R ENGINE Garret GT3582R HKS Manifold HKS Wastegate PHR Screamer Pipe PHR 4" Downpipe and Mid Pipe PHR 3" Intake kit HKS R-Type Front Mounted Intercooler PHR IC Hard Pipe HKS Racing Blow-Off Valve Type 2 HKS Oil and Water lines HKS Cams in256/ex264 HKS Adjustable Cam Gears Chris Wilson Gas Flowed Cylinder Head HKS R-Type Oil Cooler HKS Super Fire Spark Plugs HKS Oil GREDDY Ti-R Exhaust GREDDY Oil Filter POWER ENTERPRISE Double Row Aluminium Radiator PHR Radiator Cover PHR Polished Upper Radiator Pipe FUELING WALBRO 341 255 ltr/hr Fuel Pump HKS Fuel Rail HKS 680cc Fuel Injectors HKS Adjustable Fuel Pressure Regulator ELECTRONICS HKS F-Con V Pro HKS F-Con V Pro Harness HKS F-Con Pressure Sensor HKS F-Con Temp Sensor Set HKS EVC VI Boost Controller RACELOGIC Traction Control DEFI 60mm Electronic Boost Gauge DEFI 60mm Electronic EGT Gauge DEFI 60mm Fuel Pressure Gauge DEFI Control Unit Innovate AFR Gauge Turbo Timer TRANSMISSION & DRIVETRAIN Standard 6spd Manual TRD Twin Plate Clutch/Flywheel SUSPENSION HKS Hypermax II Coilovers TRD Suspension Bushes ARC Titan Front Strut Brace CUSCO Type CB Rear Strut Brace BRAKES UK Spec Front & Rear Brakes PROJECT-MU SCR-PRO Front Brake Discs TRD Brake Pads TRD Brake Lines TRD Brake Fluid WHEELS/TYRES Weds Sports SA-70 18x10/18x9 Michelin Pilot Sports (Fr 245/18/40 Rr 285/18/35) EXTERIOR TOP SECRET Type III Front Bumper TOP SECRET Type III Side Skirts TOP SECRET Type III Rear Spats Facelift Headlights Facelift Rear Lights Facelift Indicators Clear Side Markers INTERIOR TRD Steering Wheel GREDDY Dual Pillar Pod http://img183.imageshack.us/img183/656/cimg0004kn4.jpg Quote Link to comment Share on other sites More sharing options...
bolarbag Posted June 13, 2007 Share Posted June 13, 2007 Hi Nic, could you pm me a price for that GT3582R too please, What A/R's did you go for compr/exh? Exactly what model wastegate is that HKS? And lovely smooth delivery nice power figures too, but just wanna know one thing? What would be recommended to make that power curve last longer? It seems to tail off at just over 6000, was that a personal preference? Does this turbo run out of puff at that rev range? And as mentioned...estimated flywheel power...how do you get that from a dyno? Was it a hub dyno or something Quote Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2007 Share Posted June 13, 2007 Hi Nic, could you pm me a price for that GT3582R too please, What A/R's did you go for compr/exh? Exactly what model wastegate is that HKS? And lovely smooth delivery nice power figures too, but just wanna know one thing? What would be recommended to make that power curve last longer? It seems to tail off at just over 6000, was that a personal preference? Does this turbo run out of puff at that rev range? A 264 intake cam may give a bit extra up top. I already had the in256/ex264 cams installed and this setup really helps wind things up quickly lower down. I have a 7000k rev limit which it reaches very quickly in lower gears. In 4th and above it does start to drop off slightly after 6K, but I have very few opportunities day to day to actually get up to those sort of speeds in HK. I wanted a setup that was as responsive as possible lower down, which was why I chose the GT35R, the GT40R would give more top end hp, at the expense of a little more lag (still minimal). The turbo is GT35R, .82 AR, with T-04 inlet, 3" V-band exhaust fitting and 3" compressor side exit. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2007 Share Posted June 13, 2007 Forgot to add, I bought the HKS set up kit, this includes the manifold and the Racing wastegate (plus V-band fittings). The wastegate spring is rated at 0.9-1.3bar. 1420-RT015 HKS Single Turbo Set Up Kit http://www.hks-power.co.jp/products/turbo/support/set/img/image_01.jpg Quote Link to comment Share on other sites More sharing options...
bolarbag Posted June 13, 2007 Share Posted June 13, 2007 256/264 would make good sense for spool, does that make the sup an interference engine? You are quite right though, not many times will you get the opportunity to take the car to its limits on topend But say you did, are the cams the only way to increase topend performance? price for mani and turbo(individually too please) Quote Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2007 Share Posted June 13, 2007 256/264 would make good sense for spool, does that make the sup an interference engine? No But say you did, are the cams the only way to increase topend performance? With this size turbo yes. price for mani and turbo(individually too please) I'll need to check the price of the turbo and get back to you. Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 13, 2007 Author Share Posted June 13, 2007 Nic, price on the turbo and install kit please... Quote Link to comment Share on other sites More sharing options...
Guest pecheythefrench Posted March 8, 2009 Share Posted March 8, 2009 does anyone know any links for upgradeing twin turbos on supras Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted March 8, 2009 Share Posted March 8, 2009 http://www.mkivsupra.net/vbb/search.php?searchid=5974704 Quote Link to comment Share on other sites More sharing options...
AndyT Posted March 8, 2009 Share Posted March 8, 2009 does anyone know any links for upgradeing twin turbos on supras Lee P is the man for the most successful twin upgrade. Huge money. Your best bet is a GT35 or T67DBB, Solaris ecu map it via RyanG get it fitted by most of the traders here. 12k should sort you out. Quote Link to comment Share on other sites More sharing options...
johnny g Posted March 8, 2009 Share Posted March 8, 2009 There is this kit http://www.speedforsale.com/supraparts//product_info.php?products_id=635&osCsid=g4hvj8t27n17mntf3jae26fj54 Quote Link to comment Share on other sites More sharing options...
