How easy is it to make custom hard pipes
ripped_fear
Afternoon all,
So my build is soon to enter the next stage and I need to fit my new turbo pipes and inlet.
Having looked at the job in hand, I have been considering getting rid of the OEM hard pipes that run along the top of the turbo's, (even though I have had the oem ones re painted,) Then replacing them with some that can be fitted out of sight.
How easy of a job would this be to at home? and if I was to attempt it what basic tools would I need? I'm guessing some sort of pipe bender, anything else?
Any advice would be appreciated.
thanks
jake
Unless you have a mandrel type pipe bending machine able to accommodate the required pipe diameters you will struggle, only realistic home option is cut and shut which looks horrible and risks welding slag coming off the inside into things where it will do a lot of damage. A *GOOD* TIG welder using internal purge can avoid that. It's really a job to be farmed out to someone specialising in this stuff, the machines are SERIOUS money. The skill required is also something not acquired quickly. The pipes really need beading on a beading roller machine for proper hose retention. All in all far better to just pay an expert to do a nice job.
Thanks Chris think that answers my question, I was thinking about using a hand tool pipe bender but if its as complex as you say I will just stick with my new OEM painted pipe work instead. Was only considering it to tidy up the bay some more but sounds like its a job to be left alone.
Won't messing around with those pipes have an effect on the sequential turbo operation?
They are all conected just mooved, Looked like they wear all done in blue silcone tubeing. So i dont no if they would all work ok. or get sucked flat.?
I have them removed on mine and replaced with vacuum hoses hidden out of sight properly now too, its easy enough to do
Theres no issues using vacuum hose, its what they are made for
As long as you make sure they go back on to the things they came off, youll be fine
Edited by berg (see edit history)
