Wanted turbo heat shields for UK spec top money paid
jongilly
 Share
As per the title, need both turbo heat shields for my UK spec, the turbos are away being rebuilt, so would like to replace both shields with better ones if available.
Ordered from amayama, but no stock and out of production 😢
Top money paid 👌
Here are photos of mine
Edited by jongilly (see edit history)
5 hours ago, jim_supra said:
Looks like the UK turbo heat shield and J-Spec ones are different, never knew that (and that UK's had two heat shields)
I've got a J-Spec one but not sure it would fit, hopefully someone on here could confirm.
It does not unfortunately.
I do not vouch for these sites so please do your due diligence when looking at them!
This is based on the part you have highlighted in the EPC and using the product code associated with that part which is 17148-46010. The UK spec shared a lot of parts with the US cars as they too had more strict regulations around emissions etc There is only one part showing in the EPC but please do check with the vendor that this is indeed the correct part and don’t forget about import costs. If you google the part number there are more sites if the ones below have no stock left.
https://www.nurduroot.com/index.php?main_page=product_info&products_id=528202
https://www.gmirdsi.top/index.php?main_page=product_info&products_id=677332
https://www.dsmcoflah.com/index.php?main_page=product_info&products_id=545077
  • 2 weeks later...
 Share
