grahamc Posted June 12, 2007 Share Posted June 12, 2007 What options are there for twin turbo upgrades?? I have hybrids, and I like the feel of the twin setup (no jokes about my car)... I know you get big twins...but are there any small/medium twin upgrades available? Quote Link to comment Share on other sites More sharing options...
Homer Posted June 12, 2007 Share Posted June 12, 2007 I'm not sure what you're getting at here, do you wish to replace the stock/hybrid turbo's with larger ones that replicate the stock system? If so, thats not possible. If you wish to switch to a conversion, then a twin system is only really for the big power cars. A small or mid sized single is the only cost effective upgrade from hybrids if you want to retain low range torque Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 12, 2007 Author Share Posted June 12, 2007 I'm not sure what you're getting at here, do you wish to replace the stock/hybrid turbo's with larger ones that replicate the stock system? If so, thats not possible. If you wish to switch to a conversion, then a twin system is only really for the big power cars. A small or mid sized single is the only cost effective upgrade from hybrids if you want to retain low range torque it was the first bit in your reply... its not possible... pity though... then what is te choice for the small mid sized single turbos...?? just try to research costings a bit... Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted June 12, 2007 Share Posted June 12, 2007 You sure it's not possible? I thought it was possible but at a HUUUUUUUGE cost Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 12, 2007 Author Share Posted June 12, 2007 You sure it's not possible? I thought it was possible but at a HUUUUUUUGE cost Ok, re-phrase the question to include "cost-effective"... Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted June 12, 2007 Share Posted June 12, 2007 Ok give us a run down of what your looking for (purpose, HP goals, track use?) Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 12, 2007 Author Share Posted June 12, 2007 some road use, some track use, but not an everyday car. responsive and about 500bhp at the wheels... its for when I replace the hybrids. Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted June 12, 2007 Share Posted June 12, 2007 There seems to be a big following for the GT4088 at the moment which will fit your requirements nicely Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 12, 2007 Author Share Posted June 12, 2007 cool... nice to see that your biased... ok would 680cc injectors be enough or would they need to change?? what would I need to buy? turbo, manifold, downpipe, what else? Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted June 12, 2007 Share Posted June 12, 2007 pmsl no I want to change cos everyone has gone gt4088 now! 680's will be fine. You'll be needing an ECU to control the fueling as well Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 12, 2007 Author Share Posted June 12, 2007 pmsl no I want to change cos everyone has gone gt4088 now! 680's will be fine. You'll be needing an ECU to control the fueling as well got ecu - link g2 (shortly being changed to g3) edit - want to sell me yours? Quote Link to comment Share on other sites More sharing options...
Homer Posted June 12, 2007 Share Posted June 12, 2007 Geordiesteve's on the ball with those questions:) It's all about power goals, desired spool, driving style and what you want from the car. If you're happy with a genuine 500rwhp (That is a LOT of power btw!) then the popular choices are going to be: BL/SP/PHR T61 BL/SP/PHR T67 GT35 GT4088 and for quicker spool with same power: BL/SP/PHR T61 DBB (Not sure if all do this spec) BL/SP/PHR T67 DBB GT35R GT4088R Obviously the dbb turbo's cost a lot more, but it helps torque low down. I HIGHLY recommend you get a drive in as many single turbo cars as you can before making a decision (prefeably those with similar spec build & boost). It'll give you an idea of what each of the cars are like on the road. To be honest I think the difference between a base T61 and base T67 is quite large, so don't assume that little number change doesn't make much difference on the road - it does! Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted June 12, 2007 Share Posted June 12, 2007 Thanks Homer lol mines not for sale just yet. Maybe using the same turbo just in different variations (they can be versatile to your spec) Quote Link to comment Share on other sites More sharing options...
Homer Posted June 12, 2007 Share Posted June 12, 2007 pmsl no I want to change cos everyone has gone gt4088 now! 680's will be fine. You'll be needing an ECU to control the fueling as well Are you sure about that Steve? The GT4088 is similar spec to the T67 and that needs at least 720cc to run at 1.4 bar within normal safety margins. got ecu - link g2 (shortly being changed to g3) Good choice of ECU, thats a great start Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted June 12, 2007 Share Posted June 12, 2007 In that case I'm not sure. I thought 680's would run 500rwhp? I'd take your advice over mine on this though. Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 12, 2007 Author Share Posted June 12, 2007 Geordiesteve's on the ball with those questions:) It's all about power goals, desired spool, driving style and what you want from the car. If you're happy with a genuine 500rwhp (That is a LOT of power btw!) then the popular choices are going to be: BL/SP/PHR T61 BL/SP/PHR T67 GT35 GT4088 and for quicker spool with same power: BL/SP/PHR T61 DBB (Not sure if all do this spec) BL/SP/PHR T67 DBB GT35R GT4088R Obviously the dbb turbo's cost a lot more, but it helps torque low down. I's HIGHLY recommend you get a drive in as many single turbo cars as you can before making a decision (prefeably those with similar spec build & boost). It'll give you an idea of what each of the cars are like on the road. To be honest I think the difference between a base T61 and base T67 is quite large, so don't assume that little number change doesn't make much difference on the road - it does! Completely agree, and will try and get in as many singled cars as possible, except for Jamies... I have seen him drive... What is the difference between say the GT35 and the GT4088?? Then whats the R version? Well will see how close my car is at current to 400 at the wheels on the SRR day... edit - and yes 500 at the wheels is a lot, my car running 1.1 bar is rather scary for the first time I have driven a supra... Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 12, 2007 Author Share Posted June 12, 2007 Are you sure about that Steve? The GT4088 is similar spec to the T67 and that needs at least 720cc to run at 1.4 bar within normal safety margins. Good choice of ECU, thats a great start well ideally I would like something to fit in with my current setup. Thanks... will see what the full potential o the ecu is soon hopefully! Quote Link to comment Share on other sites More sharing options...
GeordieSteve Posted June 12, 2007 Share Posted June 12, 2007 In that case ARE 680's enough for Graham's goals? Quote Link to comment Share on other sites More sharing options...
Homer Posted June 12, 2007 Share Posted June 12, 2007 In that case I'm not sure. I thought 680's would run 500rwhp? I'd take your advice over mine on this though. Not sure taking my advice is a good idea I'm basing that on Ian C's findings with the BL T67 (which in theory is should flow very similar to a GT4088 at 1.2+). The 680's will flow enough to provide over 500rwhp but you're going into the 80%+ duty cycle territory which is far from desirable. Completely agree, and will try and get in as many singled cars as possible, except for Jamies... I have seen him drive... What is the difference between say the GT35 and the GT4088?? Then whats the R version? Well will see how close my car is at current to 400 at the wheels on the SRR day... I'd be surprised if your hybrid car is much more than 360rwhp (mine at BPU made this at 1.25 bar and lean as possible fueling), it's still one of the most powerful BPU cars they've dyno'd. The 'R' on the GT turbo's mean it's a dbb turbo so will spool a few hundred rpm sooner than the non-R versions (big difference for a daily driver). I don't remember the exact difference between the GT40 and GT35 turbo's but I think the it relates to the compressor size, the last two number (eg. the 88) to the exducer. Nic might be along later to explain all. well ideally I would like something to fit in with my current setup. Thanks... will see what the full potential o the ecu is soon hopefully! If you've already got the 680's then a T61 spec might be the most use to you. It should be capable of 500rwhp with a good setup and the right cams. It will be devastatingly quick on the road. Wez’s car is probably the best example around of a well set up T61 (so try to blag a lift if you can ) Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 12, 2007 Author Share Posted June 12, 2007 Not sure taking my advice is a good idea I'm basing that on Ian C's findings with the BL T67 (which in theory is should flow very similar to a GT4088 at 1.2+). The 680's will flow enough to provide over 500rwhp but you're going into the 80%+ duty cycle territory which is far from desirable. I'd be surprised if your hybrid car is much more than 360rwhp (mine at BPU made this at 1.25 bar and lean as possible fueling), it's still one of the most powerful BPU cars they've dyno'd. The 'R' on the GT turbo's mean it's a dbb turbo so will spool a few hundred rpm sooner than the non-R versions (big difference for a daily driver). I don't remember the exact difference between the GT40 and GT35 turbo's but I think the it relates to the compressor size, the last two number (eg. the 88) to the exducer. Nic might be along later to explain all. If you've already got the 680's then a T61 spec might be the most use to you. It should be capable of 500rwhp with a good setup and the right cams. It will be devastatingly quick on the road. Wez’s car is probably the best example around of a well set up T61 (so try to blag a lift if you can ) Well still lots of time for research, hopefully! My car is mapped to 1.4 (I only run around 1 - 1.1 on the road) and running 264 cams... hopefully my car will be running properly for the SRR (so get it organised ), as I am quite keen to see what its running. I will scan in the RR printout from THOR which was at 1.2 and running in true twin mode (nice straight line up, no drop in the middle). The R is sounding to be the best option, but that will depend on price. And the 40 vs 35 sizing?? I am going to go have a look at Wezs garage to see what he is running, as that is not the first time I have heard that.... Quote Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2007 Share Posted June 13, 2007 Hi Graham For around 500hp I'd definitely recommend the Garret GT35R (GT3582R). I've recently fitted one on my own car, very responsive and loads of power. Lag is similar to stock turbos, with positive boost around 2K rpm and full boost just over 3-4K rpm. See my garage for full spec. Here's dyno from mine http://img469.imageshack.us/img469/6925/010pk2.jpg cheers Quote Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2007 Share Posted June 13, 2007 I use 680cc injectors on mine with the GT35R, for the GT40R you'll want bigger. Quote Link to comment Share on other sites More sharing options...
grahamc Posted June 13, 2007 Author Share Posted June 13, 2007 I use 680cc injectors on mine with the GT35R, for the GT40R you'll want bigger. The GT35 seems to be the way to go!! What sort of max boost can you get? Then finally thing can you PM me a price Quote Link to comment Share on other sites More sharing options...
Nic Posted June 13, 2007 Share Posted June 13, 2007 The GT35 seems to be the way to go!! What sort of max boost can you get? Then finally thing can you PM me a price Hi Graham Boost depends on the strength of the engine, fuel being used, etc. max I'd want to run at on road fuel and on a relatively stock engine would be around 1.4bar. I generally run at 1.2bar which is insanely quick, 1.4bar spins the wheels up in the dry in 3rd. I'll check the price for you. cheers Quote Link to comment Share on other sites More sharing options...
imi Posted June 13, 2007 Share Posted June 13, 2007 Nic...is that dyno @ the wheels or Fly? (lovely smooth delivery) Quote Link to comment Share on other sites More sharing options...
