Service Items @ Sensible Prices + Strainer I.D. *****
Should you find an outdated link, please inform me and I will update with a current option. :hi: Thank you.
:think: (Strainer I.D. pics, post #6)
Strainers are silly money from Mr T, who will :sex: make you wait whilst he orders one for you, from Toyota Europe, Belgium?
Stress no more, I now have a small stock of these elusive things. :zen:
Strainer N/A or Hybrid 35330-30011 £20. (1 in stock)
Strainer T.T. 35330-50010 £40, or ebay https://www.ebay.co.uk/itm/Genuine-Auto-Transmission-Internal-Filter-Fits-Toyota-Supra-Automatic-2JZ-GTE/352226333517?fits=Model%3ASupra&epid=1116747400&hash=item520253534d:g:~pcAAOSwZW5aJXPP
A340E-GE GASKET, VALVE BODY, NO.1 35433-30064 £20. (3 big holes)
A340E-GE GASKET, VALVE BODY, NO.2 35434-30076 £20.
Loctite Grey 5660 £6.
  • 2 months later...
(All ATF's listed are Dexron III.)
Toyota ATF Type T-IV. Part no. T08886-82025. From your local Toyota Main Dealer.
Premium Equivalent ATF Mobil 3309 http://www.opieoils.co.uk/p-69402-mobil-atf-3309-automatic-transmission-fluid.aspx
Budget Equivalent ATF Carlube ATF-U http://www.ebay.co.uk/itm/Carlube-ATF-U-ATF-U-Automatic-Transmission-Fluid-Fluid-4-55L-FULLY-SYNTETHIC-/121347314407?epid=1223650824&hash=item1c40dd12e7:g:fmUAAMXQs6FRMgUi
Lucas Stop Slip http://www.ebay.co.uk/itm/LUCAS-TRANSMISSION-GEARBOX-FIX-STOPS-SLIP-710ml-CLEANS-LUBRICATES-STOPS-LEAKS-/231086533452?pt=UK_Vehicle_Oils_Lubricants_Fluids&hash=item35cdd4ab4c
Youtube clip re. Lucas SS. :think: (Tip: Mix with ATF to dilute before pouring this thick stuff into a thin hole.)
My local Toyota, which are usually the cheapest quoted £39 + VAT per 5 litres of Toyota T-IV ATF. With the auto box using around 8 litres it makes sense to buy 10 litres of ATF. Thats an eye watering £93.60 inc VAT with a 7 day wait. I tend to use Millers oils with my car, I always have. I've used Millers Millermatic SPIII (SPIII WS is the updated bottle) for years with no problems. I always get excellent performance and smooth shifting from my auto box using this oil. The application is suitable for Toyota T-II, T-III, T-IV, WS auto boxes. Im not saying go out and buy this ATF I just giving you my experience. Everyone has their own brand they like or prefer so nothing will be 'the best'. Just my $0.02 :)
http://www.millersoils.co.uk/automotive/tds-automotive.asp?prodsegmentID=435&sector=Car
Thank you for the input. :)
Branded lubricants are expensive and everyone has their favourite.
Yet don't miss the common factor that thicker is better for transmissions that are working hard.
Opie recommend Red Line D4. http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine&p=4148414&viewfull=1#post4148414
Club recommendations here; http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine
  • 1 year later...
  • 6 months later...
Drop the pan and there it is :)
(pic :hi: evinX )
Tip: Whilst you can get at them, re-torque all valve-body 10mm-head bolts to 7ftlb.
Tip: Don't use sump gasket, clean both surfaces with brake-cleaner and use Loctite Grey SI 5660.
(Strainer-bolts 7ftlb - sump-bolts 6.5ftlb only)
http://www.ebay.co.uk/itm/282651301240
Halfords stock it too.
  • 6 months later...
  • 3 months later...
FUCHS TITAN ATF 4400 AUTOMATIC TRANSMISSION FLUID
Is another ATF of the accepted specifications and stocked by Opie Oils.
http://www.opieoils.co.uk/p-60163-fuchs-titan-atf-4400-automatic-transmission-fluid-for-japanese-cars.aspx
http://www.ebay.co.uk/itm/182341563568?ul_noapp=true
http://www.mbrecambios.com/638-tm_thickbox_default/titan-atf-4400-1l.jpg
  • 5 months later...
  • 1 month later...
  • 1 month later...
  • 1 month later...
  • 4 years later...
If you have no idea, as far as I understand, if the colour is of a burnt red/brown, then change most of it. Equally if it's red, and the box doesn't clunk more than it should, then just do the 1 part (approx 2l) change. Last time I did mine (2l) I used Toyota's own type IV ATF, and is what's recommended on here. If new ATF is added too often then the polymers can sludge up the box.
Thanks for that. I just wasn't sure whether different ones can be mixed?
Do you mean you don't know what type has been put in before? As I said above if the atf looks ok and the box behaves smoothly etc leave it, or do the 2L part flush.
  • Like 1
Yeh, I’ll do what you said though and take a look at what comes out first.
2 hours ago, Frank Bullitt said:
@tayr A full flush is a good idea, new filter too. How is the pan holding up? Any leaks?
If you are going for a full flush, you could fit the deeper transmission pan and a decent in-line oil cooler (with thermostat) to future proof.
I’m thinking this too, at least then I know what’s in it from the get go. Pan looks fine, no leaks that I can remember but I’ll check this weekend.
I do like the idea of that. I was going to get the SRD auto box cooler when I change the intercooler and having a way of monitoring the temps would be very good. I’ll look into that tomorrow
Its a cracking guide that, last pic should be his first comparison, will guide him if he needs to anything or full flush.
Credit where credit is due, this forum owes a lot to Mr P.Especially us autoboxers. He always put up results and his endless tinkering has been a real lifesaver.
  • Like 1
I’m pretty sure you can mix synthetic and conventional without an issue. I put Fuchs Titan ATF 4400 Ultra High Performance in the tiptronic box. It works a treat, what ever that is worth.
Speak with Opie Oils - https://www.opieoils.co.uk an ex forum trader. They know their apples so will be able to advise you 100%. Lucas Transmission Fix (Stops Slip) is also a good addition when doing an oil change.
When refitting the pan make sure you use a small amount of gasket sealant (Loctite Grey SI 5660 to be precise) as you don’t want it going inside the pan. Make sure both surfaces are spotless. If the pan does leak (no reason why is should) don’t be tempted to fit a gasket (you can buy them) as it’s only a temp fix and will start to leak and then warp the mating faces. Careful not to over tighten the sump bolts, think they need 6 ftlb maybe a little more but not a lot.
If fitting a temp sensor for the box (very good idea btw) make sure it’s in the bottom of the sump, where the plug goes. You can also drill and tap for a sump magnet if you want to be super cautious. Nice mechanical gauges like stack are very accurate.
  • Like 1
 Share
